Is This Drive Shaft Movement An Issue?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by awoit, Aug 14, 2022.
  1. Aug 14, 2022 at 5:21 PM
    awoit
    awoit [OP] Well-Known Member
    CA
    08 TRD, SR5
    https://imgur.com/RayYdhV
    Not sure if this is fairly common and/or the severity of addressing or how to fix.
    It's got about 180k miles and I've done some towing with it as well (some boats/trailers).
  2. Aug 14, 2022 at 5:25 PM
    Clearwater Bill
    Billy
    Largo Florida
    Looks like that center bearing needs replacing to me. It has spilled it's guts on the floor pan above.
    Good time to check the U joints too.
    Great video.
  3. Aug 14, 2022 at 5:31 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    That's a toasted carrier.
    Time to replace and or upgrade it.
  4. Aug 14, 2022 at 5:35 PM
    Key-Rei
    Key
    Florida
    You wouldn't like my truck lol, I grease my U joints frequently and slowly slowly pump it in till I start seeing clean grease coming out the seals, I have grease sling all over my underbody, free rust protection.
    Basically just saying that sling isn't necessarily an indicator of a bad U joint.
    Unless you were implying the sling is from the carrier bearing, in which case it's a sealed bearing and lightly greased from factory they don't typically sling.
  5. Aug 14, 2022 at 5:38 PM
    awoit
    CA
    08 TRD, SR5
  6. Aug 14, 2022 at 5:46 PM
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    awoit[OP] likes this.
  7. Aug 14, 2022 at 5:48 PM
    Key-Rei
    Key
    Florida
    Yeap that should be it exactly, I have a like on that vid so I must have watched it when doing mine.
    Honestly I think I'd take it to a shop if I had to do it again.
    Getting those U-joint needles to stay and play nice was a huge PITA for me it was not a fun job.
    awoit[QUOTED][OP] likes this.
  8. Aug 14, 2022 at 5:48 PM
    awoit
    CA
    08 TRD, SR5
  9. Aug 14, 2022 at 7:03 PM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Isn’t that just from excess grease from doing u joints?
  10. Aug 14, 2022 at 7:06 PM
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    yeah I was going to say all of mine look like that lol
    TnShooter likes this.
  11. Aug 14, 2022 at 7:06 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Yes, that is a good thing to see.
  12. Aug 14, 2022 at 7:18 PM
    TnShooter
    Deogee
    STOCK
    It’s actually hard to tell from the video.
    These trucks have more play than avg. in the carrier even when new.
    I noticed mine had play in it when I got it at 24k miles.
    I’ve looked other new trucks and they were just like mine.
    You really need to look at the bushing material too.
    But at 180k, you aren’t going to hurt anything by changing it.
    And I can’t think of a reason why you shouldn’t.
    Just take it easy on the bolts when you put the bolts back in that hold it up.
    You don’t need reef on them, the last thing you want to do is break them off.
    I’d personally break them loose by hand too.
    Jimmyh and Alexely999 like this.
