Is your 4.0L V6 "cold blooded"?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MassTaco, Nov 2, 2009.
Winter warm up - how long does it take your truck to come up to fulll operating temp?
Poll closed Dec 2, 2009.
  1. Idle for 1 minute, then 1 - 2 miles at speed
    17 vote(s)
    29.3%
  2. Idle for 1 minute, then 2 - 3 miles at speed
    15 vote(s)
    25.9%
  3. Idle for 1 minute, then 3 - 4 miles at speed
    7 vote(s)
    12.1%
  4. Idle for 1 minute, then 4 - 5 miles at speed
    9 vote(s)
    15.5%
  5. Idle for longer than 1 minute
    10 vote(s)
    17.2%
  1. Nov 2, 2009 at 6:02 PM
    jandrews
    '09 FourDubDee TRD OR
    Just a thought:
    Is everyone remembering to air up for winter? As weather gets colder, the air in your tires will lose volume and you will lose tire pressure. You should remember to air up in late fall and air down in spring. My tires were at 32 psi two weeks ago and read 29 psi yesterday, temps being about 20 degrees cooler. I check tire pressure weekly, so its less of an issue for me, but you gotta watch tire pressure closely during fall/spring to maintain your fuel economy.
    Er...small engines typically warm more quickly, because there's less metal present to dissipate the heat and less surface area for air cooling...
  2. Nov 2, 2009 at 6:17 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    I park my truck in the garage. I drive six miles to work. It takes about half that distance to get up to temp. It has been in the upper 30's in the morning around here.
    I loved the climate control on my Accord. It would not blow air until it reached the temperature that the climate control was set at.
  3. Nov 2, 2009 at 7:15 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    Scangauge? that is what I use for engine temp
  4. Nov 2, 2009 at 7:54 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    try nitrogen in the tires
  5. Nov 2, 2009 at 9:58 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    rofl!!!
