Is this worth the hassle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by StreetSr5, Sep 21, 2024.
  1. Sep 21, 2024 at 5:05 PM
    StreetSr5
    StreetSr5 [OP] Well-Known Member
    IMG_3903.jpg Leaking PS rack on 2022 with 25k miles on it (so still under full warranty) truck has a billstein 5100 1.5 inch lift. I talked to a service advisor on the low and he said toyota 100% wouldn’t cover it even with a lift as subtle as 1.5 inches. He told me that if I returned the suspension back to stock, they would warranty it. The problem is that it would be a complete pain in the ass for me to put my stock suspension back on, ask them to fix it, then put my billsteins back on. I even saw a guy on here who said the dealer said they could see “evidence” that there was previously a lift on his truck when he returned it back to stock for the same problem. Based on the level on the power steering reservoir it’s a pretty slow leak. Thoughts? Worth the trouble or just top fluid off every once and a while and not worry about getting the rack replaced?
  2. Sep 21, 2024 at 5:20 PM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    I would definitely try to get it done . It’s a pain in the ass job and the trucks too new. It’s way less of a pain to put the stock suspension back in . If you decide to go that route make sure you leave for a little while after they fix it . In case anything else crops up. Once settled then you will be safe to put back
    SR-71A, kahanabob and Toy_Runner like this.
  3. Sep 21, 2024 at 5:23 PM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    Changing out the front shocks is way easier. Doing the steering rack is a nightmare and it’s not cheap to have done.
  4. Sep 21, 2024 at 5:29 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    All due respect ... "it was a slow leak" is no comfort if/when it blows out. Restore the shocks, accept Toyota not blaming the steering rack issues on the lift.
    shakerhood likes this.
  5. Sep 21, 2024 at 5:38 PM
    StreetSr5
    Y’all are right… I will put the stock shocks back in. I also have 265 75 16 tires. Do you think they will somehow also blame it on my tires being an inch bigger in diameter?
  6. Sep 21, 2024 at 6:00 PM
    andrewtheadventurer
    andrewtheadventurer Well-Known Member
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    You have to get an alignment after touching the suspension
  7. Sep 21, 2024 at 6:04 PM
    StreetSr5
    I know… another reason why I was hesitant to screw around with swapping the shocks. But a 100 dollar alignment is cheaper than a 2000 dollar rack swap.
  8. Sep 21, 2024 at 6:13 PM
    RichochetRabbit
    FWIW ... you seem to have wisely/maturely accepted the advice given. Good on ya. :cheers:
    Jaragon, brigsby99 and Bandit like this.
  9. Sep 21, 2024 at 6:21 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    25k miles and the steering rack is leaking. Gosh dang I'd be pissed. This is normally a 150k+ mile issue.
    crashngiggles likes this.
  10. Sep 21, 2024 at 6:25 PM
    TruckGuy63
    Gilbert
    New York
    Steering racks are funny, some go at almost no mileage and some go the life of the vehicle . My 05 Corolla has the original rack pushing 300k amazing car , it doesn’t burn a drop of oil and runs like a top.
    SR-71A and Superdave1.0[QUOTED] like this.
  11. Sep 22, 2024 at 3:35 AM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    Just have it fixed don’t bother with putting the stock setup back on . What happens if they still deny the warranty work then u just spent all that time putting stuff back on for nothing . Find an independent shop to fix the issue and correct the angles so this doesn’t happen again .
    02Duck likes this.
  12. Sep 22, 2024 at 10:14 AM
    SilverTRD Sport
    SilverTRD Sport Well-Known Member
    Houston, TX
    2016 TRD Drowned now 2017 Inferno TRD Sport
    Go to another dealer and don't mention what this dealer said before putting everything back to stock. If you do return it back to stock don't worry about an alignment unless you keep it that way.
  13. Sep 22, 2024 at 10:46 AM
    mit88
    mit88 Well-Known Member
    Planet earth
    I concur! What could one get to lose?
    kahanabob and SGJarrod like this.
  14. Sep 22, 2024 at 11:45 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Try some Mazda ATF? See my other posts about it. Meets the Toyota spec.
  15. Sep 22, 2024 at 12:39 PM
    StreetSr5
    That’s my plan, I already scheduled an appointment for a different dealer, but the service advisor I talked to didn’t put anything in the system so I could technically just go to the same dealer and probably be fine
    SGJarrod likes this.
  16. Sep 22, 2024 at 12:42 PM
    StreetSr5
    Already started the return process lol. The way I’m doing it there’s absolutely no way they can deny anything. I’m putting the stock front shocks back in, removing my rear blocks, and I also happen to have my stock size wheels and tires on the side of my house so I’m putting those back on. If they do somehow deny warranty I will definitely not be taking their bs and will open a case with Toyota
    kahanabob likes this.
  17. Sep 22, 2024 at 1:10 PM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    IIRC, Toyota would have to prove your shocks and tires caused the failure before they can deny the warranty.
    Superdave1.0 likes this.
  18. Sep 22, 2024 at 2:14 PM
    GawainXR
    GawainXR Well-Known Member
    William
    2020 TRD Off-Road
    DashCam
    I think this is technically true but only if you legally challenge it in which case getting a lawyer is pretty expensive and likely far going to exceed the cost of just pointing up and paying to have the repair done.
    IANAL though
    But to be honest at this point I'm not sure I'd trust any Toyota dealerships service department to change a light bulb correctly let alone something like a steering rack.
  19. Sep 23, 2024 at 8:34 AM
    rolled93slc
    rolled93slc Well-Known Member
    Jerry
    Lynchburg VA
    16 Tacoma TRD Sport DCSB MGM
    Go to a different dealer. The lift will not cause the rack to leak. That dealer just doesn't want to deal with it.
  20. Sep 23, 2024 at 8:51 AM
    GawainXR
    William
    2020 TRD Off-Road
    DashCam
    Or they're trying to milk OP.
    I've not had the best experiences with Toyota dealership service departments though so I'm kind of jaded.
    I'm not sure if it's just the dealers in my area or Toyota dealerships in general but my experiences at Subaru and Ford dealers were always 4-5 star. Toyota has been 2-3
    rolled93slc[QUOTED] likes this.
