Is this a suspension issue? 500 Miles on new suspension and it's ROUGH.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by disel_V1, Nov 16, 2022.
  1. Nov 17, 2022 at 10:00 AM
    disel_V1
    disel_V1 [OP] I eat cold pizza rolls
    3rd Gen
    few things here and there.
    Noted, will make sure I avoid that then.
    thomasburk and tonered[QUOTED] like this.
  2. Nov 17, 2022 at 10:00 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :hattip:
  3. Nov 17, 2022 at 10:28 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I've had a diff drop on for the last 15 years with zero problems... just saying.
    OP... have you retorqued since getting the work done?
    disel_V1[OP] likes this.
  4. Nov 17, 2022 at 11:38 AM
    disel_V1
    3rd Gen
    Are you talking suspension components, specifically? Nope.
    I’m going to pick it up here in a little bit. Just had the tires rebalance and rotated. The shop that perform the suspension work is interested in inspecting it. They will not charge me for an alignment, or to re-torque and adjust things as needed. is there something specific you think may have resulted from not being torqued again?
    Thanks for any insight!
  5. Nov 17, 2022 at 1:17 PM
    OffroadToy
    Nothing specific... just throwing it out there as something to check. Come to think of it my suspension upgrade seemed rough at first but after things settled and got broke in the ride is awesome both on and offroad.
  6. Nov 17, 2022 at 2:20 PM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    I had to do some digging bc things just weren't adding up. You indicated you only replaced shocks, but indicated you also had an AAL installed in another thread. My best guess is you're getting some driveline vibes, and a small shim to correct those angles "could" potentially be your fix. If thats not it, I think you may be feeling the unfortunate effects of a suspension that is way too stiff for your current setup. Eibach coils are 742 lb springs iirc, AND you're preloading them with your 5100's on the 2nd perch. Its gonna look great, but there's absolutely no doubt that its going to ride really stiff without any added weight up front. Driveline angles could be just fine, maybe barely off enough for some 'almost noticable' vibes, that an extremely stiff suspension could amplify. I know others have done it, but my unprofessional and virtually worthless opinion would be to NOT run eibach springs on any perch above the 1st. It may work technically, but thats alot of spring weight to be riding on with no bumper/skids/sliders/winch/extra battery/etc to call for the needed added spring rate.
  7. Nov 17, 2022 at 2:27 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Good info there.
    Along that line, tossing 150lb to 200lb in the bed and see how it feels might not be a bad idea either? The stock leafs are jittery when the truck is empty for some reason.
  8. Nov 17, 2022 at 2:38 PM
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    If you changed the ride height at all absolutely get an alignment.
    If those springs are really 740 lb/in., that is insane. I definitely would not be preloading them with a raised spring seat without a ton of weight. The stock coils are somewhere in the 700 range, but the shocks suck. Now that you have decent shocks, you don't need so much spring rate to help them dampen. With my ARB skids and hidden winch on 6112's, my 600 lb/in springs are plenty.
    CaptainBart45 likes this.
  9. Nov 17, 2022 at 2:41 PM
    Off Topic Guy
    And just to be 100% nothing shady is going on, when you get an opportunity (driving at an appropriate speed in a straight line at a time you can feel it shaking/vibing), throw the truck in 4HI and see if it goes away in 4wd. Wouldn't want to assume that your shop, or any other nice shop out there would operate on shady business practices, but lets rule out something free and easy, just to be certain the ECGS bushing was installed. Lets also rule out some honest mistake didn't happen (them getting into the job, tearing the seal, addressing the seal, and possibly a different tech coming in afterwards to put things back together, with the actual bushing never getting installed). Sounds crazy, but mistakes happen. I started doing my own oil changes many years ago when I had a jiffy lube tech made an honest mistake. Drove in the bay, tech below drained pan, tech at hood refilled, got called away by manager, another tech hopped in to help out, filled an additional 4-5 qts, and sent me on my way. It was an honest mistake, and neither tech had ill intentions; sometimes, a job gets started, someone else comes in to finish, and steps get missed along the way.
  10. Nov 17, 2022 at 3:50 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    Reading thru this I was thinking it might be a driveline vibration. As last resort you might want to find a shop that has an NVH analyzer. Driveline is usually a much higher frequency that say wheel/tire. In my experience most driveline vibrations are similar in frequency to going over the rumble strips on the shoulder of the road. Sometimes it’s almost audible as well.
  11. Nov 17, 2022 at 4:21 PM
    disel_V1
    3rd Gen
    Thanks to everyone for trying to navigate through this clusterfuck.
    Another update..
    so yep, I do have the OME AAL in the rear. Again, never had a single issue prior to this. I know weirder things have happened.
    I thought I’d share another detail, something I didn’t mention because I don’t know if it’s related.
    So, just dropped it off at the off road shop that did the work. They will check it out tomorrow.
    After picking it up, I did notice a faint burn smell. Almost like.. burning rubber, a hot smell nonetheless.
    I couldn’t find it, it disappeared quick. As mentioned earlier, I did do the ECGS bushing at the same time. The seal ripped, oil made a mess. So I’ve just assumed that’s what I’m smelling.
    Why am I bringing this up? Well, the balance and rotate didn’t help, as to be expected I guess. What I have noticed is that shudder / rough feeling happened on the smooth highway as well. Most noticeable around 60. I seem to notice it a bit more when I’m going uphill. So, perhaps that burning smell was a vacuum hose? Perhaps the shudder is the result of air not circulating the way it needs?
    I know I know.. I’m throwing everything at the wall, but it just doesn’t add up. The shop that did the tires earlier is a full service shop, but I’m sure didn’t check for anything.
