Is this our LED headlight solution from Phillips?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MannyS, Oct 6, 2015.
  1. Oct 6, 2015 at 7:59 PM
    MannyS
    MannyS [OP] Well-Known Member
    Republic of Texas
  2. Oct 6, 2015 at 8:04 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Mmmmaybe.
  3. Oct 6, 2015 at 8:21 PM
    MannyS
    Republic of Texas
  4. Oct 6, 2015 at 8:36 PM
    M1911
    M1911 Well-Known Member
    For those of us who live where it snows, the cooler temperature of LEDs is a drawback -- it won't melt snow on the light in the winter. So in a snowstorm, you'll have to keep stopping and wipe the snow off your lights.
  5. Oct 6, 2015 at 9:31 PM
    rysingsun
    rysingsun Well-Known Member
    2016 Quicksand Tacoma DCSB TRD OR
    Being from Vegas, it's obvious we don't have this as an issue. And so I've never considered the physical temperature of headlights to play a role in safe driving. Fascinating!
  6. Oct 6, 2015 at 9:38 PM
    M1911
    It is an issue here where it snows. It is even a problem for traffic lights. The town that I live in has replaced the bulbs in some traffic lights with LEDs, due to the fact that they last longer and use less energy than incandescent bulbs. But when we have a blowing snowstorm, snow builds up in the traffic light, making it impossible to see. Then the highway department has to go out with a cherry picker and send a guy up to clean the snow off the traffic light (likely eliminating any savings). That isn't a problem with traffic lights that have incandescent bulbs -- the heat from the bulbs simply melts the snow that builds up in front of the lens.
    Justus likes this.
  7. Oct 6, 2015 at 10:10 PM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    9 watts? 9 WATTS???
    If these ever get near overheating they are trash. No LED that size should overheat at 9 watts.
  8. Oct 6, 2015 at 10:15 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    that's comical about the money saving thing.... Oopsie
  9. Oct 7, 2015 at 12:30 PM
    MannyS
    Republic of Texas
    Response from vendor about using Phillips H11 LEDs for headlights:
    They are designed for fog light use only. I would not recommend those in a low beam headlight. I would suggest going with our XenonDepot H11 LED headlight kit instead. It will be brighter and function properly in a headlight.
  10. Oct 7, 2015 at 12:44 PM
    atrouth
    atrouth Well-Known Member
    Anthony
    2016 MGM Tacoma TRD Sport DCLB 4x4
    With the new projector lens I doubt even the heat from the halogen bulb will transfer to the exterior of the headlight housing in order to melt off any snow accumulation. Best bet might be in that case to keep halogens in the high beams if you need to generate heat to melt the snow off the front. Just my two cents
  11. Dec 14, 2015 at 7:48 PM
    Blazingbluesport
    Blazingbluesport Well-Known Member
    The OC!
    2016 TRD Sport 4x4 double cab.
    I pulled the trigger and bought the headlight kit and fog lights. Xmas present for my truck. I'll update when I get them
