Is this bolt important / what is it.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ryanke11, Dec 9, 2023.
  1. Dec 9, 2023 at 9:07 AM
    Ryanke11
    Ryanke11 [OP] Member
    Robbie
    2017 off road
    A
  2. Dec 9, 2023 at 9:12 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    You have 3 bolts circled.
    The parts in question keep the front diff oriented correctly.
    Ideally, you'd want them all in there.
    If it is one of the outer bolts, make sure the other one stays tight.
    If its the center one, I'd make sure the bushing stays put.
    Ryanke11[OP] likes this.
  3. Dec 9, 2023 at 9:13 AM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    I’m ocd when it comes to bolts nuts and washers. Transmissions are not designed just to have a spare bolt there for no reason. Id be replacing it.
    Chew and Ryanke11[OP] like this.
  4. Dec 9, 2023 at 9:46 AM
    Ryanke11
    Robbie
    2017 off road
    Thank you guys. I will be sourcing this part. Mechanic friend kept saying it’s not that important but he will replace it. That was 8 months ago and never has time to fix it. Onto just getting it done. Thank you for the input.
  5. Dec 9, 2023 at 9:59 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    That isn't the transmission. That bracket holds the front diff in the frame. If it completely lets go in 4WD, the front diff may crash into the engine oil pan. Avoid 4WD until you get it fixed. (It should be safe to run in 2WD indefinitely.)
  6. Dec 9, 2023 at 10:05 AM
    Ryanke11
    Robbie
    2017 off road
    Thank you for that District 6ix. Luckily I have not switched into 4x4 since then and now I know I won’t until it’s fixed. Thank you!
  7. Dec 9, 2023 at 12:06 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Doesn’t sound like a very good tech/friend.
  8. Dec 9, 2023 at 12:13 PM
    PTSDTherapy
    22 SR5 DCSB
    Ditto, especially if you had enough of a gut feeling to come in here and ask us even though he said it wasn’t needed.
    Chew[QUOTED] likes this.
  9. Dec 10, 2023 at 4:44 AM
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    Ah Yes, that entire bracket is extremely important. The front diff is held in place by 3 bolts. 2 in the front on the crossmember and 1 in the rear. That is the bracket for the rear nut. It's an oddly shaped long Allen head.
    Ricardo13x likes this.
  10. Dec 10, 2023 at 10:59 AM
    wayne0
    wayne0 Well-Known Member
    Why would you wait for this nitwit, Just replace it your self, unless you're not capable. I realize, we are not all mechanics.
  11. Dec 10, 2023 at 11:05 AM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    Your friend it’s not a mechanic, it’s a parts changer. And it seems like he doesn’t want to struggle changing that part. Yes, part is important and yes, all the hardware need to be there for proper stress/torque distribution. Cheers my dude.
    Chew likes this.
