Is this shop taking advantage of me?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 215Grappler, Mar 29, 2021.
  1. Mar 29, 2021 at 3:01 PM
    215Grappler
    215Grappler [OP] Member
    2020 Tacoma Off-road
    I have a 2020 Tacoma Off Road with 285/75/16s and a 3" spacer lift in the front and a 2" lift in the rear. Other than that it's completely stock. The truck is my daily driver and I do some light off-roading. I reached out to a local shop and told them this and they got back to me the following recommendation:
    Toytec Boss 2.5 Aluma Series Performance Suspension System 2"-3" Lift
    Front Diff Drop
    Front Durobumps
    Rear Leaf Spring Complete
    Rear Durobumps
    SPC Adjustable Arms
    The cost for everything listed above is $3,568, labor is $720, and alignment is $159. Total cost before tax is $4,447. I was hoping to spend a lot less as I was looking at the Eibach Pro-Truck Coilover Stage 2 (front coilovers + rear shocks), which lists for about $1,000. Are all of the components listed in the above quote necessary for my needs? I replied to the shop and told them I was looking at the Stage 2 and his reply was "that kit is not comparing apples to apples. The Eibach kit comes with no diff drop no swaybar brackets, no bump stops and nothing for the rear other than shocks. I think you would be making a big mistake just purchasing those parts and nothing else to go with it. The upper arms alone are 700 bucks."
    I have no idea if he's on point or taking me for a ride, which is why I'm asking here. Appreciate your comments and advice in advance.
    NOTE: this post edited to remove reference to fire roads and beach since I’ll be doing more than that.
  2. Mar 29, 2021 at 3:08 PM
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    Just that lift is 3k alone so the other 1500 is labor and alignment. Seems OKAY pricing but that alignment is super expensive. youre getting full coil overs and all that
    215Grappler[OP] likes this.
  3. Mar 29, 2021 at 3:09 PM
    GlitterGulch
    GlitterGulch Freedom Machine
    Tyler
    San Marcos
    2015 DCSB / 93 Pickup race truck (sold)
    Beef Supreme
    Take the spacers out and back to stock and drive the truck everywhere you want. No need for anything that shop says for fire roads and beach.
    MJTH, tortoise_taco, whatstcp and 2 others like this.
  4. Mar 29, 2021 at 3:11 PM
    Fish.Taco.Ma
    Fish.Taco.Ma IG: @fish.taco.ma
    Dean
    2017 Silver Sky Tacoma TRD Offroad
    If your truck already has a spacer lift, what is the goal of your new lift? Better ride comfort? If that is the case its going to be hard to get a "budget friendly" 3/2 lift that also increases your ride comfort.
    tcjacado and 215Grappler[OP] like this.
  5. Mar 29, 2021 at 3:12 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    It's all about that look and stance, bro :jerkoff:
    Kev250R, MadKatt, T-yoda and 4 others like this.
  6. Mar 29, 2021 at 3:16 PM
    215Grappler
    There always has to be a douchebag in the crowd.
    cosmic65charlie and Hugh Jashole like this.
  7. Mar 29, 2021 at 3:18 PM
    215Grappler
    Yep, looking for better ride comfort. However my current ride isn’t that bad to justify spending almost $5k.
  8. Mar 29, 2021 at 3:20 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Hey we don't use the D word around here. :eek:
    FishnTx and tcjacado like this.
  9. Mar 29, 2021 at 3:24 PM
    215Grappler
    I removed the reference to fire roads and beach since I’ll be doing more than that. But still nothing too extreme.
  10. Mar 29, 2021 at 3:25 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    So as priced on Toytec what they quoted you was fair but you can find better shocks and components for less. You don't really need a diff drop kit, nor do you need duro bumps. OEM replacement kits are designed to operate within factory geometry so will work with factory components.
    All you really need is:
    Front Coilovers or Struts
    Rear Shocks
    AAL, Pack or Block
    Optional:
    UCA - Helps with alignments for larger tires and increased droop for extended travel shocks
    Ubolt Flip - Increased under axle ground clearence
    CB Drop - Drops the carrier bearing to reduce potential driveline vibrations
    ECGS Bushing - Replaces Driveside needle bearing that often fails when lifted
    Swaybar Drop - lowers swaybar for mounting
  11. Mar 29, 2021 at 3:26 PM
    tcjacado
    tcjacado Well-Known Member
    What are you looking to do.... nobody can foresee what your butt dyno sees.
    Maybe you need kings and a custom leaf pack, maybe you just need bilstein 5100's in all 4 corners and a add a leaf
    :notsure:
    Kev250R, hiPSI, JoeCOVA and 3 others like this.
  12. Mar 29, 2021 at 3:28 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    wow...that's a lot of dough. I just replaced my shocks.
  13. Mar 29, 2021 at 3:30 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    sounds fair to me.
  14. Mar 29, 2021 at 3:51 PM
    tacoman45
    tacoman45 Well-Known Member
    Orygun
    2014 TRD OR DCSB - MGM
    In line with what I've been quoted for similar work.
    With that said, you will save alot of that by doing it yourself - it's not hard. Hell, I bet some folks from here would even help you out for a few beers
    phocas likes this.
  15. Mar 29, 2021 at 4:07 PM
    SweatyBiscuit
    SweatyBiscuit Well-Known Member
    Paul
    Northern AZ
    2016 Taco TRD OR
    Katzkin leather, heated seats, Popnloc, bed lights, remote start, bhlm....
    Doesn’t seem like they are far off from what I would expect. You may be able to save a bit. I wouldn’t do the diff drop. The Duro bumps are also optional (I have them front and rear). I would strongly consider swapping the needle bearing on the driver side of the front differential to the ecgs bushing.
    Superdave1.0 likes this.
  16. Mar 29, 2021 at 4:10 PM
    Superdave1.0
    SoCal
    This.
    And this too.
  17. Mar 29, 2021 at 4:21 PM
    RatDaddy
    RatDaddy Well-Known Member
    Roy
    2017 Tacoma TRD O/R Premium pkg
    None
    pricing seems fair, but you have to wonder if you need it or if the lift you have is enough for your use. I have done spacer lifts in the past just to get clearance to go on fairly simple off road treks. Truth is you really don't need all that much for simple off roading. And trucks look so much better than stock even with a simple spacer lift.
  18. Mar 29, 2021 at 4:24 PM
    RatDaddy
    Roy
    None
    I think you misunderstood him or maybe I did. Telling someone to go back to lower stock height is like saying don't get those nice aftermarket wheels and goodies that make your truck look so much better. Lifts are partially about looks and in many cases all about looks. The question was never about going back to stock, so why introduce a non option as an option. that seems more douchy to me
  19. Mar 29, 2021 at 5:11 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    This :thumbsup:
  20. Mar 30, 2021 at 6:00 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    We always had a saying at our company...''everyone wants to go to heaven by no one wants to to die first.''
