Is this a suspension issue? 500 Miles on new suspension and it's ROUGH.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by disel_V1, Nov 16, 2022.
  1. Nov 18, 2022 at 6:51 AM
    #41
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    Which is it? You said both trucks ride exactly the same no matter the settings, then say one of them rides a little bit better. I'm not following on the thought process of different perches NOT compressing coils. Sure, the spring rate doesn't change, but shortening the length of the coil by going up perches is most definitely compressing the coil. Either way, in the end, I agree that OP likely has some new driveline angle issues by changing the front coilover setup.
    Merling, Gatafly and disel_V1[OP] like this.
  2. Nov 18, 2022 at 6:55 AM
    #42
    disel_V1
    disel_V1 [OP] I eat cold pizza rolls
    3rd Gen
    few things here and there.
    Shot in the dark….
    I DID get a full tank of gas just before I noticed all this… ANY chance I got bad gas? It was at a sketchy little gas station in the country. I have gotten gas there prior without issue.
    Digging deep here.
    Also, not disregarding the fact that my angles are now wonky. I guess I’m still holding on to the fact for 500 miles.. it was smooth lol. You’d think they would’ve been bad from mile 1… IM NOT A AUTO TECH, I’m sorry lol
  3. Nov 18, 2022 at 7:05 AM
    #43
    Off Topic Guy
    Its gonna be impossible for us to truly diagnose your truck from afar with limited info. If your engine were not running optimally, you'd likely see some ECU codes popping up, or at least see some fluctuations in RPM I'd think. I wouldn't dig too far into much else until you can have the shop check into your driveline angles and address if needed. The most likely possibility at this point is: things need retorqued, driveline angles are causing vibes, or your coilover setup (heavy eibach springs on 2nd perch of 5100's) is riding way more stiff than your previous setup. When you had the eibach coils on eibach shocks, what perch were you running them on?
    disel_V1[QUOTED][OP] likes this.
  4. Nov 18, 2022 at 7:12 AM
    #44
    disel_V1
    3rd Gen
    Yeah I know, I just want the mystery solved lol.
    Okay, don’t drop kick me for what I’m about to tell you.
    On the stage one Eibach’s, I had a heavy front steel bumper. I had them set to the highest setting (3) to accommodate.
    When I took the bumper off, went back to factory, the front end shot up. They only recommend the 2,3rd notch to accommodate for weight.
    So, I had it adjusted, brought it down to the first notch, front end came down. The ride was perfect when it had the steel front bumper, after the bumper, after the adjustment.
    Then, when I saw they were leaking, I said forget it, let’s just “upgrade” and got the 5100’s. Kept the spring because others used the same setup. Now I’m contemplating swapping that spring for a stock spring, doing the driveshaft spacer, and if it continues… buying a ridgeline (jk..)
  5. Nov 18, 2022 at 7:29 AM
    #45
    Off Topic Guy
    Okay cool, so you have a baseline of how it felt on perch 1 AND perch 3 with no added weight, and liked the ride/handling of both. I think that eliminates any of our suspicions about you having an ultra sensitive butt dyno that isn't used to feeling every single bump or rock in the road. If you ran those setups, you're no stranger to a "stiff" suspension. So that leads me to believe the "shudders" you feel are actual vibrations coming from somewhere, not just bumps in the road. It sounds like your suspension shop are good people, and interested in checking it back out, so I wouldn't go around messing with too much of it until you can get it back to them. Only other suggestion I can think of is invite a tacoma friend over, swap wheels/tires, make a short drive, and rule out the possibility of something wheel/tire related. Sounds like your tire guys have ruled out any chance of unbalanced tires, but maybe look into a bent rim. Hit any huge potholes, or run over any curbs lately?
    Merling and disel_V1[QUOTED][OP] like this.
  6. Nov 18, 2022 at 7:38 AM
    #46
    disel_V1
    3rd Gen
    South Carolina roads can be brutal, but I can’t think of any major bumps I’ve hit lately. Also, thank you for such detail in your responses. You have no idea how much it means to me to have a community that is willing to help.
    Is it possible that a tire can be bad without showing obvious signs? I also thought of swapping wheels and tires just to see if they would eliminate anything.
    As far as stiffness goes, I definitely have experience with all those settings, and the ride was awesome in my opinion. No super sensitive butt here lol.
    so, that’s why I think coincidentally, something else may be at play. As soon as I get it back from the suspension shop today, I can at least say for certain everything is good there, then go from there.
    Merling likes this.
  7. Nov 18, 2022 at 8:01 AM
    #47
    Off Topic Guy
    Most definitely, you can have an "out of round" tire, or factory defect, whatever you wanna call it. And a tire shop can even balance one out. The best thing is to have them road force balanced, and a tech can then see if they're "within spec", meaning no tires are perfectly 'round' but have to be within a certain tolerance at least. BUT, if tires were the issue, you would've known from day 1 that you got tires (unless you slung a weight off, but you've had them rebalanced, so no concern there). If tires were fine before, I'd be looking elsewhere. Bent rim also doesn't seem likely, bc it would be consistent and very easily replicable (you'd feel it at certain speeds and would increasingly get worse at higher speeds). All that to say, I wouldn't spend any more money chasing wheel/tire possibilities. Swapping sets with a friend for a quick test drive is easy and free to rule that out.
