Is this my final answer
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MSU Taco, Oct 16, 2016.
  1. Oct 16, 2016 at 6:00 PM
    MSU Taco
    MSU Taco [OP] More cowbell
    Roger
    Mississippi
    05 DCLB 4x4
    Ok... I've been kicking it around a while and I'm finally about to place some orders on suspension parts. I have an 05 4.0 dclb. I already have front 5100 with OEM coils. My plan is to get a pair of 885 and set to 0. I guess my main question here is regarding the 885 v 885x. By now has the X completely replaced the old coil or do I need to specifically order an X.
    The rear is stock. My plan here is to go also with 5100 and a progressive AAL. It gets driven like 1 time a week and twice on a good week and about the only off road it will se will be deer hunting. Tires I'm relatively undecided on but I have OEM steel wheels and to cut costs I may just go with the 265/75. Did I miss anything or shoild that pretty well take care of me. I'm gonna get it aligned before I jump the gun and buy UCA.
    diabetiktaco likes this.
  2. Oct 16, 2016 at 6:03 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That all sounds great. 885x is the predominant one (I believe), so no you don't have to request it. I would order from headstrong offroad. Best prices and free shipping.
    MSU Taco[OP] likes this.
  3. Oct 16, 2016 at 6:08 PM
    MSU Taco
    Roger
    Mississippi
    05 DCLB 4x4
    I done some browsing there today. They were out of progressives when I looked. It'll be about 2 weeks before I place the order. Hopefully they will have some by then
  4. Oct 16, 2016 at 6:08 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    I have 887's on 5100's on my 2015 DCLB that way it is completely the spring doing the lift with no spacer on top for the full 3 inches
  5. Oct 16, 2016 at 6:11 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Get the ICON version it's exactly the same thing just a tad more money
  6. Oct 16, 2016 at 6:16 PM
    MSU Taco
    Roger
    Mississippi
    05 DCLB 4x4
    Trying to avoid UCA replacement if at all possible. Only spacer I plan on is the lean spacer. I had seriously considered the 887 otherwise. Although I have read testimonies of people running that coil without needing them and getting good alignment numbers. What's your stance on that?
  7. Oct 16, 2016 at 6:19 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Only stance I have on that is every truck seems to be different when it comes to aftermarket UCA's
    MSU Taco[QUOTED][OP] likes this.
  8. Oct 16, 2016 at 6:23 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    UCAs never hurt and if you are anywhere near 3" I'd opt for them.
  9. Oct 16, 2016 at 6:24 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    If you're trying to avoid UCAs, go 885s. The full 3" would be great, but does it really make a difference? Not to most since the added cost of UCAs is pretty high. Here's mine on 885s and an AAL with stock UCAs
  10. Oct 16, 2016 at 6:29 PM
    MSU Taco
    Roger
    Mississippi
    05 DCLB 4x4
    Looks good. What tire you running
  11. Oct 16, 2016 at 6:30 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    285/75r16 Cooper MTPs. Love em, but damn they're noisy.
  12. Oct 16, 2016 at 6:37 PM
    MSU Taco
    Roger
    Mississippi
    05 DCLB 4x4
    I'm eyeballing the toyo RT. Sadly it doesn't come in a 285 yet
  13. Oct 16, 2016 at 6:40 PM
    Pigpen
    Dan
    Northwest Montana
    255 > 285 in every way IMO
  14. Oct 16, 2016 at 7:24 PM
    MSU Taco
    Roger
    Mississippi
    05 DCLB 4x4
    So the 255 is pretty solid in mud despite the width?
  15. Oct 16, 2016 at 7:25 PM
    Pigpen
    Dan
    Northwest Montana
    I have zero rubbing and these bastards float like snow machines in deep snow.
  16. Oct 16, 2016 at 7:28 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    IMO the wider stance looks better. There's pros and cons to each, just depends on the person.
  17. Oct 16, 2016 at 7:31 PM
    Pigpen
    Dan
    Northwest Montana
    They do look good. There's no real performance benefit though.
  18. Oct 16, 2016 at 7:34 PM
    PPansini10
    PPansini10 Well-Known Member
    Paul
    NJ
    09' DCSB 4x4 TRD Sport
    Theres plenty of performance benefit from having a wider tire? Just like there is some performance benefits to having a skinnier tire. It all comes down to what the user needs the tire for
    EatSleepTacos likes this.
  19. Oct 16, 2016 at 7:37 PM
    Pigpen
    Dan
    Northwest Montana
    80% of increased footprint from airing down comes from diameter, 20% from width. my 255s are 33.4", the average 285/75/16 is 32.5".
    :deadhorse:
  20. Oct 16, 2016 at 7:40 PM
    PPansini10
    Paul
    NJ
    So what happens when a 285 airs down? or a 315 airs down? Does the footprint still only equal 32.5" or does it get wider like every other tire ?
