Is this too much air???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TRDsport253, Sep 25, 2022.
  1. Sep 29, 2022 at 11:19 PM
    #101
    photogr4x4
    photogr4x4 Well-Known Member
    Canada
    TRD OR
    Nada
    Eh, people are always going to suggest it anyways, why not throw it in there and just get the arguments out of the way right off the bat. Not like it wasn't a shitpost to begin with.
    I just read my door jamb and let 'er go unless I'm hauling heavy shit or going off pavement; inflate or deflate as required.
    Sungod[QUOTED] likes this.
  2. Sep 29, 2022 at 11:21 PM
    #102
    photogr4x4
    Canada
    TRD OR
    Nada
    ...drums :annoyed:
  3. Sep 29, 2022 at 11:55 PM
    #103
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    RustyGreen and BigEasy like this.
  4. Sep 30, 2022 at 12:02 AM
    #104
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Recommended psi or adjusted recommended psi has a load capacity 1.54 times that of gvwr...
    I'm wondering what your reasoning for inflating beyond that is, when "hauling heavy shit".
  5. Sep 30, 2022 at 11:34 PM
    #105
    photogr4x4
    Canada
    TRD OR
    Nada
    The combination of terrible timing and Murphy's Law states almost every time I've had my tires swapped either winter-summer or summer-winter in the past 6 years I've had to load my truck bed up with 1000 pounds of whatever, this winter swap it was a toolbox and all of my automotive tools, and in that same instance of Murphy's Law no one in this town can hire a competent employee that can balance tires properly. 30psi, shit balanced tall and skinny LT tires, and a heavy bed makes things real, real squishy, and feels like I'm towing a 4000lb trailer through a highway made of entirely of bouncy castles because it's always a static imbalance.
    Should I change them myself? Probably. Do I want to spend my own time changing tires? Fuck no. I love my trade but I hate mounting tires. I don't mind teaching people to mount them, but doing it myself routinely is one thing I don't miss from technical training.
    splitbolt[QUOTED] likes this.
  6. Oct 1, 2022 at 2:59 AM
    #106
    splitbolt
    NW Arkansas
    I can dig it...
    photogr4x4[QUOTED] likes this.
  7. Oct 1, 2022 at 10:03 AM
    #107
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    Hello Apple, this is an Orange...
    In all such racing series, the tire manufacturers go in with an expected pressure range from previous data. They then test those pressures to see how they work and last.
    Automobile manufacturers set the pressures you see in the door jamb by testing also. The numbers are for the tires that are original spec. Anything other than OEM spec tires, you are on your own for pressure, though stock sizes should see similar pressures work fine. Once you change size, all bets are off.
    photogr4x4 likes this.
  8. Oct 1, 2022 at 10:26 AM
    #108
    OldSchlPunk
    Rich
    East Central Wisco
    Great info. Per the chart in the link, I probably should be running about 47psi in my LT's for OEM load capacity. I'm running 40-42, which means my load capacity will be down a bit. I had been guessing by feel up to this point. I might try upping the pressure to see how they feel though I don't run anywhere near load capacity usually.
    Conversely, if I were to run door sticker pressures, the load capacity would be down around 30% from stock!
  9. Oct 1, 2022 at 10:27 AM
    #109
    splitbolt
    NW Arkansas
    Tacomas come with a variety of sizes, load ratings, rim widths and recommended psi. They all coalesce to an inflated load capacity of 2,149 lbs for P-metric and euro metric tires; or 1,954 lbs for all LT rated tires after de-rating. PSI is only a means to that end.
    Recommended psi or 'adjusted' recommended psi is good up to gvwr. Anything under over or under is subjective preference. Under is usually someone doing a chalk test and does not anticipate increased cargo or passenger weight; and also subject to inaccuracy if done incorrectly(99.9%* of advocates). Over is usually someone hypermiling or after subjective feel/steering response.
  10. Oct 1, 2022 at 10:31 AM
    #110
    splitbolt
    NW Arkansas
    I'm dubious...I think you might have made an error in calculation.
    What size is your LT tire?
  11. Oct 1, 2022 at 10:34 AM
    #111
    OldSchlPunk
    Rich
    East Central Wisco
    265/75/16. Getting my numbers from the linked PDF.
  12. Oct 1, 2022 at 10:39 AM
    #112
    splitbolt
    NW Arkansas
    It's 37 psi...
    I suspect you failed to derate for P/Euro-metric to LT conversion or did not make the distinction between P and euro-metric tires(there is a difference) when obtaining your oem inflated load capacity. 2,149÷1.1=1,954 lbs. Read the section on P/Euro-metric LT to conversion...
    I am an advocate of "the charts"...but, you have to be accurate about the input info and calculations.
  13. Oct 1, 2022 at 10:41 AM
    #113
    OldSchlPunk
    Rich
    East Central Wisco
    I think you may be right...
  14. Oct 1, 2022 at 10:44 AM
    #114
    splitbolt
    NW Arkansas
    I edited my post while you replied. Read for additional info...
  15. Oct 1, 2022 at 2:08 PM
    #115
    kodiakisland
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    What size did you change to that requires so much more pressure? Low profile tires?
    Edit to add just read the rest of your replies. Yeah, definitely have to make sure you account for p-metric loads and then make sure you're looking up the correct size on the chart, and then making sure it's the single load and not the dual.
  16. Oct 1, 2022 at 2:19 PM
    #116
    kodiakisland
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    I am rarely at gross weight. I use my actual weight X1.6 for my recommended psi and then adjust from there. I do add air when on longer interstate travels for mpg gains or for carrying heavier loads. I probably adjust my tires more than most, but like optimal pressures for each use of my vehicles. I don't have interstate commutes and usually stay below 60mph for most of my driving, and am usually solo, so I know my weight and needs.
    photogr4x4 and splitbolt[QUOTED] like this.
  17. Oct 1, 2022 at 3:48 PM
    #117
    splitbolt
    NW Arkansas
    Some aren't as conscious about it...
    For some, it's easy to load up and hit gvwr.
    E.g.~Load up three of your good sized friends and their gun gear and head down the interstate for 2 hours to a 3-gun match...
    If a person inflates higher than 36 psi in a P or euro-metric SL tire, the designed load capacity does not increase. Anything over, up to max psi of the tire, is to maintain the speed rating of the tire at very high speeds(illegal speeds.) It's subjective feel after that.
    I try to state just the facts; trying to make people more conscious. What they decide to do with the info is entirely up to them.
    kodiakisland[QUOTED] likes this.
  18. Oct 1, 2022 at 4:15 PM
    #118
    kodiakisland
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    Yeah, the vast majority have no idea what their psi is or should be, and the number of people driving around with near flats is still a lot considering most cars have TPMS now.
  19. Oct 1, 2022 at 4:32 PM
    #119
    splitbolt
    NW Arkansas
    Heh...
    I'm an electrician, currently wiring a middle school...
    I noticed a guy at work this week, sitting in his suv at lunch, parked on a grapefruit sized rock...
    Looked like a good offroad pressure. Highway; not so much.
    I didn't say a damned thing...
    Chew likes this.
  20. Oct 2, 2022 at 10:16 AM
    #120
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Smart! I got to a certain age and ask myself "why should I care more about xyz then he or she does?"
    It's absolutely great to help others, but they have to want help, many do not, they are not worth your time.
    splitbolt[QUOTED] and AxisCab like this.
