Is this truck worth it? New guy needs advice.
Discussion in '1st Gen. Tacomas (1995-2004)' started by yoTaco98, May 17, 2011.
  1. May 17, 2011 at 10:02 AM
    yoTaco98
    yoTaco98 [OP] Well-Known Member
    Yo
    VA
    1998 V6 Xtra-Cab Tacoma 4x4 SR5
    5100's Front and Rears, Toytec Eibach Coils, All Pro 3" Standard Leafs, BAMF BPV Bracket, ARMA Sprayed Bedliner, TGD Hunter Bull Bar, Blacked-out Headlights and Corners, Revtek 1" Diff Drop, Start Command Remote Start and Keyless Entry, Pioneer DEH-11E HU...
    Hey guys,
    I'm new to the forum and have pretty much finalized my deal on a pre-owned Tacoma. I'm driving down this weekend to pick it up if everything else checks out.
    The truck is a 1998 4x4 v6 Xtra-Cab SR5 Automatic with 173,000 miles on it. Power windows, power door locks, working A/C.
    The truck has had two owners. The previous owner is an employee of the current owner. And although they don't have maintenance records, they swear by every single maintenance.
    Concerns
    They mentioned the last thing they had to replace was the power steering pump, and it was replaced with OEM pump.
    They also said that mention that the truck has a minor oil leak from the valve cover. It is barely noticeable, and the truck doesn’t lose any oil in between changes. They are included the valve cover gasket, so I can do the replacement if I wish.
    Also, the ABS light is on. They said that the light came on after they had to suddenly break one day, and the ABS engaged. Shortly after, they replaced the brake pads and the light turned off. Since then the light has come on and off, but hit has mostly stayed on.
    173,000 miles, over 13 years
    Positives
    The body is in excellent condition. No accidents.
    The frame is rust free, from the Southeast U.S. Little to no snow or salt ever.
    The interior is immaculate. The seat have had seat covers on them since the day the truck was purchased. The interior looks as close to new as is possible for any truck.
    MODS: Rhino sprayed bed liner, rhino sprayed OEM wheels, 31" Mud Grabber tires, 2.5" Skyjacker lift with Skyjacker shocks/struts, front grill guard, tubes side steps, almost new tool box on the rear, towing package with hitch, blacked out rear tail lights, bug/rock shield on the hood, Pioneer aftermarket radio.
    It's a Toyota.
    The Price
    $6500, down from $7500 which he felt was a steal since he had $9000 into it.
    I commute to work using public transportation, So I rarely drive into work (62 miles round trip), maybe once a week.
    I want the truck for more please than anything. Tow the mountain bikes, two the snowboards, tow the dog. And occasionally drive into work on days I don't commute or trade off with my primary vehicle, Infiniti M45.
    SO...
    I'm sorry for the long email. I just wanted to get it all out there. My question is...
    Is this truck worth the price with mileage and age? Or should I be looking at a truck with fewer miles on it? How long do you guys think this puppy will last me.
    I am pretty OCD about my vehicles. My Infiniti has run Mobil-1 everything since day 1. Whatever maintenance I can't do myself, it's done at the Infiniti dealer.
    I would really appreciate your thoughts?
    I will post pics this evening if anyone's interested.
    Thanks in advance!
  2. May 17, 2011 at 11:22 AM
    Cvd2312
    Cvd2312 Well-Known Member
    Cory
    Oregon
    97 Tacoma 3.4L
    Bilstein 5100's all the way around, 2" shackles in rear, front diff drop, 32x11.50.15 BFG A/T, 15x8 Ultra 164 Wheels
    Sounds like a pretty good deal to me
  3. May 17, 2011 at 11:24 AM
    HeadlampRevamp
    HeadlampRevamp Well-Known Member
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    I would get to the bottom of the ABS light, they can be bad news. Most things related to ABS are expensive.
  4. May 17, 2011 at 11:32 AM
    yoTaco98
    Yo
    VA
    He says that the ABS still works fine, just that the light is on.
    I've read on here for some time that a lot of Tacomas had a light issue after engaging the ABS, because of low brake fluid. Either that or the fuse is bad (I Hope).
