Is TurboTax worth it?
Discussion in 'Off-Topic Discussion' started by jeremy_283, Feb 10, 2012.
  1. Feb 10, 2012 at 6:40 AM
    jeremy_283
    jeremy_283 [OP] Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
    Does it really find many "extra" deductions that a seasoned tax preparer couldn't find using long-hand?
  2. Feb 10, 2012 at 6:42 AM
    carcharias
    carcharias Giggiddy what what
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    Kings all-around w/ 700lb coils, Dakar leaf pack, TC uca's, DO single hoop bumper, BAMF bolt-on sliders w/ kickouts, Rigid 20" e-series spot/flood, aFe pro-dry, BFG KM2 255/85/16, silver TRD FJ wheels, WARN M8000-s, Access LE, Grillcraft, BAMF lightbar, BAMF rear dif skid, BAMF LCA skids, window tint, Wet Okoles, WeatherTech floorliners, Silverstar lights, led dome lights, Redline Tuning hood struts, center console lock mod, mag-lite mod, extra d-rings, re-routed exhaust, ATO skids, ATO Hi-Lift mounts, pipe tailgate lock, seatbelt alarm delete, wheel/spare locks, Viper 5901, LoJack... WISHLIST: a golden canary that poops platinum
    I've used it over the last 8 years, and it's easy. Finding extra deductions? Not sure, but it does cost less than a tax preparer and I have yet to be audited (knock on wood).
  3. Feb 10, 2012 at 6:45 AM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Not sure about finding any "extra" deductions, but it makes doing taxes super easy. I've been using it for at least 7 years now.
  4. Feb 10, 2012 at 6:46 AM
    pa blaster
    pa blaster Well-Known Member
    Scott
    central pa
    2024 GMC Canyon AT4X AEV
    yep i got an xtra 4hundred more than i thought back not much but it helps:thumbsup:
  5. Feb 10, 2012 at 7:03 AM
    jeremy_283
    Will the free version work fine?
  6. Feb 10, 2012 at 7:04 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Fed is usually free and then they charge you for state and then a processing fee.
  7. Feb 10, 2012 at 7:05 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I think it's worth it. I use it every year.
  8. Feb 10, 2012 at 7:08 AM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    I used turbota for the last 2 years. They charged me like 30-40. Then this year, I started my return with them, didn't pay, then saw what my return was. $1497. Then I did the free HR block, same return, $1497. HR block was free, turbotax was i think $40. And yes i had deductions, a few 1099's, 2 W2's.
    HR > TurboTax
  9. Feb 10, 2012 at 7:08 AM
    pFunk6983
    pFunk6983 Active Member
    Troy
    Fayetteville, NC
    2011 MGM DCSB Sport 4X4
    Since you're only 21, it probably won't find a lot of deductions for you unless you own a house or have investments, but it's still easy to use and can get a quick refund.
    As for comparing it to a person, just depends on the how thorough and knowledgable the person is.
  10. Feb 10, 2012 at 7:10 AM
    jrdbrn
    jrdbrn Well-Known Member
    Jared
    Louisiana
    '21 TRD Off Road
    I did both and liked HRBlock more. Easier and received a few more dollars.
  11. Feb 10, 2012 at 7:12 AM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    I use H&R block online. Free and easy. Only time it costs money for fed return is if you have stuff like capital gains from investments and stuff like that. I used to be an accountant(albeit not public) and I still use this rather than manually doing my return.
    Now if you need to see an actual tax preparer I'd never go into an H&R block place I'd stick with an actual CPA for that.
  12. Feb 10, 2012 at 7:13 AM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    i've used it for the past 5 years... my returns are pretty simple, so i'm not too worried about it finding all these crazy deductions or anything, just like it because it only costs like $20 and i can e-file and all that good stuff. just submitted my taxes with turbotax last night actually...
  13. Feb 10, 2012 at 9:54 AM
    North Star
    North Star I keep planets in orbit
    Cali
    07' Double Cab 4x4
    N-fab side steps, Extang hard tonneau cover, Terra Grappelers
    Turbo Tax will actually let you do a step by step to explore all deductions if you want. This is tedious, but if you know what you are looking for it's rather quick.
    I plan on doing mine this weekend.
  14. Feb 10, 2012 at 9:57 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I've been using it for the last 10 years. I've never been audited.
    I have been itemizing for the last 4 years since I bought my house and used it for my sole proprietorship business for the last 2 years. It's very easy to use. I can't speak to more money back because I have nothing to compare it to, I've been using Turbotax since I turned 16 and started working.
    I did my taxes about a month ago and have had my refunds for a few weeks.
  15. Feb 10, 2012 at 10:03 AM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    You won't find "extra" deductions when using a legitimate CPA. They just know what you are eligible for.
    Turbotax will guide you through that process.
  16. Feb 10, 2012 at 10:47 AM
    North Star
    Cali
    07' Double Cab 4x4
    Good to hear. I just bought a house in Novermber and have money set aside for my 10% penalty for dipping into my retirement money to buy the house. I think as long as I plug in everything with the tax documents I have received, I should be good to go.
  17. Feb 10, 2012 at 11:28 AM
    elmo7
    elmo7 Easily Replaceable Member
    SC
    07 DC TRD OR 4x4
    Frak no - TT is too expensive, IMO. You can find cheaper versions that perform just as well. I use Tax Act online. Easily half price for me or better, as I have to file multiple states. States are the killer. You can use TA for free and not pay until the end when you want to print/file.
    Maybe I need to check that H&B Block free!
  18. Feb 10, 2012 at 11:55 AM
    396tears
    396tears Well-Known Member
    I have used Turbotax since it came out.
    I used to do my taxes by hand at the kitchen table years ago.
    With 3 kids in school and and all of them working part time plus all my tax
    schedules and such,
    I sure learned a lot and spent a lot of nights doing taxes with
    all the forms and instruction booklets from the IRS
    and of course a calculator and lots of scratch paper.
    Turbotax was a huge relief.
    If you plan to purchase it buy the Amazon download.
    It is by far cheaper than in stores and no sales tax and no shipping
    (if you qualify).
  19. Feb 10, 2012 at 11:56 AM
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '23 DCSB 4x4 SR5
    We use it! Makes taxes simple lol
  20. Oct 22, 2013 at 10:32 PM
    cherylwalden
    cherylwalden New Member
    Cheryl
    2539 Massachusetts Ave NW, Washington, DC 20008
    07 PreRunner
    I have been using Turbo Tax from a long time now, like 5/6 years maybe, it has always made my tax filling easy and convenient. Although I prefer buying the software rather than going for the free online one as I always have insecurities about the free one being infected with malicious data or that it has any hidden costs or if it can be a data collection stunt online, but yes to save some money I do use those online available turbotax coupon while buying which does makes a difference.
