Is this camber or toe wear?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Buyashotgun, Jan 10, 2017.
  1. Jan 10, 2017 at 7:10 PM
    Buyashotgun
    Buyashotgun [OP] Well-Known Member
    Charlotte, NC
    M
  2. Jan 10, 2017 at 7:13 PM
    Silverspool
    Silverspool Come at me Bro!
    Frank
    DFW
    18T4RORP 17GT350
    Anyone seen my wallet?
    posi camber causes it to be on the outside, the toe caused it to be that severe
  3. Jan 10, 2017 at 7:29 PM
    yeos
    yeos OCD Member
    Moses Lake, WA
    2007 Lexus GX
    Excessive toe causes that kind of wear as well.
  4. Jan 11, 2017 at 8:02 AM
    Caltech90
    Caltech90 Well-Known Member
    '19 TRD OR T4R
    Just had mine done. 0.5 camber on both sides. My tires look fine so far but, I only have about 800 miles on them.
    Edit: Did you ever rotate that set of tires?
  5. Jan 11, 2017 at 8:22 AM
    Zac of all trades
    Zac of all trades FWP Fabrication Vendor
    Zac
    fwpfab.com
    2013 4x4 Locked DCLB
    886/5100s/AAL/UCAs/360 armor/RTT/295 17s
    Just flip it around... You will be good! haha.
  6. Jan 11, 2017 at 9:05 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    its that toe... jezus that toe number was HUGE.... idealy you should be right at .08 - .1* of toe per side... you are 6x that which is 100% the cause of your huge wear difference.
    The positive camber will wear the outside edge a bit more and ideally you want a smidge of negative camber to negate the effects of a rolling bead on turns to promote even tire wear. -0.2 to -0.4* of camber would be ideal.
    But paired together the insane toe in and positive camber will ruin tires quickly as you have found.
    Personally if you are that high on the caster, id sacrifice a bit of caster to get into some negative camber for even better tire wear.
  7. Jan 11, 2017 at 9:31 AM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    Maybe it's just me, but that is quite obvious and I probably would've fixed it a long time ago?
  8. Jan 11, 2017 at 9:54 AM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    Before you do anything make sure all componets are not worn out. Ball joints, tie rods, bushings, wheel bearings as well as any possible frame damage.
  9. Jan 11, 2017 at 2:28 PM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
    How did you not notice wear like that 10 months ago?
    I second the recommendation to check associated parts for issues. What caused the toe to be off >1/2 on each side?
  10. Jan 11, 2017 at 6:55 PM
    magnetic4x4
    magnetic4x4 Well-Known Member
    2013 Magnetic Gray DCSB XSP-X 4x4
    Last time I saw one that bad, another tire shop had left the tie rod end nuts loose, and the tie rod end on one side had spun out about half an inch. I'm not sure about the 2wd, but on the 4wd, the hunter machine says .6 positive camber. Since I've lifted mine and put UCA's on, I run 0 camber and 3.2/3.5 caster, and it drives good.
