Is VIAIR the portable compressor to get?
Discussion in 'Recovery' started by alexh, Nov 13, 2017.
  1. Dec 1, 2019 at 4:48 PM
    #81
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Well, this is a truck forum, and all those tests were performed on car tires. I highly doubt any of these compressors would fair that well against even a stock sized truck tire.
    I consider anything from Harbor Freight to be "single use" tools. If all you need is something to use, maybe once or twice in an emergency, yeah, it'll probably work for you.
    But if you want something that you know will work time and time again, the 88p is easily the best choice to get. And at ~$65, it's not even that expensive. For off-roading, I'd definitely recommend going to the 300p or 400p. I have the 400p and it's great.
  2. Dec 1, 2019 at 4:49 PM
    #82
    uptaco
    uptaco Well-Known Member
    Adam
    Pittsburgh, Pennsylvania
    '19 Cavalry Blue OR 6A DCLB
    Fair enough. First time new truck owner here... :notsure:
  3. Dec 2, 2019 at 12:07 PM
    #83
    xguntherc
    xguntherc Taco Time
    Cory
    East Dallas
    11 TRD Off Road - Black
    Icon Stage 5, Nexen Roadian MTX, Fuel KB43 Block wheels, Baja Design XL 80s, Baja Squad Pro WC fogs, TacoVinyl grill, "dudebro" lights, Prinsu rack, trail rash pinstripes, BAMF hybrid bumper, sliders, and LCA skids, and a few other things I can't think of.
    True true.. That said, the 88p gets a lot more than "warm"... It gets so unbelievably hot that it's dangerous. If I grabbed the top of it after topping off 2 tires, I would absolutely get a 2nd degree burn on my hand. But ur right, that's my fault for getting something not rated for a big truck tire. I guess the point I'm trying to make is I see a lot of people here recommend the 88p for our trucks. And while it's a nice affordable option, it's in no way what I'd "recommend" anyone buy. The bigger better Viair's, absolutely, but not the 88p.
    CaliTaco718 and jbrandt[QUOTED] like this.
  4. Dec 9, 2019 at 8:13 PM
    #84
    slick7108514
    slick7108514 Well-Known Member
    Arizona
    2018 White Tacoma TRD Offroad DCSB
    I have the Viair 88P and it gets the job done, but definitely not the best unit out there. It will fill 31" tires from about 15psi-35psi in about 15-20 minutes, but it will consistently blow fuses if you attempt to inflate an extra set of tires. Also the unit gets scorching hot and it's a PIA to reach the RR tire with the equipped air hose. I would probably spend the extra coin and get a better unit if you're in the market.
  5. Dec 9, 2019 at 8:20 PM
    #85
    eon_blue
    Azusa, CA
    I upgraded to the 300p after using the 88p for a couple years, I love it. Highly recommend. Doesn't get as scorching hot and I've yet to blow a fuse on it. Blew a few fuses on my 88p. And it's almost twice as fast on my 33" tires going from 15psi to 35psi
    jbrandt and TacoNorth76 like this.
  6. Dec 18, 2019 at 12:40 AM
    #86
    Ivilla23
    Ivilla23 Member
    16 trd off road
    Just used mine for the first time this past weekend, great device. Filled up right around 10min
  7. Dec 18, 2019 at 1:45 AM
    #87
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    Fishnwiz likes this.
  8. Jan 7, 2020 at 10:05 PM
    #88
    jp59inh
    jp59inh Well-Known Member
    02 Tacoma Extra cab 4x4
    None yet
    I have one and after 3 years and many many uses it needed a new cylinder and piston. I took it to Viair and they completely disassembled my compressor , double checked every part , installed a new cylinder and piston kit , and gave me a info sheet on all the parts . When i went to pick it up they didnt even charge me !!!! I was super stoked , needless to say I highly recommend them.
    Marc70 and trailbound like this.
  9. Jan 13, 2020 at 3:56 PM
    #89
    jbrandt
    Justin
    That's some serious customer service right there!
