Is this switch supposed to have a gasket?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by F75gunslinger, Sep 17, 2021.
  1. Sep 17, 2021 at 6:11 PM
    F75gunslinger
    F75gunslinger [OP] Ka like a wheel
    Christian
    Rochester,NY
    SWB '10 Doublecab TRD Sport 4x4
    Cluster and Radio LED swap,Westin bull bar,2nd set of bed tie downs,URD SS,K&N filter,weathertechs
    I have a 2010 Tacoma sport quad cab, 4x4,V6 with a manual transmission. My reverse lights only work when they want to, so I'm going to order a new switch as both the camera and backup lights work fine when it works, but neither one works when it doesn't . My question is, is that switch supposed to have a gasket similar to the oil drain plug ? Or at least some type of gasket? And do they usually come with one?
  2. Sep 17, 2021 at 6:25 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    IIRC the threads have a sealant applied from factory but it's been a few years since I replaced a reverse light switch.
    I want to say I put a thin crush washer gasket on mine as I didn't see one and figured it should have one but the 1/16" was enough spacing away from the actuation rod that the switch wouldn't engage.
    Just pull the old one out and install the new one in the same configuration as to how the old one came out.
    For what it's worth if it still works sometimes it's probably not the reverse position switch you may just need to disconnect and clean all the contacts in the plugs of the system, pack them with dielectric grease after you do to help displace any water or sediment that gets past the plug seal.
    PzTank likes this.
  3. Sep 17, 2021 at 6:30 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  4. Sep 17, 2021 at 7:54 PM
    NateInAZ
    NateInAZ Well-Known Member
    NateInAZ
    85224
    2008 Tacoma TRD Offroad White
    Bilstein 5100 2" front, 2.5" AAL in rear. LT255/85r16
    TnShooter likes this.
  5. Sep 18, 2021 at 11:11 PM
    F75gunslinger
    Christian
    Rochester,NY
    Nice...thanks guys !
  6. Sep 19, 2021 at 11:04 PM
    F75gunslinger
    Christian
    Rochester,NY
    I have another question....when you pull the switch out, will it let the fluid out as well ? Or is the switch above the normal fluid level?
  7. Sep 19, 2021 at 11:25 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Can't say for sure, but I am fairly certain it is above the manual tranny oil level.
  8. Sep 20, 2021 at 12:04 AM
    TnShooter
    Deogee
    STOCK
    Jimmyh likes this.
  9. Sep 20, 2021 at 12:17 AM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    It is above the fluid level. At least mine was. If I remember correctly the new one I installed had a washer on it
    Jimmyh and TnShooter like this.
  10. Oct 2, 2021 at 1:26 PM
    F75gunslinger
    Christian
    Rochester,NY
    So I put the new one in the same way the old one came out..no washer. Stupid me forgot to check and make sure it worked right before I put the truck back on the ground....turn on the key, reverse lights and camera are on all the time... . Cheated and drove it up a little bank to raise the center of the truck, tossed the washer on, works great now...
    Key-Rei[QUOTED] likes this.
  11. Oct 2, 2021 at 5:59 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Wow, I' surprised that washer made a difference relative to location but it obviously does. Good deal you got it fixed.
  12. Oct 3, 2021 at 7:38 PM
    F75gunslinger
    Christian
    Rochester,NY
    I was too....you wouldn't think that little bit ( 1/8th of an inch MAYBE ? ) would make the difference.