  5. May 17, 2011 at 3:44 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    i dont have ABS either, seriously, who needs driving aids anyway:D
  6. May 17, 2011 at 3:50 PM
    easyeatlanta
    easyeatlanta Artificial Intelligence beats natural stupidity
    Eric
    Memphis
    14 DC Trd Off Road
    I would definitely replace the gasket but other than that sounds like a good deal as far as I can tell and have the light checked out but if it still works don't worry too much about it
  7. May 17, 2011 at 4:30 PM
    yoTaco98
    Yo
    VA
    We have to get a "safety inspection" in VA before we can register the vehicle.
    I know I should probably check with VA, but do you guys think that they can fail me for the ABS thing?
  8. May 17, 2011 at 4:51 PM
    yoTaco98
    Yo
    VA
  9. May 17, 2011 at 4:54 PM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    pics don't work for me...
  10. May 17, 2011 at 4:57 PM
    yoTaco98
    Yo
    VA
    Does it work now?
  11. May 17, 2011 at 5:00 PM
    GWL
    GWL Well-Known Member
    justin
    Cole Harbour N.S.
    98 4runner 5speed 4x4 :)
    super clean truck, seems like a lot of cash for that many miles, but a tacomas price is dependant on the area. I'd get him to get it saftied before I bought it and if it needs repairs haggle the price more
  12. May 17, 2011 at 5:01 PM
    bowhunter11199
    bowhunter11199 Well-Known Member
    thats at 2.5" lift? it almost looks like its lowered
  13. May 17, 2011 at 5:02 PM
    SupraT
    SupraT Tacoma Lover
    Tony
    Columbia Falls
    98 TRD SR5 4x4
    3" Lift Three leaf add and Bilstin 5100"s in back and Donahoe coilovers in front, Tinted Windows, Blackened parking light, tinted brake lights, clear bumper lights, Blacked out turn signals, AVS vent visors, Electric Fan mod, K&N CAI
    I think it looks like a good deal and pretty clean.
  14. May 17, 2011 at 5:15 PM
    yoTaco98
    Yo
    VA
    We'll they were asking $7500, and I got it down to $6500. I found another one for that I got down to $5500. But, considering the cost of the bed liner, lift, tool box, grill guard, and other mods. I thought the $1000 difference was worth it, no?
    2.5" skyjacker. You can see the spacer on the one pic of the wheel, and obviously the shocks were changed to skyjackers as well.
    They way I saw it. Anyone that puts this much money into mods and upgrades, has taken pretty good care of the truck. Especially since the interior is super clean.
  15. May 17, 2011 at 5:16 PM
    bowhunter11199
    i know its lifted but it just looks like it isnt..... but still nice looking truck
  16. May 17, 2011 at 5:41 PM
    JBear
    JBear Spiral Out... Keep Going!
    Orange County, CA
    2003 Extra Cab 5 spd 4x4 TRD Off-Road
    2" suspension lift with King Coilovers up front. Standard Bilsteins on rear with a Fabtech 1.5" AAL. Leer 100XL Shell.
    good lookin, engine included... sounds like a decent deal. I wanna Linex my wheels too, but I have the lame spiral ones. Might as well get some new black wheels with my next set of tires... $$$ouch$$$
  17. May 17, 2011 at 5:50 PM
    yoTaco98
    Yo
    VA
    I know the Linex/Rhino bed liner run about $500. How much does it cost to do the wheels typically?
  18. May 17, 2011 at 5:55 PM
    yoTaco98
    Yo
    VA
    Thanks! It's in Montgomery, Alabama. I have wedding to go to in Orlando, so I would just be flying in to Orlando, and driving it back form Montgomery.
    Does anyone think the mileage is excessive? Or 173,000 on a Taco is no big deal?
  19. May 17, 2011 at 6:29 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    Do you trust the seller has done the timing belt change at 90K, in the absence of receipts? Could be an expensive maintenance item if it wasn't done, and an even more expensive repair if the belt breaks.
    The critical fluids (transmission, differential oil, transfer case oil) are all replaced "on condition". So the truck could be running on original fluids for the last 173K and still be compliant with the minimum required maintenance. Something to think about if you are OCD...
  20. May 17, 2011 at 7:13 PM
    yoTaco98
    Yo
    VA
    We'll, that brings up a good point. I am planning on taking it to the local Toyota dealer and having all the fluids and belts and hoses inspected.
    But are there some things that I should do regardless?
    Spark plugs?
    Timing belt?
    Differential Fluid?
    Transmission Fluid?
    It's only 7k miles from it's second 90k full service at 180k. So isn't there things I should plan on doing right away anyways?
    How much does the timing belt cost to replace by the way?
