Is this a single valve cover gasket leak?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cutter_, Oct 21, 2020.
  1. Oct 21, 2020 at 12:15 PM
    Cutter_
    Cutter_ [OP] I probably could have googled this
    2002 Super Air Nautique Build
    Old Man Emu lift, 2 10" JL subs
    2002 5vzfe prerunner 6cyl
    In the first picture is the left side of my engine. I know there is a valve cover gasket leak there I had it diagnosed at the dealer. I just noticed some seepage on the right side of the engine bay in picture 2. Is this the same gasket leak? Or is it a new leak. I’ve heard of many guys just having to tighten down loose engine bolts to fix this problem, but I’m going to have someone do the whole engine completely.
    9D1586DC-D66F-48A2-82FE-E0650B6F2C44.jpg 4D794EDB-6368-4D6F-B0E0-538DAC49DF87.jpg
    GQ7227 likes this.
  2. Oct 21, 2020 at 12:39 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Uhm, I don't understand the question?
    You have a set of valve covers (2) since your truck is in a V configuration hence a set of heads (2).
    Could very well be leaking from each valve cover.
    Do the job yourself, it'll be about 3 hours of work if you take your time.
    TRD-ED and JudoJohn like this.
  3. Oct 21, 2020 at 12:40 PM
    Cutter_
    Ive watched the YouTube videos. I just don’t have the tools.
    GQ7227 likes this.
  4. Oct 21, 2020 at 12:42 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    No worries
    I have gotten by for many years on many different cars/trucks with a craftsman tool set I got from Sears.
    The fact that many locations are closing up shop means you can buy an entire tool set for about a third it'll cost to have the job done by a mechanic.
    From there it's just adding small specialty tools here and there for other jobs.
    I always recommend DIY
  5. Oct 21, 2020 at 1:22 PM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    You can also get a good Craftsman tool set from Lowe's, or even go to Harbor Freight and get Pittsburgh tools.
    The basics are 1/4 and 3/8 drive sockets and ratchets, extensions, a spark plug socket, a set of screwdrivers, pliers, a set of allen keys and some pliers.
    GQ7227 and High Noon like this.
  6. Oct 21, 2020 at 1:26 PM
    JudoJohn
    St. Louis
  7. Oct 21, 2020 at 1:27 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    yep, save some money, stealership quoted me like $500-600 dollars, I told them, nope, I'll get around to it.
    JudoJohn likes this.
  8. Oct 21, 2020 at 1:29 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Kinda just looks like whoever has been putting oil in lets it dribble down the fill neck.
    GQ7227 likes this.
  9. Oct 21, 2020 at 1:29 PM
    JudoJohn
    St. Louis
    For the majority of jobs on my Taco, I use 10,12 and 14 mm sockets or wrenches the most. It's nice to have a set, but you could easily get by with those 3 sizes.
  10. Oct 21, 2020 at 1:35 PM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    like an old chevy, 1/2 5/8 and 9/16 could just about take one apart
  11. Oct 21, 2020 at 9:31 PM
    1997tacomav6
    Denver
    Do it yourself and take your time,
    This would be a good time to paint the covers too.
    A dremel with a wire tip wheel will make short work on cleaning the old gasket material off.
    Did mine 4 months ago
  12. Oct 22, 2020 at 1:54 AM
    TWJLee
    TWJLee Well-Known Member
    Jay
    Midwest
    2001 Tacoma 4X4 2.7 5spd access cab 2020 Tundra DC LmTD 2020 F150 5.0
    2020 Tundra GFC 33’s Borla Pro XS FOX 2.0 2020 F150 33’s Magnaflow FOX 2.0 2001 Tacoma 4x4 2.7 5spd access cab new frame 217k 2” lifted Always for sale.
    They are leaking on both sides. If you are not sure how or what to use, find a good shop and have them explain what they will do and what parts they are going to use. While it is apart, all new gaskets, cam plugs, and a tune up too. Know what it needs at least from the yt vids and service manual so you dont get ripped
  13. Oct 22, 2020 at 3:26 AM
    Tydeorum
    Tydeorum Well-Known Member
    Anderson S.C.
    4x4 SR5
    I just put did the valve cover gaskets on my trucknthis past weekend. Its not overly common you take your time and go slow. Take good pics of the vacuum hoses and where they go. I replaced the spark plugs and wires while I was there.
    I do recommend inspecting each hose you disconnect, i replace a bunch of them because they just split or broke as I was taking them off or sliding them over the barbs reinstalling them. The 3 hoses on the bottom of your thottle body were really hard to take off, just be patient.
    I used a 10, 12, and 14mm sockets, 3 and 6" extention, a pair of needle nose pilers, and a couple flat screw drivers.
  14. Oct 22, 2020 at 6:41 AM
    OMT Tacoma
    OMT Tacoma Member
    F'burg VA
    2001 Regular Cab 4x4 5spd, 1999 Ext. Cab 5-lug 5spd
    OME 2881 Coils front, Wheeler's 5 leaf spring rear, OME Nitrocharger Sports on all four corners, SCS F5 Wheels - 16x8 3.5" BS, 265/75R16 Goodyear Wrangler Authority Tires, Rear diff breather extension.
    I agree with Speedytech as far as the driver's side valve cover oil in your second photo. If it was me, I'd go ahead and replace both valve cover gaskets and at the same time check the valve lash clearance and re-shim as needed.
  15. Oct 22, 2020 at 6:49 AM
    sco
    sco Member
    2002 tacoma 4wd dc trd
    none
    Recently had both valve cover gaskets replaced on my 2001 vzfe at the dealer and it was closer to $1000 after adding new wires, plugs, gaskets, etc. Painful, but like Cutter i just didnt have the time and expertise to do this myself. The other plus is that the dealer can check and adjust the valves if necessary (probably not, mine were fine at 350K miles). Downside is if valves need adjusting the $ meter will keep running.
    1997tacomav6 likes this.
  16. Oct 22, 2020 at 6:58 AM
    1997tacomav6
    Denver
    X2, it will definitely be closer to 1000 if Dealer does it
  17. Oct 22, 2020 at 8:12 AM
    PRECMPR
    PRECMPR Active Member
    Jose
    San Diego
    2004 2WD PRERUNNER TRD OFF-ROAD
    When mine were leaking I went to tighten them and a couple were real loose. So I’d suggest to tighten them a little until you can get the parts to do the whole job.
  18. Oct 22, 2020 at 8:18 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    this^
    slopped over
    Cutter_[OP] likes this.
  19. Oct 22, 2020 at 8:22 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i have a toyota master tech indie shop here can do ALL it for about $500 (ish) including the back plug moons, which dealer apparently does not do or it was not needed idk too many miles ago
    that is a very good deal! if its a very complete & thorough job done
    Dalandser likes this.
  20. Oct 22, 2020 at 8:32 AM
    Cutter_
    stealer quoted me $950 after a discount to fix my valve cover gasket. Local indie shop quoted me $500. Mobile mechanic family has been using for years quoted me $250.
    I’m going to clean the engine bay and tighten the bolts until I get them replaced
    Toyota of Orange (second largest dealer in Orange County) SUCKS!!!! I have had nothing but problems there with Aaron Para, salesman, and their repair crew. I moved and am taking it to the Carlsbad dealer now. They are much better.
    1997tacomav6, GQ7227 and PRECMPR like this.
