Is Toyota OEM parts losing quality?
Discussion in '1st Gen. Tacomas (1995-2004)' started by RoscoeTT, Sep 24, 2022.
  1. Sep 24, 2022 at 4:07 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Why didnt u buy the rebuild kit and just rebuild old one?
  2. Sep 24, 2022 at 6:31 PM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 185k
    881/5100/Dakars 4R wheels / TBU / New frame
    Out of curiosity, where did you buy that part? I see other pictures for that part number on Google that show made in Japan. I wonder if they switched suppliers at some point.
  3. Sep 24, 2022 at 7:26 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Unfortunately it's becoming this way across the board, it's not just limited to Toyota or vehicles in general but the majority of everything made today.
    Quality control and build quality have taken a backseat to making things as cheap as possible while still having "enough of it" last "long enough".
    Toyota I think still tries more than some others to produce quality stuff but even they are succumbing to the degrading quality throughout the supply chain.
    Unfortunately it looks like it's just gona get worse as costs continue to rise manufacturers will continue cutting corners and using cheaper raw materials to keep production costs down.
  4. Sep 24, 2022 at 7:31 PM
    leid
    leid Well-Known Member
    Brandon, MS
    1997 V6 Tacoma 4x4 & 2020 V6 Tacoma TRD 4x4
    ECGS & ZUK diffs w lockers/Marlin R150F/NITRO axles/winches
    That CHINA marked Front Tcase seal was purchased from McGeorge in the past few weeks. Another seal package is marked VIETNAM. IIRC another OEM Toyota part was marked MEXICO but I do not remember where it came from.
    EDIT: The MEXICO part was a 90311-A0027 Rear Main seal & the VIETNAM part was a 90311-47013 Front Diff Tube seal. Both were from McGeorge.
  5. Sep 24, 2022 at 7:51 PM
    RoscoeTT
    RoscoeTT [OP] Well-Known Member
    New York
    2002 Toyota Tacoma
    Thanks for all the replies! Some of them cracked me up. I sent an email regarding the tail gate strap not matching the photo but will follow up with something about replacing the manifold now that I know I’m not crazy about those welds. I know MIGs can have some build up but these looked scary!
  6. Sep 24, 2022 at 9:17 PM
    O'Silver_Taco
    MD
    I bought an aftermarket $100 stainless off ebay job...
    Mine has that egr mount/outlet so it can spin and have adjustability, for the alignment of that egr tube...
    I noticed, the one you have is hard welded......could that have alignment issues....
    Mine you get in place and then it locks on back side of that tube when you lock the flanges and gasket together on other side.....
    I'll see if I can snap a pic tomorrow...
    RoscoeTT[OP] likes this.
  7. Sep 25, 2022 at 12:19 AM
    02hilux
    Planet: EARTH
    This been going on for years now. Standard business practice. NOT EVERYTHING IS MADE IN JAPAN BY TOYOTA! Toyota is also a business and want to make a substantial profit like any other business. If they can save 5 buck overall, it's a 5 buck profit in their pocket. The company you work for is doing the same thing.
  8. Sep 25, 2022 at 12:36 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    Toyota outsources parts just like any other manufacturer, and they’re going to look for the best bang for the buck just like anyone else. I don’t get where this idea comes from that Toyota manufacturers every component on their vehicles in house out of magic and rainbow unicorn farts that somehow makes their parts superior to any other. On top of all that with the plandemic causing supply issues, I’m sure all manufacturers had to lower their quality expectations just to get parts.
    p.s. I don’t see an issue with the tailgate cable.
  9. Sep 25, 2022 at 12:53 PM
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    Those welds should embarrass that dealership.
    MalinoisDad likes this.
  10. Sep 25, 2022 at 1:04 PM
    02hilux
    Planet: EARTH
    They're litterily a third party seller regardless. They don't QC every item. Most are drop shipped from warehouse beyond their control. It wasn't manufactured at their location.
    :rofl:
    Clearwater Bill likes this.
