is this an okay lift kit, mostly for looks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by doons, Aug 21, 2011.
  1. Aug 21, 2011 at 11:56 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    What cutting is involved?
  2. Aug 21, 2011 at 12:02 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    lower diff mount, bump and extension stops.
  3. Aug 21, 2011 at 12:06 PM
    lithous
    lithous Active Member
    Phoenix
    SR5
    Billet grille, pro comp 3"lift. Tint, LR UCA's, De-Badged
    The lift is pretty easy install. The "hardest" part is just compressing the new Coil Springs. Get a good set of coil spring compressors. Make sure you have all the mounting hardware.
    I have the same lift. Took me 4-5 Hrs install. I was missing a few parts and had to find them.
    Also pickup a set of shock boots from Checker. 10 bucks i think.
    You will also need new UCA to correct your alignment.
    Any more questions you can shoot me a PM. Or if your in AZ i can help you out
  4. Aug 21, 2011 at 12:07 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    If I put the kit on, can it go back to stock?
    It depends on the vehicles suspension type. All GM independent front suspension lift applications require cutting of the lower differential mount and bump and extension stops and would require considerable work to return to stock. The 02-05 Dodge 1500 and 96-04 Tacoma kits also require cutting that would not allow a graceful return to stock. Jeeps, 73-91 GM straight axle trucks, Ford Super Duty’s, 94-01 Dodge 1500 and 94-04 Dodge 2500/3500 can be returned to stock.
    :notsure: :notsure:
  5. Aug 21, 2011 at 12:14 PM
    lithous
    Phoenix
    SR5
    This lift does not require any cutting
  6. Aug 21, 2011 at 12:20 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    That's what I thought.
  7. Aug 21, 2011 at 12:31 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    patrick had to cut
  8. Aug 21, 2011 at 12:40 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    OP has a 2011, different kits. The Procomp 6" lift I believe is the one that requires cutting.
  9. Aug 21, 2011 at 12:45 PM
    St. Swervus
    St. Swervus Well-Known Member
    Nathan
    Mill Creek, WA
    '09 Double Cab TRD Sport
    Leer Camper. Thule Rack, NFab side rails w/step, 3' lift, Weather Tech mats, Paracord grab handles, LED interior lights, Bed Rug, Front windows tinted to match factory rears.
    I have this lift on my '09 DCSB TRD Sport. Running 285s .I love it. No cutting was required but they had to remove my front mudflaps due to rubbing.
  10. Aug 21, 2011 at 12:49 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Correction: sorry OP
    I'm not smart enough to read your link
    in first post.. ignore my advice :pout:
  11. Aug 21, 2011 at 12:51 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Haha.. Patrick has the 6" inch right? That's what you were thinking of huh.
  12. Aug 21, 2011 at 12:54 PM
    SATXguy
    SATXguy Well-Known Member
    San Antonio
    2017 4x4 TRD Off Road
    Mobtown Front Recovery bar Relentless Fab Bed bars (3) Quickfist 2 pair Husky Floor Liners Cali Raised bed channer stiffeners Cali Raised low profile ditch light bracket 27 watt ditch light pods w/ side projection OEM Ditch Light switch Roam Adventure Co. Roof top tent Roof top tent annex Costway 54 Quart Portable Refrigerator/Freezer Compact Smittybilt 2789-99 Transit Bag NOCO GC019 12-Foot 12V Adapter Plug Socket Extension Cable Scoshe Magic Mount for Iphone plus Hypertech Speedometer calibrator BFG KO2 AT 265/75/16 JDMCar Center Console Organizer TRD pro Grill TRD PRO Grille Vinyl Decal Gloss Super White X-Bull Recovery Traction tracks 3rd gen CamPark ACT 74 Action Camera DC cargo 2" Diameter Black Steel V-Ring BoltOn Trailer Cargo Tie-Down CLC 1173 32 Pocket Socket Tool Roll Pouch Viair 00088 88P Portable Air Compressor Toyota Accessories PT580-35050-SB Bed Mat for Select Tacoma Models Rhino USA shackle hitch receiver Toyota Accessories PT580-35050-SB Bed Mat for Select Tacoma Models Smittybilt 3x30 recovery strap 30,000 lb capacity Smittybilt 3/4" D-Ring Shackle (Black) 4.75 ton rating 12V 140 Amp Dual Battery Isolator by KeyLine Chargers - Voltage Sensitive Relay Gen 3 Tacoma Auxiliary Battery Tray
    I have that lift and think it is great! I did not install it myself, 4 wheel parts did the install for $245.00.
