Is this front diff bolt stripped or is it a special bolt?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2009Access4x4, Apr 4, 2024.
  1. Apr 4, 2024 at 4:49 PM
    BigCarbonFootprint
    BigCarbonFootprint Well-Known Member
    Andy
    2019 TRD Off Road
    King Racing 3” lift
    There are some bolts where torque is critical - cylinder heads, rod bearings, etc.... Drain & fill plugs? Not so much.
    FLUID FILM IS A GREAT PRODUCT AND SHOULD BE APPLIED ANNUALLY IF YOU DRIVE ON SALTED ROADS IN THE WINTER.
    w8tdstrgecube likes this.
  2. Apr 4, 2024 at 4:49 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
  3. Apr 4, 2024 at 5:02 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Not that important. There's a single-use metal crush washer underneath. Tighten the plug until the washer is crushed (you'll feel a distinct increase in resistance), and it won't leak. In any case, worry about loosening the plug first.
    1. Have a replacement fill plug and crush washer on hand.
    2. Heat the perimeter of the plug with a propane torch until red.
    3. Try to knock it loose with hammer and sickle chisel.
    4. If 3. doesn't work, take it to a shop for them to weld a nut to it.
  4. Apr 4, 2024 at 5:15 PM
    w8tdstrgecube
    w8tdstrgecube Well-Known Member
    Brian
    Wisconsin
    2004 Gold Regular Cab 2.7L Manual 4x4
    Louder!!! For the kids in the back!
  5. Apr 16, 2024 at 8:46 AM
    2009Access4x4
    2009Access4x4 [OP] Well-Known Member
    Shane
    2009 Silver 4x4 access cab 6cyl
    I tried to hammer a hex socket in and I couldn't get it to turn. I had a shop try and they couldn't get the plug out. A third shop wanted $250 as a starting price to weld a nut on there. Who knows what they would have charged me in the end. The dealership wanted $250 to drill the plug out. I have called multiple shops and they can't weld a nut on there.
    I'm not sure what to do. Should I suck it up and pay the dealership? Is there an extractor tool that might work? I'm located in San Diego. Does anybody know a shop I could talk to? I don't have a torch. I think if I try and chisel it, I will make it worse.
