Is Transmission Temp Check Mode Necessary?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacotoosdays, May 15, 2024.
  1. May 15, 2024 at 11:22 PM
    999
    999 Well-Known Member
    Texas
    FYI - On my 2021, I was trying to use a jumper wire to get it into temp mode. Took me a little while to realize that year doesn’t need the jumper to go into trans check mode. I’m wondering if a 2020 was the same and maybe why it was hard to get into.
    Regardless if you have a scan tool it’s easier.
  2. May 16, 2024 at 6:50 AM
    tacotoosdays
    tacotoosdays [OP] Member
    2020 TRD Off Road
    The 2020 doesn't need the jumper wire but I still had issues getting it to work. I watched a couple of videos including the Car Care Nut.
  3. May 16, 2024 at 7:00 AM
    SilverTRD Sport
    SilverTRD Sport Well-Known Member
    Houston, TX
    2016 TRD Drowned now 2017 Inferno TRD Sport
    That was my next question. Thank you
  4. May 16, 2024 at 7:08 AM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Now that i’ve done drain and fill a couple times and know its at the right level,’ i was thinking of just adding the same volume that drains out and not checking the overflow plug….
    After the factory level question is answered, if you drain 2.5….add 2.5 lol
  5. May 16, 2024 at 7:14 AM
    Pungo1
    Pungo1 Well-Known Member
    Mark
    That makes perfect sense to me. That's exactly why someone will post that I shouldn't do it that way because of this or that. They'll be right and I'll once again go back to electronics and databases where my expertise really is and leave this to the experts. LMAO!
  6. May 16, 2024 at 10:14 AM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    It matters a lot. The difference between check temp and normal operating temp fluid level is significant.
    For some reason ATF expands much, much more than motor oil. I don’t know the specifics as to why but it does.
  7. May 16, 2024 at 10:28 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Negative.
    I can confirm this.
    I think my external IR reading 5° under the gauge.
    Plenty close enough.
  8. May 17, 2024 at 8:11 AM
    tacotoosdays
    2020 TRD Off Road
    I was reading the official service procedure. It's really confusing. Even if you use Techstream they still want you to put it into temp check mode??? Makes no sense. The other thing I noted was this in regards to disconnecting from Techstream:
    "Be sure that terminals TC and TE1 are not connected. If the terminals are connected, the fluid level cannot be precisely
    adjusted due to fluctuations in engine speed. Disconnecting terminals TC and TE1 activates engine idle speed control mode."
    The Car Care nut says a scan tool is fine so that's what I'll do but it's interesting that the service manual wants you to do both. This is what gave me pause about temp check mode.
  9. May 17, 2024 at 8:43 AM
    Captain Dirty Beard
    Captain Dirty Beard Well-Known Member
    Colorado
    2023 Ice Cap Tacoma TRD Off Road
    OTT tune
    even 10 degrees isn't really significant. If your gun reads 100-105, do the proceedure and call it good. Were only talking about a few ounces difference here
