Is this normal 4x4 operation?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EJS, Oct 1, 2010.
  1. Oct 1, 2010 at 4:15 AM
    EJS
    EJS [OP] Member
    NJ
    2005 SR5 4x4
    I just bought a 2005 Tacoma, Auto Trans, 4x4, tow package, with 60K miles. When I switch into 4x4 Hi the light blinks but does not engage if the vehicle is moving. It switches fine if the truck is stopped or coasting, but not when there is any speed, i.e. 30 mph. I thought these were supposed to be able to switch to 4x4 Hi while at speed. This is my first Tacoma so I don't know if this is normal, or if I just bought a huge headache. Any input would be helpful, Thanks.
  2. Oct 1, 2010 at 4:23 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Yeah thats pretty normal. Mine won't switch into it if there is load on the drivetrain but if I let off the gas and coast it will switch on.
  3. Oct 1, 2010 at 4:24 AM
    Brunes
    Brunes abides.
    Rotorhead
    I would not want to try to make that switch at speed with the engine loaded...There isn't really a reason. It says you can do it up the 60 mph...but that if it does not work to slow down and do it again.
    If it engages at slower speeds...I wouldn't worry.
  4. Oct 1, 2010 at 5:15 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    Yup, they are finicky...try slowing down, coasting, braking, speeding up, turning, etc.
  5. Oct 1, 2010 at 8:12 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    X2
  6. Oct 1, 2010 at 9:18 AM
    EJS
    EJS [OP] Member
    NJ
    2005 SR5 4x4
    Thanks for the info, I feel better now. Also, since it is at 60K miles I would like to get the recommended services done. I don't have a service manual, can anyone tell me what maintenance is recommeded? I'm trying to take care of this one, and have the truck last longer than the length of the loan (never been able to do that before).
  7. Oct 1, 2010 at 9:26 AM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    http://www.tacomaworld.com/forum/te...nance-2nd-gen-30-000-60-000-90-000-miles.html
  8. Oct 1, 2010 at 10:49 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Mine has always popped into 4WD while driving... Naturally, I only engage when I need it, not just for giggles on the freeway! I would say I have popped it in at 50 mph when the pavement ended and I wanted maximum control.
  9. Oct 1, 2010 at 11:01 AM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    it'll do the same for 4lo, will beep and sound like it's going to explode until it finally engages
  10. Oct 1, 2010 at 12:24 PM
    45longcolt
    45longcolt Well-Known Member
    DFW Area
    08, Double cab, 4WD, Off Road, Tow,
    I have switched mine in and out going 50-60 MPH no problems. Had it for almost 3 years now, an 08. Only on icy roads though, I do let off the gas and it switches in and out just fine.
  11. Oct 1, 2010 at 12:26 PM
    Bryan07sport
    Bryan07sport Well-Known Member
    Bryan
    Newark, Delaware
    07 TRD Sport Access 6spd
    Hardwire GPS, 110v power outlet in cab, foglights anytime, mudflaps removed, pa-15 ipod interface, rear leaf tsb, URD short shift, integrated third brake/cargo light, ABS disable switch, BHLM, Dynomax super turbo muffler, Nitto Terra Grapplers 265/70/17, Front Bilstein 5100's at 1.75, Weathertech floormats, sockmonkey bedsides, bestop supertop, spidertrax
    what she said
  12. Oct 1, 2010 at 3:57 PM
    David K
    Because he's new... make sure we give complete answers... Like to go into L4 (LOW RANGE), you must STOP moving first, put the tranny into NEUTRAL (not PARK), then rotate the dial while pushing it in, from H4 to L4. If he gets the beep or the indicator blinks, he is not in L4.
  13. Oct 1, 2010 at 5:39 PM
    EJS
    EJS [OP] Member
    NJ
    2005 SR5 4x4
    I appreciate all the insight, and yes I'm new...to the forum, not new to how trucks work :D
  14. Oct 1, 2010 at 5:43 PM
    David K
    Umm okay... but these are your words from above:
    "I thought these were supposed to be able to switch to 4x4 Hi while at speed. This is my first Tacoma so I don't know if this is normal, or if I just bought a huge headache. Any input would be helpful, Thanks."
    What we want to do is advise you correctly... and be friends!:rolleyes:;)
  15. Oct 1, 2010 at 5:49 PM
    EJS
    EJS [OP] Member
    NJ
    2005 SR5 4x4
    True, it has been a while since I have used a truck. I must admit the last truck I had to get out in the mud and lock the hubs manually.
  16. Oct 1, 2010 at 8:14 PM
    larryde09
    larryde09 Well-Known Member
    Larry
    Rochester, NY
    (Traded-in) 06 2.7L 5-spd SR5 4x4
    K&N Intake, Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars/sliders/running boards, DIY Bed Lights, DIY Running Board/Ground Lights, DIY Tailgate Electrical Box (12V socket, voltage and current gauges), DIY Internal Lighting (coming soon), Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    Same here...no problems switching in and out at up to 60 mph, but you might have to coast, speed up, or whatever to get it to lock in faster. It's so that the mechanisms can all mesh together without a torque differential on any of the shafts.