  8. Nov 18, 2022 at 8:34 AM
    #48
    disel_V1
    3rd Gen
    Understood
    Side question… back to the fuel pump.. some people say they are an all or nothing fail point. So, if mine was on the way out.. could it cause these issues? Or does it really just stop all together?
    Toyota did the recall for mine already. Just curious.
  9. Nov 18, 2022 at 8:50 AM
    #49
    Off Topic Guy
    I'm not really familiar with this topic to be honest, so couldn't tell ya.
  10. Nov 18, 2022 at 10:14 AM
    #50
    sakibomb
    sakibomb Well-Known Member
    Kevin
    DFW Texas
    2016 TRDOR DCSB 6MT
    Dual Batteries Blue Sea Fuse Panel
    Manufacturers match shock valving to vehicle (and coil) specific applications. The Eibach struts you removed are compression/rebound adjusted for the Eibach springs. Bilstein 5100's are set up for stock springs. Those who run OME springs with other shocks (like myself OME 887's and Bilstein 5100's) are mix and matching products are most are fine with it. I would suggest stock springs on whatever notch you prefer on the 5100's, or replace the 5100's with the same Eibach struts you had before.
  11. Nov 18, 2022 at 12:39 PM
    #51
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    Is it all the time or is it more pronounced when you are pressing the gas/feathering the throttle on the highway? These trucks are infamous for having shitty rear differentials. Also if the alignment is slightly off at the toe one tire could be skipping across the road making that high speed vibration.
  12. Nov 18, 2022 at 1:27 PM
    #52
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I raised it to the 5th perch and went up to 285/70s Toyo at3s and the short bed is on 265/70 Toyo at3s. I think it may ride a tad better because of the wider tire and it has 20k miles on it as our other 2018 has 60K on it. Same suspension, set up, wheels etc.
  13. Nov 18, 2022 at 7:48 PM
    #53
    Merling
    Merling Well-Known Member
    James
    NH
    2021 Black Tacoma TRD OR
    RCI IFS Skid Eibach Stage 2 Explore Overland Sliders
    Compressing coils affects preload which most certainly affects ride. Not sure why you’d think otherwise tbh
  14. Nov 18, 2022 at 9:58 PM
    #54
    VaToy
    Parts Unknown
    I think you need to do some more research, not debating it as it's been discussed many times. But your intitled to your opinion.
  15. Nov 18, 2022 at 10:10 PM
    #55
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    Can you shoot a link to a video or a thread that discusses this?
  16. Nov 18, 2022 at 10:24 PM
    #56
    Bishop84
    Bishop84 Well-Known Member
    There's a vendor on here that advises against top perch. I install suspensions professionally and advise against it as well. On any of the bilstiens.
    Extended length or not you're no getting height for free. You pay with ride quality.
    Thats why 5100's with anything but OEM needs to be on zero, and anything above 4 is garbage for ride.
    Merling likes this.
  17. Nov 19, 2022 at 12:27 AM
    #57
    VaToy
    Parts Unknown
    That is what a vendor advises, ok. The shop I have been using is extremely well know in off road suspensions and advises otherwise. Bilstein advises not to use the top perch on certain trim levels on the Tacomas, however mine doesn't fall under that category so the 5th is ok. So per Bilstein and my trusted shop the 5th works for my trim level and I see no ride quality difference between the 4th and 5th settings as the spring rate doesn't change just the perch setting. Not debating this any further as its been discussed several times so it is what it is. People can make their own opinion on this either based on what they read, vendors advise or someone who has has first hand experience.
  18. Nov 19, 2022 at 2:31 AM
    #58
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    5100 have 4 settings and any above the 3rd at 1.75 inches require new UCA to get aligned and many posts on all this with a search.
    Here is the Bilstein link:
    E4-WM5-Y686A00_0 (bilsteinus.com)
    So set the front at 1.75 as highest. All installed per pic correctly and bolts/nuts tight.
    Get alignment. Verify all cams tightened
    Check that CVs and wheel bearings good and they put the ECGS bushing in correctly (see their site) and not pushed in too far.
    Front diff correctly filled and not damaged by bushing install.
    Rebalance (Road Force) and rotate the tires. Are you running SL (C) or E rated tires as big diff in ride.
    Front brakes as a caliper hanging up and/or bad rotors. Brake lines are stock and too short and damaged.
    Steering rack and tie rods all OK.
    Basically any part that the shop touched need to be checked plus the rest.
    Doubtful but verify no issues with any front of engine accessories failing and bearings bad so shaking. Includes idlers and tensioner.
    After all done and the vibration is still there now time to determine if in the drivetrain or rear.
    U-joints or center.
    Springs, bushings, or an altered pinion angle.
    Rear brakes or drums thrown a weight.
    Rear diff or bearings.
    That's a start so hunt on.
  19. Nov 19, 2022 at 7:16 PM
    #59
    Merling
    James
    NH
    Just so you know you sent a link of a pdf that’s on your computer, not a hyperlink to something on the internet.
  20. Nov 20, 2022 at 12:05 AM
    #60
    muddog321
    FL
    Thanks Merling link is fixed I needed more coffee.
    Merling likes this.
