is toyota brake fluid green?
Discussion in '1st Gen. Tacomas (1995-2004)' started by keakar, Sep 28, 2016.
  1. Sep 28, 2016 at 8:28 AM
    keakar
    keakar [OP] Well-Known Member
    karl
    louisiana
    just wondering why my brake fluid was green?
    I thought it was just dirty but after replacing master cylinder and doing a full system flush with new fluid I realized the old fluid wasn't dark because it was dirty but that it was dark green in color looking more like 2 cycle oil then clear brake fluid.
    I know people have said that dealers are prone to use colored fluids to tell if owners replace fluids but I just never saw green brake fluid before????????????????
    my truck was from texas originally, then spent time in mississippi if that means anything
  2. Sep 28, 2016 at 8:33 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    the brake fluid the factory puts in is light straw colored
    like all usual brake fluid
    green could be dye used in mineral oil fluids (which would be bad)
    green could be broken down fluid and metal brake system parts
    GREEN=old
    thats all.
    flush it out
    T4RFTMFW likes this.
  3. Sep 28, 2016 at 8:53 AM
    keakar
    karl
    louisiana
    well the master cylinder had a slide issue going on with it randomly binding at times and a stuttering type slippage to get past it if you stand on the pedal so broken down fluid and metal brake system parts sounds the most plausible then since there was no evidence of any rust in the system or any leaks anywhere
  4. Sep 28, 2016 at 9:39 PM
    EJPHI
    EJPHI Well-Known Member
    N CALI
    2003 2.4l 5sp 5 lug
    pt474 cruise control Alpine head unit
    Yeah
    Green looked a little weird to me too. When I bled the system after doing the front brakes, this is what came out:
    The fluid in the reservoir had a slight green shade to it. The green color comes from copper in the brake plumbing. Time to bleed the system.
    keakar[OP] and T4RFTMFW like this.
  5. Sep 29, 2016 at 8:28 AM
    keakar
    karl
    louisiana
    ya, mine was even worse, dark green like 2 cycle motor oil, not even as transparent as yours looks
    I did a google search for "dark green brake fluid" and it seams lots of people are running into finding this green fluid and freaking out
  6. Sep 29, 2016 at 8:52 PM
    EJPHI
    N CALI
    2003 2.4l 5sp 5 lug
    Keakar,
    I see a new master cylinder in your future when I gaze into my crystal ball.
  7. Sep 29, 2016 at 8:55 PM
    Tayoflor
    Tayoflor Well-Known Member
    Taylor
    Woodinville
    2013 DCSB MGM
    Leer topper BAMF weld on sliders BAMF LCA skids Icon stage 4 SCS F5s wrapped in 285/75r16 Cooper Stt Maxx
    There is some brake fluid that is green, I believe it is DOT 4 or higher temp stuff but it's usually only used in "race" cars and such. Can't imagine someone would put that in a Tacoma
  8. Sep 30, 2016 at 6:33 AM
    keakar
    karl
    louisiana
    already done but its still having the random hard pedal issue at times that returns to normal only if i stand on the pedal, then it works fine for a while, so I guess its the brake booster, not sure what else it could be?
    I think you are thinking of DOT 5 fluid which is blue, DOT 3 and DOT 4 is clear.
    Harley motorcycles and I think some European import cars use that blue DOT 5 stuff
  9. Sep 30, 2016 at 8:55 AM
    Indy
    Indy Master of all I survey.
    Next time drain into a mountain dew bottle, you won't even notice the off color :)
    keakar[OP] likes this.