  11. Sep 26, 2022 at 8:50 AM
    alarka
    alarka Well-Known Member
    WNC/SE GA
    2k X cab 3.4 5spd
    King ex travel, JBA UCA’s, All Pro Springs/shackles, Locked, all new poly bushings & rack, SS brake & clutch lines, ext bumps for starters.
    Same here I bought a OEM R&P and the thing is trash at about 22K, puking fluid and Tie-rod end is about done.
  12. Sep 26, 2022 at 9:37 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    can you elaborate on this? I use Toyota pink in my truck and have not had any issues. Last coolant flush I did I used aftermarket pink tho (Recochem)
  13. Sep 26, 2022 at 9:58 AM
    O'Silver_Taco
    MD
    Yeah not a fan of the asian stuff.....it was developed to be safe for animals.....period.
    Crazy i know.....why.....why switch from whats worked for 100yrs....
    Over time everything ages....and pinky doesn't do so well....
    It protects by coating everything with a layer of slime.....
    I grant u aluminum is highly reactive at 200 F......so even regular coolant still has to be replace every couple years....
    no short cuts there.....
    I've worked on the ones that didnt do this.....all the aluminum is so corroded its unworkable....
    Its like running well water thru your house without a water softener......fine....for a few years...
    And all this is BS.....if you trade in every ten years......it'lll never catch up with you....
    These trucks pop head gaskets for breakfast.....far too many.....
    and way too many 'crack between valves'...
    Cleaning that stuff out is tuff....takes many flushes....and cold water wont do it....
  14. Sep 26, 2022 at 10:10 AM
    Clearwater Bill
    Billy
    Largo Florida
    You betcha.
    Wonder what will happen when some folks around here learn Toyota oil filters are made by the 'low bidder' for a particular batch. Most likely they are some 'aftermarket' brand painted black and labeled Toyota. Because Toyota sure doesn't make filters. I'm not suggesting the filters are bad at all. Just that they aren't magically freshening your oil.
    vern650[QUOTED] likes this.
  15. Sep 26, 2022 at 10:15 AM
    #35
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I think I used hot water to flush when I changed my rad (pinhole leak at upper plastic portion) but it's been a couple years now so I can't remember lol. I didn't notice much gunk build up but then again I didn't look too hard either. 3.4s don't have HG issues as much as the 4 cyl
  16. Sep 26, 2022 at 10:21 AM
    #36
    O'Silver_Taco
    MD
    And if your using the pink....dont stretch it out for years and years...
    just change it more often..dont go for the record......7 years.....thats got to be one of the biggest jokes ever played on america.......
    Theory is...like dissolves like...right?
    To crash the ship.....it usually takes several idiots in a row to make it happen....
  17. Sep 26, 2022 at 11:24 AM
    #37
    02hilux
    Planet: EARTH
    Yep. Filter is a filter, as long as you change it periodically.
  18. Sep 26, 2022 at 5:07 PM
    #38
    Smokestacks
    Smokestacks Well-Known Member
    BayArea
    1996 3.4L 4x4 Tacoma extra cab MT.
    Eaton Truetac limited slip Bilstein 5100s struts set at 2” 5100s shocks Torch add a leaf B&M short throw shifter Hella h4 headlights Warn front hitch Curt rear hitch Sony DSX-GS900 Deck Custic 1000watt amp Alumpro 10” sub Lund Steel Gullwing tool box Broadway rearview mirror Weather tech window deflectors
    Gawd dam that is bad. You got to be trolling. I don’t see how that could get worse without having functionality defects.
  19. Sep 26, 2022 at 5:14 PM
    #39
    Mallrat60
    Mallrat60 Not all of us in CA are libs.
    Nor-Cal, Sacramento area
    2015 Dbl cab L/B 4X4
    ADS 2.5 #700 springs, RCI metal fab full skids, JBS UCA, OME rear leaves, Fab Fours front, and rear bumpers, BAMF Rock Sliders and other stuff
    Counterfit Parts????
  20. Sep 27, 2022 at 5:12 PM
    #40
    DaveCanuck
    DaveCanuck Well-Known Member
    Dave
    Canada
    2011 SR5 V6
