Is this the original timing belt?
Discussion in '1st Gen. Tacomas (1995-2004)' started by egebhardt, Jan 14, 2014.
  1. Jan 14, 2014 at 7:42 PM
    egebhardt
    egebhardt [OP] Well-Known Member
    Eric
    Rapid City, SD
    '99 4x4 Xcab 5spd V6
    None
    I bought this 99 Taco a week ago. The PO said the timing belt was replaced, however, he has no records. The PO was not my brother or father, so obviously I'm not going to trust him further than I can throw him.
    The truck works perfectly so far but at 128,000 miles, I want to change the belt and water pump in case it was never done. This is a dry California car that was made in the NUMMI plant 20 miles away. It's probably never seen snow and was garaged at night.
    I pulled the timing belt cover back a bit to take a picture. Can anyone tell me if this is the original belt? Thanks in advance.
  2. Jan 14, 2014 at 7:50 PM
    xcmtb83
    xcmtb83 Well-Known Member
    Iowa
    Dunno about the belt but it looks like the plug wires read 1999. As far as the water pump it should have casting date on the front. I forget if it is a two or four digit number. The age of the water pump may clue you in on belt age as they are "typically" done at the same time. I realize this is not a guarantee.
  3. Jan 14, 2014 at 8:13 PM
    Bren
    Bren Well-Known Member
    CT
    01 Tacoma SR5 V6
    The belt looks pretty new from the pictures. My Taco has 207k and still has the original belt.
  4. Jan 14, 2014 at 8:40 PM
    rolledovertaco
    rolledovertaco roll me back over please...
    Cadillac
    kansas city missouri
    2002 tacoma 4x4
    get it to where you can read the manufacturer info ?
  5. Jan 14, 2014 at 10:40 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    When I changed my timing belt at 90K you could not tell by looking at it that it had that many miles on it.
    A better indicator of whether or not you should do this or not would be if the water pump is beginning to seep. The water pump is usually what goes first and to change it means taking all the belts off. If your WP is leaking, change everything, including the belt tensioner.
  6. Jan 15, 2014 at 5:55 AM
    fyremanpat
    fyremanpat Well-Known Member
    Pat
    757
    2013 DC LB TRD Sport w/Entune
    OME 886x and 5100's all the way around. Toytec AAL. Phillips x-treme vision headlights. 886 reverse lights. Borla exhaust. 20% tint. Hi 6 mod. 285/65/18 Nitto TG on 18" Moto Metal 955's. Airaid intake. Scanguage2.JBA LT's.GC Grill..more to come.
    its pretty clean in there!
  7. Jan 15, 2014 at 7:00 AM
    Moco
    Moco Well-Known Member
    Eric
    NoVA
    96 Regular Cab 4x4 5spd
    I dont think so.
    There is a telltale white reference mark on the sprocket that the person doing the timing belt job marked. I dont think the mark is from the factory.
  8. Jan 15, 2014 at 7:36 AM
    jaunty
    jaunty Well-Known Member
    99 V6 TRD Automatic 4x4
    i have the same dilemma. Bought my truck over a year ago. has 140k on it now. i guess im not as worried since its non-interference v6. if you have the 4cyl its a bit more critical.
  9. Jan 15, 2014 at 8:23 AM
    egebhardt
    Eric
    Rapid City, SD
    None
    That's just it. I can't find any marks anywhere which makes me think it was replaced with a cheap aftermarket belt.
    I know. It is surprisingly clean everywhere for 15yrs old.
    That white mark has always been present in DIY videos. I think the white mark is from the factory.
    I hear you. I asked a guy at the gas station how far he'd gone. He said 409,000 miles and he's NEVER touched it.
    I'm inclined to save the $150 (Ebay Mitsubishi/Aisin kits) and leave it alone but I love maintenance.
  10. Jan 15, 2014 at 8:31 AM
    HBtaco02
    HBtaco02 Well-Known Member
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    ARB Front Locker grey wire mod Camburg UCA's Extended Kings All-Pro expo's 10" Bilstien Brute Force Hybrid front bumper Smitty XRC8
    When in doubt change it out. Don't take a chance. People do get over 200k on original belt but why be lazy. The tensioner wears out long before the belt.
  11. Jan 15, 2014 at 9:56 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Hard to tell on the belt.
    A factory 99 water pump will be bolted directly to the block with FIPG as a sealant. Somewhere around 01-02, factory and service replacement pumps changed to a stainless steel and rubber gasket.
  12. Jan 15, 2014 at 11:16 AM
    egebhardt
    Eric
    Rapid City, SD
    None
    Unless I take it apart further, I'm not going to know for sure. By then, I may as well do the job.
