Is this normal
Discussion in 'Performance and Tuning' started by Rwood, Aug 27, 2013.
  1. Aug 27, 2013 at 7:45 PM
    Rwood
    Rwood [OP] Well-Known Member
    Raymond
    WNC
    15 TRD Off-road
    I have an 05 SR5 and when it is running the is some water that comes out of the exhaust pipe and I was wondering if that was normal or not and if someone can tell me what it is caused by.
  2. Aug 27, 2013 at 7:47 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    Normal in the correct weather/environmental conditions. Does it do it all the time or just on occasion?
  3. Aug 27, 2013 at 7:47 PM
    TailDrag
    TailDrag Well-Known Member
    Yes it's normal. It is condensation from your muffler.
  4. Aug 27, 2013 at 7:47 PM
    User Name01
    Bolbi Stroganovsky
    Usually in the early morning, when yiu first fire it up, is when it happens
  5. Aug 27, 2013 at 8:01 PM
    Rwood
    Raymond
    WNC
    15 TRD Off-road
    Ok thanks a lot I have been wondering. You all helped a lot thanks
  6. Aug 28, 2013 at 5:22 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Water is the byproduct of all combustion. its just some chemistry coming out of if truck.
  7. Aug 28, 2013 at 5:29 AM
    BRUCEB
    BRUCEB Well-Known Member
    CENTRAL MISSOURI
    2012 CREW CAB TRD
    Iwas told by a GM rep a long time ago,that for every gallon of gas you burn,you make a gallon of water.Sounded a little "high" to me,but that's what he said.So, a little water is normal.
  8. Aug 28, 2013 at 6:34 AM
    yota243
    E.J.
    north Alabama
    2C18H+25O2->16CO2+18O2. 1 GAL PER GAL SEEMS ABOUT RIGHT.
  9. Aug 28, 2013 at 8:56 AM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    That's why they call it hydrocarbons. ;)
  10. Aug 28, 2013 at 9:17 AM
    yota243
    E.J.
    north Alabama
    Theres pot in them?
  11. Mar 25, 2014 at 4:02 AM
    Doug001
    Doug001 Member
    Georgia
    05 Tacoma PreRunner
    always heard it means your mtr is running good!
