Could this be source of leak?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Suspender, Feb 25, 2018.
  1. Feb 25, 2018 at 9:27 AM
    Suspender
    Suspender [OP] Well-Known Member
    Colin
    IE, CA
    2004 PreRunner Xtracab 2.7l 3RZFE automatic 2WD.
    Not much of a mechanic, would greatly appreciate some input on how big a deal this is.
    The pictures are of the automatic transmission where it bolts to the engine. Does that look like it could be the source of a leak under pressure, or probably just superficial? No idea how it happened.
  2. Feb 25, 2018 at 10:53 AM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    Looks like you might have a rear main seal leaking. I can't really see anything in the pictures on my phone, but if it's coming from inside the bellhousing and it is oil, then it's a rear main. If it's ATF, then it's a pump seal.
    When looking for an oil leak, or any leak, look up and forward. Gravity pulls it down, wind blows it back.
  3. Feb 25, 2018 at 11:33 AM
    abunai2
    abunai2 Well-Known Member
    Do the newer Toyota still have the fiber rear main seal?????
    Those seals lasted way longer than the new all rubber ones.
    You could be having a valve cover leak.
    Also on the older V6, in the back of the head, there was a round rubber lined cam plug that always leaked.
    I don't know if the newer engines are the same.
  4. Feb 25, 2018 at 11:34 AM
    4drtaco03
    4drtaco03 Well-Known Member
    BAY AREA
    2003 v6 TRD / 2004 singlecab 2wd / Now a 2019 SR5 4x4
    Mine looked the same and it was a valve cover leak
