Is this normal while in 4x4?
Discussion in 'Performance and Tuning' started by Rucas, Dec 6, 2009.
  1. Dec 6, 2009 at 5:37 PM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    Just wondering, this is my first 4x4 vehicle.....
    So in a few weeks im heading up to the snow, and just wanted to check the 4 wheel drive to make sure its working (since I bought from an owner and not a dealership).
    So while stopped I turned it into 4x4, heard it click in, so I started driving around. Nothing fast just around my street. But what felt strange was when I slowed down and turned (kinda sharp) the truck felt like it went into a low low gear, and a little harder to turn.
    Idk... am I a noob?
  2. Dec 6, 2009 at 5:40 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    What He said ^^^^ No 4x4 on street.
  3. Dec 6, 2009 at 5:42 PM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    ahhhh alrighty. I was just making sure it was working. I didnt want to get up to the snow and find that my 4x4 didnt work.
    But I doubt ill use it, im going to get some sand bags to keep her planted.
  4. Dec 6, 2009 at 5:43 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    To answer your question- You are a newb. That is driveline resistance.
    Forcing something that doesn't feel right to you in the drivers seat means you were on the verge of breaking shit....Wouldn't ever try that again....if you want your driveline to continue to work at least...
  5. Dec 6, 2009 at 5:43 PM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    Is it bad to?
  6. Dec 6, 2009 at 5:45 PM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    thank you for pointing out my noobness.
    I stopped right away because it didnt feel right.
  7. Dec 6, 2009 at 5:47 PM
    tisher49
    tisher49 Well-Known Member
    Alex
    Orange, Virginia
    '08 4.0L 4x4
    K&N Air Filter, Westin Bull Bar with PIAA fog lights, Retrax cover, Alpine Head unit with I-Pod interface, maglite mount, Color matched grill surround w/ Grillcraft mesh
    I'm new to the site as well but have never driven anything besides a 4x4 vehicle. I've experienced this in all of them (2 jeeps and my current taco) and have asked other 4x4 owners and they said its normal. The best way I can explain it is that since you are in 4WD power is being delivered to all 4 tires. Any time you are turning you can essentially imagine you are making a circle and since the outside wheels are further away from the center of this imaginary circle, even tho the tires are being fed the same power, there is a small difference in the rotations of the tires so it is harder to turn. At higher speeds this difference is negligible thus less noticeable. May not be the accurate wording but thats the idea behind it as it was explained to me. Thats why they tell you not to use 4x4 without snow.
  8. Dec 6, 2009 at 5:47 PM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    por que?
  9. Dec 6, 2009 at 5:48 PM
    AlexForbesR6
    AlexForbesR6 My R6 Eats Me
    Alex
    Houston, TX
    07 4x4 6-Spd
    ^^^what they all said..haha
    4x4 is not the same as AWD and is not meant for driving on the road due to the fact that the wheels need to go diff speeds when turning and in 4x4's they cannot do this which can cause serious break downs..
  10. Dec 6, 2009 at 5:48 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    All in good fun bro- We all learned the same stuff....Many of us in the same way!!!
  11. Dec 6, 2009 at 5:49 PM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    :eek:
    ohhhhh, beatuifully done. i get it now.
  12. Dec 6, 2009 at 5:50 PM
    AlexForbesR6
    Alex
    Houston, TX
    07 4x4 6-Spd
    thats right in what you say about diff speeds but wrong in the fact that at higher speeds it is less noticeable.. the higher the speed the more stress you will put on the front wheel drive parts
    NEVER put in in 4x4 at high speeds on the road!!!!
    you could do some SERIOUS damage..i.e. destroy your front diff, snap an cv axle etc...
  13. Dec 6, 2009 at 5:53 PM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
  14. Dec 6, 2009 at 5:57 PM
    tisher49
    Alex
    Orange, Virginia
    '08 4.0L 4x4
    yeah i spoke too soon...now that you said that i realize the only time i had my truck in 4x4 going fast was in the snow...
  15. Dec 12, 2009 at 8:16 PM
    LFH
    LFH Active Member
    Spring, Texas
    2001 Tacoma 4x4
    I haven't a clue, so will say none.
    What you described tells me it is working as it should.
    What people are saying, is don't drive it in 4x4 on DRY concrete, at least at any kind of speed.
    If you are in snow or wet pavement and you go to slipping or sliding by all means slip it in to 4HI.
    Be safe, use it when you have to.
    Just my two centavos worth...
  16. Dec 12, 2009 at 8:21 PM
    ROADHOG
    ROADHOG Well-Known Member
    Valley of the sun
    2010 Dbl cab 4x4 TRD Offroad fully loaded
    Big block Chevy engine(just kidding)
    I was told by my dealer that once a month I need to put it in 4 high and drive it for a few miles to keep everything lubricated and in check.This to me means pavement so I do it.It won't hurt a thing and is mandatory according to my dealer.
  17. Dec 12, 2009 at 8:22 PM
    Danosabre
    Danosabre Well-Known Member
    Dan
    Gardner,Ma
    09 TRD Off Road
    Extang Trifold bed cover,DDM 55W 6000k HID, maglight, Vent visors
    I have an 09 and in the owners manual it says to drive it for 10 miles every month in 4 wheel drive, just to keep all the parts moving and lubed.
    But then who reads the fuggin manual:eek:
  18. Dec 12, 2009 at 9:22 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    4x4 on dry pavement is a bad idea because it can cause you to flip. it binds when you turn because the rear wheels want to push you straight while the front are trying to pull you to the side. You can also feel the inside tire hop and push forward. It shouldnt break anything. It will tear up tires bad though. The reason it is unsafe is if you turn while driving normal speeds the tires will pull the front of the vehicle to the side which can cause a vehicle to flip.
    Im not saying its fine for the drive train because it will cause parts to wear extremely fast. Im saying that it shouldnt snap a cv or destroy the diff. instantly.
  19. Dec 12, 2009 at 9:31 PM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    4x4 in the street is muy Bueno in Western New York in the winter time.
  20. Dec 12, 2009 at 9:36 PM
    ROADHOG
    Valley of the sun
    I do/did from front to back.My 2010 Tacoma is a hefty investment,atleast to me and I want her to last for a very long time.
