Is this Auto LSD at work? (Video clip)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by littleblue81, Apr 14, 2013.
  1. Apr 14, 2013 at 12:31 PM
    littleblue81
    littleblue81 [OP] Well-Known Member
    Below is a video clip of a 2012 Taco TRD Offroad in the snow. I see both wheels spinning as if it has a lsd. Is this the auto lsd at work? And for anyone who has experience with it, do you feel/hear the brake working in the car? I would imagine at the speed the wheels are going here it would sound really crazy...?
    http://www.youtube.com/watch?v=zPBdjDuYa9c
  2. Apr 14, 2013 at 12:36 PM
    BamaToy1997
    BamaToy1997 ASE Master Tech Vendor
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    Looks like you are seeing LSD at work. (Not the drug...lol) At a few points when he was going slow, you could actually see one of the wheels as it spun/gripped/spun/gripped.
  3. Apr 14, 2013 at 4:20 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    I can hear mine working.
  4. Apr 14, 2013 at 4:28 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Trd Offroad = locker also......
  5. Apr 14, 2013 at 6:08 PM
    nathan3306
    nathan3306 Well-Known Member
    Nathan
    Charleston AFB, SC
    2012 SR5 DC 4X4
    That video convinced me to buy my taco...
  6. Apr 14, 2013 at 9:02 PM
    littleblue81
    I'm just assuming he didn't do the any time locker mod. But if that is the "auto" lsd, it looks to be working pretty well.
  7. Apr 15, 2013 at 7:06 AM
    nathan3306
    Nathan
    Charleston AFB, SC
    2012 SR5 DC 4X4
    This may be a stupid question but will this Auto LSD funtion the same for the front as it does the rear? Not talking about ATRAC but similar, just weaker I suppose?
  8. Apr 15, 2013 at 4:23 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    In H4, yes...
    I am not sure of the change made in 2012, but on 2009-2011 the drive mode 'AUTO LSD' was only a 2WD feature and meant TRACtion control but without engine output regulation. In H4, it is (was) called TRAC and is also without any engine regulation, for the most effect. TRAC in H2 has regulation.
    In 2012, there may have been an addition in H4 of TRAC (with regulation) and the former unregulated TRAC in H4 is now called AUTO LSD, in H4...?
    In either case, the traction control in H4 is on the FRONT and REAR tires, no matter if you call it TRAC or AUTO LSD.
    This is why the 4 LO TRAC MOD is so popular for the non Off Road TRD trucks... it provided limited slip to the front tires in L4. Not nearly as firm as A-TRAC, but a world better than just an open front differential in L4.
  9. Apr 15, 2013 at 4:29 PM
    David K
    If the traction is the same under both tires, then both will spin. Off Road or on wet roads this is not always true, and one tire will spin and you may be stuck. A limited slip transfers some of that spin over to the 'good' tire so it turns and moves you.
    AUTO LSD is a manual system in H2, that has no regulation to the engine output... so more power to the good tire. Otherwise, the TRAC system is standard and will limit the tire spin by reducing engine output, instead of just braking the spinning tire. So, if you are stuck with TRAC, then press the VSC switch once quickly to activate AUTO LSD and try and drive away from the stuck. If that doesn't work, then I hope you have a 4WD!
  10. Apr 15, 2013 at 5:45 PM
    nathan3306
    Nathan
    Charleston AFB, SC
    2012 SR5 DC 4X4
    Thanks David K. One day I will get to test it out but until then, I want to learn more about the truck.
