Is towing 6500 lbs safe?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OhMyJosh, Jan 10, 2022.
  1. Jan 10, 2022 at 4:32 AM
    OhMyJosh
    OhMyJosh [OP] Member
    Josh
    2018 silver Tacoma TRD Off-Road 4x4
    Hey guys, I work for a construction company and I take most dump trailers to get emptied. And the total weight can be from 3700lbs when empty and up to 6500lbs max. And the dump is about 20 miles away, and I want to keep my truck long term, but I’m not sure if towing that much can be dangerous.
  2. Jan 10, 2022 at 4:33 AM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    I'm going to dump a maxed-out dump trailer every single day and I want to keep my truck long-term are mutually exclusive.
    You need a company truck, my man.
    Chew, hr206, Knute and 8 others like this.
  3. Jan 10, 2022 at 4:38 AM
    Mr.Hustler
    Mr.Hustler Well-Known Member
    2018 Magnetic Grey Metallic TRD Off Road 4x4 [AT]
    It's a secret
    Use your boss' truck for tasks like that. Unless your boss will add additional compensation for future damages/ware-and-tear/maintenance for your personal vehicle, don't do shyte like that just for work...
    Chew, Mattedfred, tacoshell88 and 4 others like this.
  4. Jan 10, 2022 at 4:39 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    It is safe to tow whatever the manufacturer suggests for your truck configuration. A 6500lb single axle trailer with 4000lb tongue weight is a lot different than a 6500lb tandem axle trailer loaded properly with a WD hitch. If you are within the manufacturer specs, towing 20 miles shouldn't cause catastrophic harm to your truck.
    RSOTACO, coma toy and boston23 like this.
  5. Jan 10, 2022 at 4:43 AM
    AntMan408
    AntMan408 Well-Known Member
    Bay Area, CA
    2021 Toyota 4Runner off-road, 2022 Tacoma Offroad
    4runner: King Shocks Front/Rear SPC UCA’s SPC rear control arms Icon Rear Springs 52700 Icon Panhard Bar SCS 10’s RCI Skids and Sliders CBI Baja Bumper w/Diode dynamic lightbar RCI Roof Rack Tacoma: King Shocks Front/Rear Camburg UCA’s Deaver Expedition Stage 1 Leaf Pack SCS Gen 5 RCI Skids RCI Sliders BAMF Hybrid Bumper RCI Roof Rack
    I wouldn’t use my truck (wear, tear, gas and damage) to make someone else money. However what I quoted here is the most accurate answer.
    Mattedfred, Skydvrr and kgilly like this.
  6. Jan 10, 2022 at 4:48 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Yeah I personally would never agree to use my POV for something like that. Being asked to run to a nearby store for some needed supplies is one thing. But being required to regularly tow a maxed out dumpster with your own vehicle is crazy! Find another job brother, plenty of work out there!!
    Chew, hr206, Mattedfred and 4 others like this.
  7. Jan 10, 2022 at 5:00 AM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    Except they’re not weighing that trailer every trip, and it’s being maxed out well beyond its limits, and beyond that weight is beyond his truck’s limits.
    Chew likes this.
  8. Jan 10, 2022 at 5:02 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Your going to have a lot of maintenance and repairs you keep doing that on a regular basis. You better be getting paid pretty good to use your own truck
    Chew, Barsoom and TOMRR like this.
  9. Jan 10, 2022 at 5:04 AM
    jake72
    Jake
    N.E. PA
    Dumps do weigh every load, that’s how they charge
    Mattedfred and boston23 like this.
  10. Jan 10, 2022 at 5:07 AM
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    That all depends on where you're dumping, and no matter the weight at the dump he will have already towed it there. Unless there's a scale on the job site he will be towing without knowing the weight
    Barsoom likes this.
  11. Jan 10, 2022 at 5:08 AM
    Hobadger
    Hobadger Well-Known Member
    Mark
    2021SuperwhiteTRD4×4offroad
    Cold air intake - CAT-BACK
    If you are asking, will it haul, yes, if you are asking will it cut down the lifespan of my personal vehicle, YES!
