Is this lift kit compatible with my truck?
Discussion in 'Suspension' started by THAM, Dec 10, 2012.
  1. Dec 10, 2012 at 4:02 PM
    THAM
    THAM [OP] Member
    '11 PreRunner 2WD
  2. Dec 10, 2012 at 4:04 PM
    THAM
    THAM [OP] Member
    '11 PreRunner 2WD
    Help!
  3. Dec 10, 2012 at 4:09 PM
    THAM
    THAM [OP] Member
    '11 PreRunner 2WD
    Please...
  4. Dec 10, 2012 at 4:10 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Yea, but if you have more money to spend I'd avoid a spacer lift and go with a suspension lift, or spindles since you're a Prerunner.
    Also, calm down, you only posted a few minutes ago. Patience is a virtue.;)
  5. Dec 10, 2012 at 4:12 PM
    THAM
    THAM [OP] Member
    '11 PreRunner 2WD
    Do you recommend any kits that aren't very expensive?
  6. Dec 10, 2012 at 4:12 PM
    Razgriz
    Razgriz wtf am i reading
    San Jose, CA
    03 Double Cab SR5 TRD
    Debadged. AFE Stage II intage. Magnaflow muffler. Mid travel. Blackrocks with BFG AT
    Yup. Most people here will say fuck spacers lifts. Save up and get the good stuff.
  7. Dec 10, 2012 at 4:13 PM
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
    5100s arent too expensive
  8. Dec 10, 2012 at 4:14 PM
    THAM
    THAM [OP] Member
    '11 PreRunner 2WD
    Are there any good kits for $500?
  9. Dec 10, 2012 at 4:15 PM
    Monster Coma
    Corey
    If you do 5100s yourself it would cost less than $500
  10. Dec 10, 2012 at 4:18 PM
    THAM
    THAM [OP] Member
    '11 PreRunner 2WD
    Is it possible to give me a link to what you would recommend?
  11. Dec 10, 2012 at 4:19 PM
    Monster Coma
    Corey
  12. Dec 10, 2012 at 4:22 PM
    THAM
    THAM [OP] Member
    '11 PreRunner 2WD
    Do I need a rear lift? 2 inch add a leafs?
  13. Dec 10, 2012 at 4:23 PM
    SR52012
    SR52012 Well-Known Member
    Port Richey (Tampa Area)
    2012 Taco Pre-Runner SR5 3" procomp lift
    3" Procomp lift level kit N-FAB step sides
    I have the pro comp 3" leveling kit... front coil spacer and 1" rear block... rides great! got if for like 250 on 4wheelparts.com
  14. Dec 10, 2012 at 4:26 PM
    Monster Coma
    Corey
    You don't need it unless you want the extra lift
  15. Dec 10, 2012 at 4:28 PM
    THAM
    THAM [OP] Member
    '11 PreRunner 2WD
    I want the extra lift haha
  16. Dec 10, 2012 at 4:29 PM
    Monster Coma
    Corey
    Then go with it, In all honesty tho a lift really depends on what you want it for. If you are going to off road with it, save and get the one that you want. If its just for looks then you are fine with anything mentioned
  17. Dec 10, 2012 at 4:30 PM
    THAM
    THAM [OP] Member
    '11 PreRunner 2WD
    It's just for looks, I just want a noticeable difference in height
  18. Dec 10, 2012 at 4:32 PM
    THAM
    THAM [OP] Member
    '11 PreRunner 2WD
    I don't need the rear shocks, correct?
  19. Dec 10, 2012 at 4:34 PM
    jtav2002
    Josh
    Reading, PA
    Nope, they provide no lift. They will just make it ride better.
  20. Dec 10, 2012 at 4:35 PM
    THAM
    THAM [OP] Member
    '11 PreRunner 2WD
    Ok, thanks that's what i thought.
