Is this BS
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Backt, May 26, 2015.
  1. May 26, 2015 at 9:29 PM
    Backt
    Backt [OP] Well-Known Member
    Oregon
    2012 Tacoma DCSB Off Road Pryrite Mica
    Due to lack of time and not being able to run around for parts I had to go to the dealer today for my first oil change in my new to me 2012 Tacoma Off Road. I bought the truck with 38,000 miles certified pre owned and it now has 43,000.
    After the oil change the service rep says I need a EFI service because the atomization of the of fuel isn't efficient.
    He also said I need a service to clean the throttle body.
    I'm sure it's no coincidence either that each of these symtoms have a 1/2 page dedicated to them in the back of the pamphlet they hand out with oil changes. So my question is this B.S.. More importantly can I add sea foam or a fuel additive over time to clean these and also keep the engine maintained.
  2. May 26, 2015 at 9:34 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Well, you can probably clean the throttle body yourself. The only thing that would cost you is a can of throttle body cleaner, about $5?
  3. May 26, 2015 at 9:39 PM
    Backt
    Oregon
    I'm guessing that's under under the black cover where the air filter is?
  4. May 27, 2015 at 5:57 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    THis is why I hate some dealers and service departments. EFI cleaning is a total money grab by these clowns. I wouldnt even waste my time with seafoam, your truck on has 43K, its a baby.
  5. May 27, 2015 at 6:03 AM
    Pigpen
    Dan
    Northwest Montana
    At this point, all you need to do to it is drive it.
    Lester Lugnut and BassMaster06 like this.
  6. May 27, 2015 at 6:05 AM
    Large
    Large Red
    Just burn a few tanks of gas with a heavy foot, you'll be good to go. Clean the TB beforehand though and you're set.
  7. May 27, 2015 at 6:24 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    This.
  8. May 27, 2015 at 7:38 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
  9. May 27, 2015 at 8:16 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I think I would use a different dealer or do my own service... They are just trying to up-sell you shit that isn't needed. You should have asked how he knew that the " atomization of the fuel wasn't efficient ". I would love to hear his answer.
    That being said the fuel spray pattern can be tested and analysed, but it requires special equipment and the injectors have to be pulled out and ran to test. I do not think that they evaluated your injectors...
    heckeng and KB Voodoo like this.
  10. May 27, 2015 at 9:14 PM
    nextfriday
    nextfriday Well-Known Member
    Indianapolis, IN
    13 SR5 Double Cab
    5100s@2.5", 2" aal Leer 100 XR w/ Yakima rails and towers 18x9 Pro Comp Rockwells Cooper Discoverer AT3 275 65 18
    If you're concerned, pull the air hat and check the throttle body yourself. Look for carbon buildup and grime in the area before the butterfly. I call foul with less than 50k miles but shit happens.
  11. May 27, 2015 at 11:45 PM
    DoctorStrobe
    DoctorStrobe Active Member
    The first thing I would recommend is checking to see if spark plugs were changed at 30K per the maintenance schedule... Bet they are factory plugs.
    Lester Lugnut likes this.
  12. May 28, 2015 at 12:17 AM
    SilverBullet19
    SilverBullet19 Well-Known Member
    Scott
    Sacramento County
    2015 DCLB Prerunner TRD Sport
    The fuels have detergents in them. I worked in automotive for 4 years (3 in parts, 1 in service). Fuel injection cleaning is not needed 99% of the time. Our mechanics never recommended it until the company offered to pay then 1.5 hours for the service (it took them 20 minutes, so they came out ahead). We sold it for $90...it cost less than $40 to do it in cost + labor.
    Even our dealership mechanics flat out told customers it was a gimmick. Half our service advisors refused to even offer it, the other half only did because of the commission. In 1 year I think less than 5 people total had it done.
    So, in summary, you don't need it.
    On a side note, time constraints to purchase the parts? You must be a very busy person if you can't even swing by an auto zone/pepboys/kragen for 5 minutes :boink:
    G.T. likes this.
  13. May 28, 2015 at 1:29 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Like any other job It is the service writers job to make these suggestions I would say at least half or more hate doing it .
    But keeping the wife happy and kids feed over comes misgivings .
    Maybe they figure if your going to the dealer for oil changes you need service suggestions .
    Be nice to know just what a EFI service includes ?? ECM tune up ?? Injector polish ?? fuel filter inspection ??
  14. May 28, 2015 at 6:21 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Did they also offer a 30K power steering fluid flush.....another one of their over-sell tactics.
  15. Jun 1, 2015 at 9:28 PM
    Backt
    Oregon
    I went to the dealer today and requested a full service history of the truck. The truck was originally leased by them and I bought it after the original owner traded it in with 38,000. As the document printed the service tech mentioned that the plugs were not changed at 30,000. I questioned this but he said it was the owners responsility not the dealerships. The service manager had the day off today, but my salesman was in and agreed that the dealership should have changed them before they resold the truck.
  16. Jun 1, 2015 at 10:22 PM
    DoctorStrobe
    I bought my 09 Tacoma at 91k miles. Original plugs. I had a carfax that showed a lot of dealer maintenance too.
  17. Jul 13, 2015 at 8:53 AM
    ready6delta
    ready6delta REGULAR GUY
    JACOB
    Still in PNW but moved to Boise.
    Black pinstriped 2014 DCSB 4x4
    IT NEVER ENDS..........
    I had a dealership just try to offer me this today when I went in for 20,000 mile service! I was like no thanks!
  18. Jul 13, 2015 at 11:17 AM
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    You're being hornswaggled. Enjoy your new truck op.
  19. Jul 13, 2015 at 1:04 PM
    mray
    mray Well-Known Member
    Colorado
    2011 4cyl Base Access Cab 4x4
    I had the exact same thing happen at my last oil change...I go in for my 30K service this week...can't wait to see what is "needed" this time. I love telling them "No thanks!"
  20. Jul 13, 2015 at 1:30 PM
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    bullshit is right. just trying to charge you for nothing, had my 2001 for 13 yrs, all i did was change oil, and basic stuff, last time at dealer with my pro for oil change, while i was waiting, the service tech's ,,, i guess thats what they are called, told 3 or 4 customers they needs this or that , and im thinking dont fall for it,, simple stuff, change air filter for one customer he said like 80 bucks,,, another one needed cabin filter changer 95.00 bucks,, these poor people.. 65.00 bucks t oplau a tire with a small hole in it.. and when the guy walks away they complain to each other about the cost,,,, dont go to a dealer for basic stuff, go to your local guy, simple stuff, and a simple price......