    So, here’s to hoping to a better tomorrow.
  12. Nov 17, 2022 at 4:38 PM
    Merling
    Merling Well-Known Member
    James
    NH
    2021 Black Tacoma TRD OR
    RCI IFS Skid Eibach Stage 2 Explore Overland Sliders
    To clarify, you did not get new tires when you got the suspension work.
    You may need a carrier bearing drop, the FK29 from ARB is cheap. Just do one side at a time and do your best to keep it exactly aligned as it was.
    I had a hell of a time after a shop did my suspension work and all I can say is I feel for you. Local TW helped me so much to get to a point where I’m pretty happy with my truck now but for a while it felt like I paid someone to ruin it.
    For me, rear block was put on backwards amongst other issues. Can an AAL be installed backwards?
    disel_V1[QUOTED][OP] likes this.
  13. Nov 17, 2022 at 5:38 PM
    Off Topic Guy
    Can't say for 100% certainty, but I'd be willing to bet the burnt smell is just gear oil burning off somewhere. That stuff stinks like crazy. I think all in all, we should throw the idea of "didn't have problems before" out the window, not bc its not important or relevant, but because its not a fair comparison. When you swapped your front eibach shocks for 5100's, reusing the eibach coils, you changed something in your suspension geometry, even if just a miniscule amount. Swapping Eibach for Eibach, wouldn't be any difference. Swapping Eibach for 5100's, they're slightly different, and yield different lift results. I'm not implying that you did anything wrong, or made a bad swap or part choice, I'm just pointing out that they are slightly different in a few ways. I can't remember reading, did you say you DID get an alignment after the swap? Can't say that it'll fix your issues, but it needs to be done regardless if you haven't already, as well as getting a retorque on all suspension components. If you have a torque wrench, this is something you can easily do yourself without a lift or too much mechanical inclination. Until thats done, lets explore some other things, because we really don't have enough consistency or info to build a solid case on one particular part yet. Are you on a stock ECU tune? Do you ONLY notice this shudder with throttle applied? Ever experiencing it while braking? Give us all the info you can; you're not gonna bore us.
    Rusty66 and disel_V1[QUOTED][OP] like this.
  14. Nov 17, 2022 at 5:54 PM
    disel_V1
    3rd Gen
    Absolutely, and makes sense.
    Okay, few things.
    - Alignment was done
    - No new tires, current tires still have 80% left on them. Nitro ridge Grapplers
    - Burning smell I’m sure is related to the gear oil, but hey… you never know
    - That shudder I’m describing, well.. it’s like I feel it in center of the truck, but my sense of where it’s coming from can be off I’m sure.
    - I’ve noticed the shudder going straight, up, or downhill. Just a tad more when going uphill.
    - No tune, or other engine mods at all
    - No slipping, grinding, or other noises that would make me think tranny or something
    - Fun fact, burning smell does not happen when sitting still. Only after driving about 20 min, so I thought perhaps a belt coincidentally started having issues and I’m assuming my recently changed suspension is to blame.
    Guy at the shop is going to overhaul everything he did, I’m sure he’s an honest guy, the shop keeps apologizing… but I feel like I should be apologizing, bringing it back to them.
    Incredibly tempted to pay the diag at Toyota and have them tell me I need a new everything… just to get some compressive assessing lol.
  15. Nov 17, 2022 at 6:05 PM
    #35
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    Mine does the same thing, eibach shocks leveled. I'm positive that it is a combination of shitty shocks, alignment slightly off and possibly shitty rear diff.
  16. Nov 17, 2022 at 6:29 PM
    #36
    Merling
    James
    NH
    Well thats good, the shop I went to was 1. telling me their mistake was me being wrong and 2. treated me like an inconvenience and that my issues were "it happens to these trucks" which just makes me think that they're cool with ruining people's things
  17. Nov 17, 2022 at 6:43 PM
    #37
    Rusty66
    Rhode Island
    The more you describe this problem the more it sounds like a drive line/prop shaft issue.
    Does it change any in 4wd?
    Has the tech verified prop shaft cancellation angles? I would check that, front and rear prop shafts. The U joints.....take the shafts off and verify no binding or wear. Check that center bearing while its out.
  18. Nov 17, 2022 at 6:55 PM
    #38
    disel_V1
    3rd Gen
    Good idea. I did turn 4WH on, it made no difference.
    Off Topic Guy likes this.
  19. Nov 18, 2022 at 2:59 AM
    #39
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    One thing is no matter what perch your on it does not compress the coils, big misunderstanding as people are confused about this. Not opening up for a debate, if your concerned about this then do your research and you will know the truth. I have been on 5100s on two exact same trucks and no matter the settings the ride is the same. Also 5100s are designed and its recommended to use the stock coils. I run mine now on the 5th perch from the 4th and I think it rides maybe a tad better. I think you have a driveline angle issue. Sometimes adding a rear diff drop makes it worse or makes the front vibrate and vise versa when adding a carrier bearing. I run both, vibration free on some 285s with an ECGS bushing. Seems like you upset some angles with the front settings and those heavy coils. My guess is swap your coils.
    71tattooguy likes this.
  20. Nov 18, 2022 at 3:38 AM
    #40
    willee51
    willee51 willee51
    Bill
    Forest, VA
    2022 SR5 DCSB AT 4X4, 6-cyl MGM
    This is the exact results when owners screw with the OEM engineered systems!! :crapstorm::crapstorm::crapstorm: (expected, but I have spoken the Truth)
    Tritiger and disel_V1[OP] like this.
