is this possible???
Discussion in '1st Gen. Tacomas (1995-2004)' started by cole47, May 21, 2009.
  1. May 21, 2009 at 12:05 PM
    cole47
    cole47 [OP] Well-Known Member
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    ive been reading into this and asking around about doing this for a while, ive been wanting to see how much or even if it is possible to convert my 04 DC into a 5 speed manual???? i know that it will take some work but thats fine by me. i just want to see if it IS in fact possible and about how much it will cost???
  2. May 21, 2009 at 12:09 PM
    AzPrerunner05
    AzPrerunner05 Desert Rat
    Tucson
    2005 V-6 SR5 PreRunner Debadged
    De Badged, Flowmaster 50 Muffler & Dual Out Exhaust. K & N High Flow Filter. SP Racing Slotted Rotors
    :popcorn:Got me interested....
  3. May 21, 2009 at 12:13 PM
    98tacoma27
    Ben
    Not Beech Creek
    Yes it is. It will cost more time and money than what it is worth.
    You will need
    1. Complete manual trans (clutch plate, pressure plate etc.)
    2. ECU from a standard vehicle with same options
    3. Pedal assembly (all the mounting hardware)
    4. Clutch cylinder
    5. Clutch fluid reservior
    6. Possible new tranny mount
    7. A new wiring harness ( I believe)
    8. A new instrument panel (for tach-probably not necessary but recommended)
    9. You may need a new drive shaft due to length (not 100% sure of this)
    There may be more also. There are fitment issues to analyze. Hole locations......
  4. May 21, 2009 at 12:14 PM
    AzPrerunner05
    Tucson
  5. May 21, 2009 at 12:15 PM
    eordonez
    eordonez Living vicariously through mjp2
    Ed
    Chihuahua, Mexico
    TRD Sport Dcab 4x2 Black Sand Pearl
    OEM All Weather Mats, wheel locks, Toyota Silver Tube steps.....
    Sounds like he would be better off with a trade-in
  6. May 21, 2009 at 12:16 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    People claim you will need a new ecu and wiring harness, but that is false. You can make it work without one. Also, you will need a new driveshaft.
    This is A LOT of work, and i contemplated it, but decided against it and went with a built IPT transmission.
  7. May 21, 2009 at 12:16 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah for sure or just wait until you get a new Taco!
  8. May 21, 2009 at 12:16 PM
    98tacoma27
    Ben
    Not Beech Creek
    Yes, by the time you are done, it would cost more than to have just purchased it with the manual tranny.
  9. May 21, 2009 at 12:16 PM
    cole47
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    think its gonna be over 2k???
  10. May 21, 2009 at 12:17 PM
    98tacoma27
    Ben
    Not Beech Creek
    Oh hell yeah. Unless everything comes out of the junkyard.
  11. May 21, 2009 at 12:17 PM
    cole47
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    i dont think they makee a first gen DC in straight drive??
  12. May 21, 2009 at 12:19 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    And you do all the custom work yourself. Can you weld and fabricate?
  13. May 21, 2009 at 12:19 PM
    cole47
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    yeah i just got my welding license last week lol im looking for a new project
  14. May 21, 2009 at 12:21 PM
    dually
    dually Low and slow
    Is this your DD?
  15. May 21, 2009 at 12:21 PM
    98tacoma27
    Ben
    Not Beech Creek
  16. May 21, 2009 at 12:22 PM
    98tacoma27
    Ben
    Not Beech Creek
    You will need a new ECU if you don't want the CEL lit up 24/7
  17. May 21, 2009 at 12:23 PM
    cole47
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    not rele i have a accord (gas saver)
  18. May 21, 2009 at 12:25 PM
    98tacoma27
    Ben
    Not Beech Creek
  19. May 21, 2009 at 12:32 PM
    dually
    dually Low and slow
    The only electrical wiring going to the manual trans is the speed sensor, and that can be wired into the existing harness. The truck will drive regardless of whether there is a speed sensor or not.
  20. May 21, 2009 at 12:35 PM
    98tacoma27
    Ben
    Not Beech Creek
    I never said it wouldn't drive.
