Is this hyper-flash?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tjswope, Apr 19, 2022.
  1. Apr 19, 2022 at 3:45 PM
    tjswope
    tjswope [OP] Well-Known Member
    Tom
    Chester County, PA
    2019 cement off road double cab MT
    A bunch of smalls
    On my way home from work today my left turn signal started flashing at twice it’s normal speed. Right turn signals and flashers are normal. I checked and all bulbs are good. I do have meso stage 1 tails and his mirror turn signals. Front turn signals are also LED. Any ideas about a cause or solution?
  2. Apr 19, 2022 at 3:52 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Sounds the resister in the meso tails went out...or wherever one was.
  3. Apr 19, 2022 at 3:53 PM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    Sounds like a resistance problem but no way to know without testing. I would start by contacting meso customs and explain the issue to him since it’s his product. I’ve heard his customer service is pretty good I’m sure he can give you some helpful suggestions and probably help you work it out.
  4. Apr 19, 2022 at 4:09 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Yes, that is hyperflash. As mentioned the load resistor either failed or has disconnected. Some resistance checks will confirm this. Compare each side of the Meso wiring.
  5. Apr 19, 2022 at 4:41 PM
    tjswope
    Tom
    Chester County, PA
    A bunch of smalls
    Update: I found the resistors that came with my total tails and added one to the left turn signal and all is good. It’s strange to me that it would pop up after more than two years on my truck. Thanks for the quick responses!
    Speedfreak likes this.