  12. Jan 10, 2022 at 5:13 AM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    The dump does, the job site doesn’t.
    Chew and Barsoom like this.
  13. Jan 10, 2022 at 5:16 AM
    Finn-2187
    Finn-2187 Well-Known Member
    2021 White Tacoma SR 4x4 DCSB
    Fog lights, Vision Turbine 16x8 wheels, Goodyear Wrangler Ultraterrain 265/75/r16 AT's, janky LEDs that probably won't catch on fire
    I agree with the other comments; you're going to be putting stresses on your equipment that you will absolutely end up paying a lot for, one way or another. I get the impression that whoever owns your company isn't likely to pony up and reimburse you either, given that they're ok with what sounds like an exploitative process such as this in the first place. I wouldn't do it.
    Mr.Hustler likes this.
  14. Jan 10, 2022 at 5:21 AM
    Gutentight
    Gutentight Well-Known Member
    IL
    2021 Cement Off-Road 4x4 DCSB 3.5L AT
    Everyone here is right on with their replies.
    Watch out for insurance also, many policies cover you getting to work, but do not cover accidents or damage from using your vehicle for someone’s business.
    45k x 3yr x 4% = $1,328
    Mileage is standard compensation when using your vehicle for a business. In this case I would tell them only do it for mileage + wear and tear. Say flat rate $1,328 per month, or nothing.
    I assume they will then go buy a (properly sized) 1/2 or 3/4 ton truck to run their business.
  15. Jan 10, 2022 at 5:55 AM
    MidCitiesMildMan
    MidCitiesMildMan Well-Known Member
    2017 Toyota Tacoma Limited
    Stock and staying that way
    It amuses me how only one person actually answered his question. The rest made a supposition and based their response around what was not asked.
    Yes it is safe as long as everything is right. Toyota is pretty smart. Trust their engineers. Follow the hard use maintenance schedule.
    D. Lengua and airforceb2cc like this.
  16. Jan 10, 2022 at 5:55 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    1) You don't mention a brake controller or a weight distributing hitch, both are required for that kind of weight.
    2) Sure you can tow that kind of weight when properly equipped -- doesn't mean it is a great idea.
    3) Yes, it will accelerate wear on your truck and increase maintenance costs.
    4) "Helping out" by going for a part occasionally is fine, using your personal vehicle for Company work on a regular basis is foolish.
    5) Read the first line of your post to your insurance agent, you will be in for an eye opener. If you have an accident your coverage may be reduced/denied.
    Short version: Drive your truck to work, use Company trucks for work.
  17. Jan 10, 2022 at 6:15 AM
    Hobadger
    Mark
    Everybody basically was telling him, what he didn't ask was the most important thing, don't mess your truck up for someone that is making the money, he don't care about you or your truck, or he would invest in one for his business! Also, most everybody I know wants to get a longer lifespan out of their vehicle then them, aforementioned, smart engineers design them for, which only tells you how to maintain up to 150,000. Even if not hauling things it's best to go beyond them smart engineers and flush transmission, change all gear fluids more then recommended!
  18. Jan 10, 2022 at 6:27 AM
    ThreeBeers
    ThreeBeers Well-Known Member
    Ron
    2020TRDOR
    If you are involved in an accident the lawyers are coming after you and not the company you are hauling for. The company will say that you were hauling as a contractor. That is why you insist on using company owned trucks.
    same response no matter what truck you own
    Chew and skeletron like this.
  19. Jan 10, 2022 at 6:28 AM
    GrizzledBastard
    GrizzledBastard OH NO! I've built a Faux Pro!
    Tim
    Central Coast, CA
    '21 TRD OR 4x4 DCLB Super White
    Not enough bandwidth on the internet to list.
    When your transmission fluid lay steaming on the ground and you are stopped in the middle of traffic needing a tow regardless if it is during work time. Will said boss be providing all the necessary mitigation and paying the $5000 to replace the transmission? Therein lays your answer.
    Hobadger likes this.
  20. Jan 10, 2022 at 7:03 AM
    MidCitiesMildMan
    Except none of you have any idea of what he is being compensated.
