Is this what I want?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Irish020, Sep 30, 2011.
  1. Sep 30, 2011 at 1:58 PM
    Irish020
    Irish020 [OP] Well-Known Member
    Phil
    Pennsylvania
    '05 Tacoma TRD Sport 4 Door Longbed
    ARE Hard Tonneau Cover Flowmaster American Thunder Super 50 Series Stainless Dual Exhaust Toytec Ultimate 3" w/ UCA's
    So I'm getting close to purchasing a lift kit for my '05 TRD Sport 4DLB..
    Is this the one I want?
    3" lift kit with Bilstein 5100 Height adjustable Coilovers
    Price per Unit (Kit): $859.99
    Ask a question about this product---TTHA-CK---
    SALE PRICE $859.99 Normally $899.99
    Complete 3" lift kit with Bilstein 5100 Height Adjustable front shocks
    INCLUDES:
    Bilstein 5100 height adjustable front shocks
    Toytec/Eibach 112620 front coils
    Fully assembled with Toytec Aluminum top mount and Urethane bushings
    Preset at 3" Lift Adjustable with C Clip for additional weight.
    Rear options: select one below
    -----TAC-AL - ToyTec Rear "long" add-a-leafs featuring anti friction pads for quiet ride
    -----TAC-AL-TSB for Tsb & 4 leaf Toyota springs
    -----BK-15 1 1/2" rear block kit
    -----CS047R Complete OME Dakar springs include bushings and additional shipping to the 48 states, Alaska and Hawaii will have additional shipping due; we will contact you with the additional amount due. price is for set of 2
    Also includes:
    -----Extended length Bilstein 5100 rear nitrogen gas shocks for optimum performance on and off road
    -----TT-RS - rear axle degree shims for proper pinion angle alignment
    -----UB-4 - (4) new rear ubolts
    NOTE: Some Canadian models require the TSB 1 1/2" add-a-leafs, if your springs have 4 leafs total you will need to order the TSB add-a-leafs
    3" lift kit with Bilstein 5100 Height adjustable Coilovers from Toyotec?
  2. Sep 30, 2011 at 2:07 PM
    Irish020
    Phil
    Pennsylvania
    And, is there a better option for less price than Toytec?
    I've heard I may want need new upper control arms with this kit...True or False?
  3. Sep 30, 2011 at 2:10 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    This sure looks like a nice setup. They recommend anything 2.5 inches or higher, should get some aftermarket UCA's to get the alignment back in factory specs.
  4. Sep 30, 2011 at 2:19 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    light racing UCAs from fat bobs are 379.99 FYI
  5. Sep 30, 2011 at 2:22 PM
    Irish020
    Phil
    Pennsylvania
    So I need UCA's....
  6. Sep 30, 2011 at 2:26 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Its highly recommended. I have some TC UCA's and they were pricey but my alignment and tire wear has been perfect for years so I think its worth it. You can go without them but I wouldnt wait extremely long.
  7. Sep 30, 2011 at 2:31 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    that is a nice set up.and yes get new uca's for it to be done right
  8. Sep 30, 2011 at 5:44 PM
    Irish020
    Phil
    Pennsylvania
    Thanks for the responses!
  9. Feb 3, 2012 at 12:59 PM
    ajan246
    ajan246 Well-Known Member
    Orange County, CA
    2012 Access PreRunner V6 2WD
    this is the same kit i am looking to get as well. Will I need extended brake lines for this or will stock work?
    thanks
  10. Mar 6, 2012 at 8:52 AM
    jdk52
    jdk52 Bro do you even 'Merica?
    Utah
    11 SR5
    3 inch OME lift kit, rear diff breather mod, cb install, sliders, brute force fab front end.
    Everyone I've talked to and from what I've seen on here has made me go with that kit unless I find something better locally. I get paid on the 15th so I'm shopping around until then. Any personnal recomendations on tires for "i need to go down this fire loop road to a fishing spot" use?
  11. Mar 6, 2012 at 9:17 AM
    Bryan139
    Bryan139 I have a spectacular aura
    NJ
    '09 Sport
    I cut some wires here. Added some wires there.
    When I bought tires I had narrowed it down to General Grabber AT2 or wallyworlds Goodyear Wrangler Authortys. I went with the Goodyear because they ended up being cheaper and I think they look a little more aggressive and they came in a C load range. I'm not scared of Walmart, they still say Goodyear on the side. I spent 3 years with the stock tires on and never got stuck or popped one so I'm not worried, but to each his own. I definitely don't wheel like a lot of other guys on here. 90% of the time when I switch into 4wd there is fishing gear in the back. The other 10% it's snow.
    It all starts with your budget though. I was on a tight one. Decide how much you have to spend, research the highest quality tires in that price class, and then pick which one you think looks the best.
