is this the "Taco Lean"?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Black Sheep, Feb 14, 2011.
  1. Feb 14, 2011 at 4:56 AM
    Black Sheep
    Black Sheep [OP] Well-Known Member
    Jeff
    Pittsburgh, PA
    2011 Black Dbl Cab TRD T/X Pro
    6" Pro Comp Suspension lift with Pro Comp leveling kit, Bilstein 5100's, Full leather interior with seat heaters, Go Rhino step bars, Sony XNV-770BT Head Unit with NAV, DVD, XM and Blutooth, Tonopro toneau cover, Tinted windows, Black mesh grille, Projector headlights with HID lows, HID fogs, Crystal Eyes rear LED taillights, Weathertech mats front and rear
    I just had my 5100's installed up front on Saturday. I had the tsb done a few weeks ago. I love the way it sits. My Duratracs are going on tomorrow afternoon. But my issue is with the measurements that I took after the install. The front is the same at 36" to wheel well, but the back passenger side is 37 1/4" and the drivers side is 36 1/4". Is this the "Taco Lean" that I have read about? Is 1" normal? My gas tank is only at 1/4 tank right now. The dealer is doing the alignment tomorrow. Should I ask them to look at the rear driver's side or is this normal? It seems like 1" is a lot of difference to me.
  2. Feb 14, 2011 at 5:15 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    So I guess you got the dealer to do the TSB then? Did your orig dealer do it or did you go somewhere else? And I'm guessing your not selling your truck.
  3. Feb 14, 2011 at 5:19 AM
    Black Sheep
    Jeff
    Pittsburgh, PA
    I got the original dealer to do the TSB, with a little "coaxing" on my part. No, not going to sell it now with everything that I have in it.
  4. Feb 14, 2011 at 5:25 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Good deal. Now as far as the Taco lean. I'm pretty sure the lean does not set in for a little while. Maybe your new springs just need to settle some. Maybe 1 side settled and the other has not yet. Maybe throw a load of something in the back and drive around a little. Might just level it out for you.
  5. Feb 14, 2011 at 5:32 AM
    pinktaco808
    pinktaco808 Hot Steppa
  6. Feb 14, 2011 at 5:52 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Most folks experience the lean in the front, and don't have that noticeable difference in the back. This doesn't sound like the typical lean, especially with the leaf packs being so new.
  7. Feb 14, 2011 at 6:06 AM
    Black Sheep
    Jeff
    Pittsburgh, PA
    That is what I thought. I called the dealer. They are going to look at it when the do the tire swap and alignment tomorrow.
  8. Feb 14, 2011 at 6:18 AM
    TexasTacoma37
    Cool.
    If you post up a picture of the leaf packs on each side, we might be able to help you diagnose before it goes to the dealer.
  9. Feb 14, 2011 at 6:49 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    1" does seem kind of a big difference. As far as the lean affecting both front and rear, yes the right side in both places will be higher as part of the lean. Here's the measurements I did before and after installing the 5100s (I just repeated the data for the rears at both settings even though it obviously would be the same since it's just the front that changed). FYI, the measurements "after" in the rear are due to the Wheeler's 1.5" AAL. But you can see both front and rear before and after all have the lean, just not as much after the 5100s are on.
  10. Feb 14, 2011 at 7:38 AM
    jrdbrn
    jrdbrn Well-Known Member
    Jared
    Louisiana
    '21 TRD Off Road
    Mine leans, but only when I have a full tank. Thought it was normal?
  11. Feb 14, 2011 at 7:42 AM
    Black Sheep
    Jeff
    Pittsburgh, PA
    I will try to get this pic when I get out of work today and get it posted.
  12. Feb 14, 2011 at 7:46 AM
    Black Sheep
    Jeff
    Pittsburgh, PA
    These numbers are just about right on with mine except for the left rear.
  13. Feb 14, 2011 at 8:53 AM
    05Moose
    Jim
    Did you leave a bar of gold sitting in your driver's side storage cubby in the bed? I hear those bars are kind of heavy...
  14. Feb 14, 2011 at 9:48 AM
    Black Sheep
    Jeff
    Pittsburgh, PA
    I wish I did that. If that was the problem, I wouldn't be worried about anything.
    :D
  15. Feb 14, 2011 at 1:52 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    I would give it some time to settle first.
    when i first had the TSB done , it raised the back about 1.5 inches.
    about a week later the back end was only about 1 inch above stock.
    i dont think any truck sits perfectly level, and if it does its pure luck
    between options on truck, gas in the tank, the amount of wheel travel we have, etc.
    Lets see some good pics with the Duratracs!!!!
  16. Feb 14, 2011 at 6:25 PM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    Mine leans all of the time, but is easier to see from the rear especially when the tank is full. It may be common, but it shouldn't be confused with "normal"