    Maybe I'll start buying the special "2-pin" tool for the crank bolt. Then some anti-freeze. That's $100. Then another $200 max for the pump, belts, seals, thermo, tensioner, pulleys, etc....
    Another $300 isn't bad. I've spent $1,000 so far getting things perfect. I still want tires though.
  13. Jan 15, 2014 at 11:59 AM
    stikle
    stikle Well-Known Member
    Seth
    The Sovereign State of Eastern Oregon
    1997 LX Xtracab 4x4 V6 3.4L
    Eh, see my Build Thread sig link. Too many mods to list.
    That's it? Lightweight...I'm around $6K now. :D And there was nothing wrong with it either...just not perfect to me.
    Typically when a shop changes the timing belt, they put a sticker on the cover with the date...just about where that white sticker with blue lettering is on yours. If someone just did it in their garage, then who knows. I'd agree with the others...replace it so you have peace of mind.
  14. Jan 15, 2014 at 3:56 PM
    egebhardt
    Eric
    Rapid City, SD
    None
    Thanks guys!
    Tires will be over $500. Timing belt etc.. $300.
    I looked at that sticker. It talks about using 2-prong plugs only for this engine. Well.... AutoZone doesn't sell 2-prong plugs anymore because of prongs falling off in the engine. I bought Bosch Platinums for $2 each. That was cheap.
  15. Jan 15, 2014 at 5:03 PM
    Bren
    CT
    01 Tacoma SR5 V6
    I would advise you to return those bosch plugs and buy the oem ones. I bought the oem densos for 2.66 each. I heard about people having a lot of problems when using anything but the denso or ngk plugs. The motor has half denso and half ngk from the factory, so either brand will be fine. I bought mine from Toyota parts zone, but call the dealer for a price, they might be the same price.
  16. Jan 16, 2014 at 8:26 AM
    egebhardt
    Eric
    Rapid City, SD
    None
    Thanks. I have the receipt for the Bosch plugs ready for return. On my BMW M3, copper plugs are best too at $2ea. I see guys spending $15ea all the time. It's hilarious.
    The dealer wants $4.40 per plug. I'll just get them off Ebay for $4. Less driving around.
  17. Jan 16, 2014 at 2:58 PM
    RJ MacReady
    RJ MacReady professional trousersnake charmer
    RJ/Mike Hauncho/HeavyHands
    US OUTPOST North 31-Mayday Mayday! We've found som
    00 4Runner 4WD LTD - Cheatin' Bitch Build 2
    Cheatin' bitch build 2: All stock for now... 99' Tacoma 4wd TRD Cheatin' bitch build 1: BG44K additive, motul 5w40(always), deckplate mod, K&N washable air filter, 2.5" flow master(cut thanks to Airdog), king fronts 2.5", all pro standard leaf pk, stainless steel rear ext brakeline, 5125's 10" travel rears, 4-jasper offroad 6" pod LED spot lights, secret compartment for small bottle of wild turkey, cobra CB, Hi-lift jack w/locking bed mount, hi lift curved bumper lift & road base plate, smittybuilt X20 winch, wab fab F&R bumpers w/ hitch receivers, smittybuilt 4in1 recov tool, 10gal mini flamethrower, 11 lbs dynamite sticks, 13 4-hr snowflares, .50Cal full auto mounted machine gun w/ RPG unit & a shitoad of death metal to fuckstart your brain...everything you need for first contact with a shape-shifting alien entity frozen for over 100,000 years reanimated & immitating all life it engulfs.
    TRUTH!
    be a big PITA if the belt goes while you're driving it.
    I've spent over $3600 & several 30pks of modelo negra getting shit done to my 99'. Now the freakin' valve covers are leaking!!!!!
    :mad::mad::mad:
  18. Jan 16, 2014 at 3:08 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
  19. Jan 17, 2014 at 8:24 AM
    egebhardt
    Eric
    Rapid City, SD
    None
    RockAuto is about $3.50 shipped. Too late. Mine arrive Monday from SoCal (southern california for those don't live in this high-ego state) on Ebay.
    I have a Harmonic Holding tool coming too, from Amazon for $64. I can't find 'em any cheaper.
  20. Jan 18, 2014 at 3:42 AM
    jdkilroy
    jdkilroy Well-Known Member
    Jon
    Southern NH
    '02 4x4 SR5 Access Cab
    That is an unbelievably clean engine ... ! Just that is a pretty good indicator of how gently used that truck was before you got it; nice find.
