Is this the factory brake controller hook up?
Discussion in 'Towing' started by andyt11, Jun 30, 2013.
  1. Jun 30, 2013 at 10:27 AM
    andyt11
    andyt11 [OP] Tiny Member
    Central Canada
    '13 TRD 6spd Dbl cab Leather
    Tekonsha P3
    I've been looking for the plug in my 2013 so I can connect my brake controller up and with the help of some of the threads in this forum I found the plug in the photo. Its the right shape but the wires dont quite match the harness that came with the tekonsha.
    It's located just above and left of the clutch pedal. It has blue, black white with grey, green and another small blue. It appears if I connect here, the green wont be used.
    I suspect the green is for some kind of illuminations that the Tekonsha doesn't used. Anyway, did I find the right plug or do I keep searching?
  2. Jun 30, 2013 at 10:57 AM
    smd3
    smd3 Well-Known Member
    It looks like it to me, but I don't remember the color of the wires. I bought a pre-made tekonsha harness to plug in to the Tacoma. I just plugged it in, and went...
    I will say this. It's the correct plug if you found it on the left wall of the cab, not on the firewall, and it was tucked behind where you couldn't see it.
    It'll be held to the rest of the wire bundle with thin tape, if you tug it the tape will break free easily, and give you 6" or so of slack.
    I think all the other unused connectors up there have caps in them and foam tape around them.
  3. Jun 30, 2013 at 9:26 PM
    andyt11
    Central Canada
    Tekonsha P3
    It's not really on the wall, but it is near and it is taped to a bunch of other wires with thin tape. And the harness i bought fits into the plug. I'm gonna give it a go.
  4. Jul 3, 2013 at 6:44 AM
    andyt11
    Central Canada
    Tekonsha P3
    update for anyone else finding this plug, it is the trailer brake control harness hookup.
    I checked out the wire that sends a signal when the brake pedal switch is operated and I got 12v when the pedal was pressed. Brought the trailer home last night. All is well.
  5. Jul 4, 2013 at 9:50 AM
    skeighter
    skeighter Well-Known Member
    Yeah. They don't make it easy to find. I had to pull the little kick panel out to find the plug. Once I found it was all good. Now I just have to configure it to my trailer.
  6. Dec 3, 2013 at 12:42 PM
    owensrj1
    owensrj1 Active Member
    Richard
    New Jersey
    2011 Black Taco LB
    Bed cover, Nerf bars
    does any know where the plug is on a 2013 tx pro access cab with tow package. can't seeem to find it.
  7. Dec 4, 2013 at 7:47 AM
    owensrj1
    Richard
    New Jersey
    2011 Black Taco LB
    Found it. It was up above the left side kick plate between the side wall and the emergency brake pedal bracket. very difficult spot to access. Thanks to all the above posts I found it
