is this harbor freight spring compressor suicide?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by aficianado, Mar 8, 2010.
  1. Mar 8, 2010 at 3:25 PM
    aficianado
    aficianado [OP] Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    i need to get my OME lift installed and i'm exploring my options. is this crazy? anyone use this?
  2. Mar 8, 2010 at 3:26 PM
    AvsFanTRD
    AvsFanTRD Oh gravity, thou art a heartless bitch!
    Brandon
    Wyoming
    2008 TRD Off Road Black
    rear suspension TSB, sockmonkey bed decals, weathertech floor liners, TRD seat covers, tailgate pop n lock, rear diff breather relocation, center console lock, Viper Alarm, extra D-rings in bed, 5100's on all 4 corners
    Used that for installing some 5100s on someones taco. A little bit of a pain to use but they get the job done for cheap
  3. Mar 8, 2010 at 3:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Ive used it before. It works good. Much better than the other cheapo ones.
  4. Mar 8, 2010 at 3:29 PM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    Yea exactly...its probably the best DIY spring compressor you can get without dropping some serious cash.
  5. Mar 8, 2010 at 3:29 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    ive got one........gonna use it saturday.
  6. Mar 8, 2010 at 3:37 PM
    EL TACOROJO
    EL TACOROJO SNAPPIN NECKS AND CASHIN CHECKS.
    BURRY
    south mills NORCAK
    03 dblcab prerunner sr5 v6
    smoked taillights,smoked front turnsignals,smoked 3rd brake light,black badges,black roof rack,removed mud flaps,debadged, camburg 2.5 coilovers,camburg uca's, cobra 25 cb, 4ft firestick ant, dust light/bed lights , 4 hellas on the front
    Anything that is bought from said place is suicide . I bought numerous tools from them and they either broke or exploded
    Comatose likes this.
  7. Mar 8, 2010 at 3:39 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I've used a different type from autozone that has two threaded rods. You place one on each side of the spring. Then tighten each one independently to compress the spring. It takes a while and kind of a PIA. The one from Harbor Freight looks much easier to use. I'll probably go pick one up.
  8. Mar 8, 2010 at 3:44 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Never used this particular tool from said place but all other tools I have used from there have broken.
  9. Mar 8, 2010 at 3:48 PM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    another option is to take your springs/shocks off the truck and go to a local shop and have them swap your top plate over. Merchants tire only charged me 40 bucks to do both sides, so all i had to do was reassemble them back on the truck. MUCH easier than dealing with a spring compressor.
  10. Mar 8, 2010 at 3:49 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    mine looks/seems pretty well built actually.....except the main bolt, and i plan on getting a good grade 8 bolt to replace it if i can find one. i think tractor supply has them.
  11. Mar 8, 2010 at 5:12 PM
    aficianado
    back to bone stock.
    called my local shop..they wanted $200. hahahha. he actually said, taking the spring/shock out was the easy part, with the majority of the time and effort spent being at the spring compressor. i almost laughed at him.
  12. Mar 8, 2010 at 5:14 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    he was actually telling the truth. it takes more time to install new springs with a spring compressor....then it does to remove the shock/strut assy from the truck. the price is a joke tho.
    12TRDTacoma likes this.
  13. Mar 8, 2010 at 5:14 PM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    yea thats BS (the 200 dollars), they can do it in about 30 minutes for both sides...providing they have the commercial compressor that mounts to the wall.
  14. Mar 8, 2010 at 5:20 PM
    aficianado
    back to bone stock.
    you should see how fast prerunnerseth is. FAST.
  15. Mar 8, 2010 at 5:22 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    good deal.
  16. Mar 8, 2010 at 5:34 PM
    dmb
    dmb Well-Known Member
    Boise, ID
    I bought the exact same one to do my 5100's last weeked. I had a hard time using it and ended it up giving up after fighting with it for 30 minutes. I managed to get one side of the spring locked in the compressor......the other side wouldn't fit go in. Then I couldn't get it off! Had to take the whole dag thing apart. I called a friend and brought them to the shop. Hour 1/2 later and $50 bucks cheaper I had the springs on my new shocks. Good luck either way!
  17. Mar 8, 2010 at 5:37 PM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    Looks safer than the Autozone loaners I've used successfully a few times. I just keep spring perpendicular to my body and pointed in a safe direction. If it blows, it's less likely it's coming at me.
  18. Mar 8, 2010 at 5:58 PM
    Gunfan
    Gunfan Member
    09 DC TRD Off-Road
    I think these units from HF must vary. The one I had, the hooks on the arms were too big to fit between the coils of my TRD springs. Went to a local shop and 30 min. and $40 dollars later, they had my Eibach / Bilstein combo assembled.
  19. Mar 8, 2010 at 7:03 PM
    Timber
    Timber Crankey Old Yacht Jockey
    Tim
    San Pedro Bay Ports
    just a couple comfort items.
    I had the Harbor freight one with the two bolts and fingers and it exploded! I never saw the one the OP showed when I was looking. I ended up going to a garage around the corner and they had a nice floor mounted rig. Charged me $30.00 Well worth it.
  20. Mar 8, 2010 at 7:29 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    $30 or $40 is cheap 2 B safe. I rented one of those spring compressors once. I got the job done but it did slip B 4 I got the job done and I won't do it again.
