Is this the stock leaf pack?
Discussion in '5 Lug' started by FortuneFavorstheBruin, Mar 20, 2018.
  1. Mar 20, 2018 at 2:06 PM
    FortuneFavorstheBruin [OP] Well-Known Member
    Zack
    Austin, Texas
    2018 Tacoma Off-Road
    Hello All,
    New forum member here and I'm trying to make my truck a little easier to drive. I've noticed that the rear of the truck bounces over every single small bump in the road. As a precaution, I'm putting new bilsteins in all around (123k miles, it was time anyways).
    However, I've noticed what looks like an unusual amount of lift in the rear. I found that the OEM parts diagram from Camelback toyota shows 3 springs, rather than 4. Can anybody confirm if there is an added leaf in here? If so, how do I go about removing it?
    Thanks!
  2. Mar 20, 2018 at 2:08 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Looks like the short one is an add a leaf or maybe a leaf someone cut down. Maybe a 3/4 ton leaf.
    Also....someone correct me if I'm wrong...but is the overload spring upside down?
  3. Mar 20, 2018 at 2:16 PM
    Matic
    Tricky Dick
    Easley, SC
    Removing it is simple.
    Get 2 C clamps and tighten em down on either side of the center pin. About 12 inches or or near the end of the aal.
    Remove the bolt that holds the center pin/pack in place.
    Loosen 4 U bolts enough to slide out the AAL.
    Make certain that overload spring isn't upside down.
    If so, flip it.
    Make sure the leaf pack is aligned. Tighten the center pin/pack nut.
    Tighten the u bolts.
    If it is an aal, the previous owner might have installed a center pin with longer threads. You may have to trim that to get it to seat correct because you're going to have extra length on it from removing a leaf.
  4. Mar 20, 2018 at 2:23 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    You even have air bags in the rear
    Matic likes this.
  5. Mar 20, 2018 at 2:24 PM
    Matic
    Tricky Dick
    Easley, SC
    Good eye. Previous owner must have used it on a daily to haul stuff. Maybe mulch or construction stuff.
  6. Mar 20, 2018 at 2:31 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Also stock I think we have only 2 leafs. I have an short aal and including that i have 3 leafs
  7. Mar 20, 2018 at 2:35 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Here is a stock photo i found
  8. Mar 20, 2018 at 2:39 PM
    Zack
    Austin, Texas
    Yeah, previous owner said that it was used for hauling stuff occasionally, the back end literally jumps over bumps and it's killing my back/head. Said owner was a dipshit and wouldn't surprise me if it was in fact, upside down.
    I took a pic of the other side of the full leaf pack for y'all:
  9. Mar 20, 2018 at 2:43 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    yeah you got alot of extra stuff going on there. All easily removable without having to get new stuff other then short shocks which would be cheap
  10. Mar 20, 2018 at 2:48 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    This is what my rear end looks like with just a single short AAL
  11. Mar 20, 2018 at 2:53 PM
    Zack
    Austin, Texas
    Thanks Sperrunner, I actually have a set of 4600 Bilsteins showing up today that should help smooth out this ride a bit.
  12. Mar 20, 2018 at 2:53 PM
    Zack
    Austin, Texas
    Just in case the U-Bolts are toast, anybody know what brick and mortar shops would carry them?
  13. Mar 20, 2018 at 3:00 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
  14. Mar 20, 2018 at 3:02 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Btw with those AAl on your truck it will have lifted the rear meanin stock size shock will not work probably. They will be to far extended and will be prone to toping out when going over big bumps which will damage them.
  15. Mar 20, 2018 at 3:15 PM
    Zack
    Austin, Texas
    So be sure to remove the added leaf before putting the new shocks on? That makes sense, i'm wondering if I should take off the airbags and put on the bump stops too. What do you think?
  16. Mar 20, 2018 at 3:18 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    If you plan to hual anything then sure keep them, but thats if they are in good condition, after awhile those bags break down and tear. Also is there already on board air to fill them. I personally would just go back to stockand use bump stops
  17. Mar 20, 2018 at 3:31 PM
    Zack
    Austin, Texas
    Nah, it's the stock sealed system that you get from Amazon. I'm personally not a huge fan of them and nothing heavier than a dirt bike would ever go in the back anyways. Fortunately I found the bump stops underneath the rear passenger compartment when I was cleaning. I'll see how it feels after ditching the leaf and stock shocks; if I still dont like it i'll probably take the bags off.
  18. Mar 20, 2018 at 3:33 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    The bags arnt probably really providing any comfort or discomfort they are just there.
  19. Mar 27, 2018 at 8:03 PM
    Zack
    Austin, Texas
    Removed the overload, threw new bilsteins on, and it rides better (Albeit still kinda like shit). Anybody got any suggestions for what else could possible be the issue?
  20. Mar 27, 2018 at 8:12 PM
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    You forgot to tell him about removing the leaf pack from the truck and how much fun that is to do. Lol
