Is this all I need?
Discussion in 'Suspension' started by Bananahands, Mar 1, 2009.
  1. Mar 1, 2009 at 6:46 PM
    Bananahands
    Bananahands [OP] Well-Known Member
    San Diego
    '05 TRD Sport
    I'm currently in the process of trying to get the rear TSB done. From everything I've read I can get the 5100's for the front to somewhat level out the truck after the TSB.
    I just want to make sure ALL I NEED ARE THE 5100's? I don't need new control arms or swaybars or a one piece driveshaft??? or anything else? Just the new shocks, set them to my liking and I'm done???
    Thanks for any guidance.
    Khris
    P.S. In case you can't tell I'm a total newb when it comes to truck suspensions. Any pics of some tacomas with just the rear tsb and 5100's would be great.
  2. Mar 1, 2009 at 6:53 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    the 5100's are all you need to level the truck after the tsb. set them at 1.75, or the setting before that, and you should be good to go.
  3. Mar 1, 2009 at 6:55 PM
    canuck_tacoma
    canuck_tacoma Well-Known Member
    BC, Canada
    SR5 4X4 Tacoma Access Cab
    1.5" Eibach Front Coil Lift, Rear TSB, 265/75/16 BFG A/T's
    Depends on what setting you use on the 5100's. 0.85, 1.75 or 2.5". You should be fine up to 1.75 without a dif drop. Don't forget you will need a wheel alignment.
    I ordered the Daystar, 4 Runner, 1" lift for my Tacoma. 5100's are $700 installed in Canada so I decided against them becasue of price. I was only looking for 1" but it sounds like the 1" Daystar Spacer is going to give me around 2" of lift. I will let you know how it works out.
  4. Mar 1, 2009 at 7:34 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You don't need anything with the TSB....
    Put 200lbs in the bed for a month, and the rear will settle down. YOu don't need to buy anything.
  5. Mar 1, 2009 at 10:08 PM
    Bananahands
    San Diego
    '05 TRD Sport
    I'm actually hoping to end up with a net of 1" lift after the tsb. Not for any particular reason, just for a little bit of a raised look.
  6. Mar 2, 2009 at 8:50 AM
    canuck_tacoma
    BC, Canada
    I've had the TSB for over a year now, have a canaopy, and ran 300 pounds of sand in the back over the winter. I sit at 37.5" in the back and 34.5" in the front with the canopy and no sand, just to give you an idea. Plus I had a few 800pound loads of sand and gravel for my yard since I had the TSB. What are sitting st in the back? I measured from the ground, through the middle of the wheel, to the fender.
  7. Mar 3, 2009 at 8:33 AM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    I'm in the same boat and all ears (*bump*).
    I have an 09 and hope to be getting the TSB done (though it's a battle with the 09's). I'd also like a small lift but have no idea what I need or can get. I want something easy and am doing it for looks (don't do any serious off-roading). I would like to retain a comfortable and stable ride.
    Ideally, I'd like to get a 2-2.5" lift. I may start with the 5100's in the front and leave the back alone (after the TSB).
    Can you AAL with the TSB?
  8. Mar 3, 2009 at 8:50 AM
    MacTaco
    MacTaco Mustache May
    Pensacola, Florida
    06 Indigo, Lifted, Flowmaster
    Skyjacker 3" Lift, 285/75/R16 Toyo M/T tires/ Eagle Alloy Wheels, Flowmaster 50 Series, Pioneer Din Head Unit, Viper Alarm/Remote Start System, Debadged, DT Headers, True Flow Intake
    What happens if I get the TSB done, and I also keep my AAL?
  9. Mar 3, 2009 at 8:55 AM
    06Bluez
    06Bluez Well-Known Member
    Phoenix, Arizona
    06 4x4
    Icon Coil-overs, TC UCA, with Bilstein 5150 and Icon 3 leaf pack. 17" Moto Metal 951 4.5" Backspacing wrapped in 285/70/17 BFG AT's. Demello front bumper and Avid offroad sliders.
    The dealer is gonna steal you AAL like they did mine!!!! try and take it off before hand if you can.
  10. Mar 3, 2009 at 8:57 AM
    MacTaco
    Pensacola, Florida
    Haha, well. I'm sure they would give it back to me if I made it apparent before hand that I wanted it.
  11. Mar 3, 2009 at 9:11 AM
    steelerfan7p
    steelerfan7p My other car is a Bugatti
    Yes
    Fairmont, WV (1 Hour South of the City of Champi
    Non-TRD, Non-SR5, Non- Prerunner
    Rear Leaf Spring TSB, Metra IPod Adapter, AFE Pro Dry S Air Filter, I was added to the truck to make it better, so does that count as a Mod?
    I have read hundreds of posts about the suspension TSB and I have just a couple questions.
    I tried checking all the part numbers, and the only ones that I have found that matches are the leafs (leaves) themselves. My rear shocks do not match that listed on the TSB (it is non-TRD). I cannot get to the front ones very well, so I haven't verified if I need to get them replaced. But my guess would be no since the rear ones don't need to be.
    So since it seems that only the leaf springs need replaced, do I need to get anything else? I assume I would not need an alignment. Do I NEED the 5100's, or is this for cosmetic purposes only?
    Thanks guys. I just want to be sure.
