is this V6 running hot?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CHUCK W, May 17, 2017.
  1. May 25, 2017 at 10:14 PM
    Pigpen
    Dan
    Northwest Montana
    Truth
  2. May 26, 2017 at 10:29 AM
    jessandjamie
    jessandjamie Well-Known Member
    Arizona
    You are aware that just because the gear selector is in D doesn't mean he's in 5th gear. Look at the RPM's, he's probably in 4th with the torque convertor unlocked. That's the real problem. If anything he probably should have dropped to 3rd so it would lock and drop the trans temp. The torque convertor being unlocked is where the heat is coming from.
  3. May 26, 2017 at 11:11 AM
    Hoyle
    Hoyle Well-Known Member
    Cookeville TN.
    2014 DCSB 4x4 Black
    A lot of stuff.
    Yes, I was in 4th.. out of habit it goes into drive.. I did all my towing in 4th... so it was in 4th during this photo... I actually put a Sticky Post-it on my dash to remind me when I have the trailer to use 4th ...
    Alexely999 likes this.
  4. May 26, 2017 at 11:13 AM
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    In my FJ with the UG, I sometimes see 186, but almost always its 192 or 194.
  5. May 26, 2017 at 7:06 PM
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    I see 186 a lot, but as it gets warmer outside I start to see 190° to 194°. I don't think I've ever seen it climb above 196°. I always thought 240° was as high as you can go without warping the head... is that anywhere close, @Torspd ?
  6. May 27, 2017 at 10:39 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That'd be correct.
    Concrete jungle traffic. Freeway baking in the sun for hours, then toe - jam traffic. You'll watch those numbers get up there.
    Owners with grills which have small perforations(which does restrict air flow), additional coolers, or other devices blocking air flow, will also see increased coolant temps.
    The diversion panel will help force air through the rad, https://www.bpfabricating.com/products/05-11-toyota-tacoma-cooling-panel
    Relative to its cousin, the 4Runner, the Tacoma is lacking a significant amount of ducting to force the air through. All aspects of the afore mentioned can contribute to higher coolant temps, most noticeably in the summer months.
    clinteastside likes this.
