Is this normal for ball joints?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SpaceMonkey, Jul 8, 2010.
  1. Jul 8, 2010 at 7:45 PM
    SpaceMonkey
    SpaceMonkey [OP] Well-Known Member
    Houston, Tx
    06 PreRunner
    I've been hearing a metal popping sound when I drive up my drive way or when I reverse and turn. Can't really find the source but looking under the truck today, I observed these differences in the ball-joints. Is this normal for them to be different?
    Driver side (notice the space above the LCA):
    Passenger side (no space):
  2. Jul 8, 2010 at 7:48 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    looks like the ball joint has come out,or is there a ring or spacer under the joint itself
  3. Jul 8, 2010 at 7:53 PM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    It looks like both sides are the same. The fist picture you are just seeing the open space between the ends of the snap ring and in the second picture we are looking at the back of the snap ring
  4. Jul 8, 2010 at 7:55 PM
    david7268
    david7268 Well-Known Member
    Tucson, AZ
    2012 DCLB 4x4 TRDSport
    NONE.....yet!
    That space looks like a C-Clip. That is normal for those.........someone correct me if I'm wrong.
  5. Jul 8, 2010 at 7:55 PM
    Boilerman
    Boilerman Well-Known Member
    Brian
    Texas, northwest of the Big Pond
    2010 Prerunner SR5 Magnetic Gray 2.7L
    Yep what he said^^^^
  6. Jul 8, 2010 at 7:57 PM
    SpaceMonkey
    Houston, Tx
    06 PreRunner
    Hmmm...I see. Could the snap ring be worn down on the driver side so there is more play than normal? Thanks for the feedback.
  7. Jul 8, 2010 at 8:02 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    whats all that juice on them
  8. Jul 8, 2010 at 8:03 PM
    SpaceMonkey
    Houston, Tx
    06 PreRunner
    I sprayed some teflon lubricant on them. I'm trying to isolate annoying sound from around my suspension area.
  9. Jul 8, 2010 at 8:10 PM
    cummins6speed
    On an 06, highly unlikely. Those snap rings won't wear much if at all
  10. Jul 8, 2010 at 8:11 PM
    cummins6speed
    If its an issue when turning I would take a look at your steering joints
  11. Jul 8, 2010 at 9:27 PM
    JKD
    JKD Well-Known Member
    No zerks on the joints?
  12. Jul 8, 2010 at 10:10 PM
    SilverStreak05
    SilverStreak05 Well-Known Member
    NorCal
    2005 4x4 TRD Off-Road
    DR coilovers, DR rear reservoir shocks, Deaver custom 11 pack leaf springs
    Clicking while turning is usually a bad CV joint
  13. Jul 9, 2010 at 6:25 AM
    cummins6speed
    He doesn't have those
  14. Jul 9, 2010 at 6:29 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    do you have coilovers or are you stock?
  15. Jul 9, 2010 at 6:59 AM
    jmed99
    jmed99 Well-Known Member
    SC
    09 DC PreRunner TRD OR
    X2?
  16. Jul 9, 2010 at 7:02 AM
    chadabear
    chadabear God fearing turkey hunter
    Chad
    Louisiana
    2018 DCSB 4x4
    Mine pops when I back up and go forward, only after I installed the three inch lift spacer on front. I asumed it was the spring shifting back and forward when I was moving trying to settle. jmo
  17. Jul 9, 2010 at 7:10 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    FWIW, I had a horrible popping sound when turning..Sounded like metal on metal. Turned out to be a rock stuck in the coil spring, near the spring perch.
  18. Jul 9, 2010 at 7:20 AM
    Magnetic
    Magnetic Active Member
    Baton Rouge, La
    09 TRD-Off Road, locker mod
    I had the same problem. I brought it in for warranty service, and they said nothing was wrong. I left and it was doing it again. I was angry and raised hell. They took it in again and removed a rock between the body and the frame. I felt like a dumbass.
  19. Jul 9, 2010 at 8:16 AM
    SpaceMonkey
    Houston, Tx
    06 PreRunner
    ^ Interesting comments on finding rocks. I'll check. I have bilstein 5100 shocks set at 1.75" with OEM springs. Sound is coming from the driver side.
  20. Jul 9, 2010 at 7:24 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Check your sway bar bushings and end links.
