Is this my final answer
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MSU Taco, Oct 16, 2016.
  1. Oct 16, 2016 at 7:43 PM
    Pigpen
    Dan
    Northwest Montana
    still 80/20
    A taller tire increases footprint more drastically than a wider tire. Of course, if they're the same height...a wider tire will gain more footprint.
