IS300 Help
Discussion in 'General Automotive' started by whippersnapper02, Jun 10, 2011.
  1. Jun 10, 2011 at 8:55 PM
    whippersnapper02
    whippersnapper02 [OP] Well-Known Member
    Christian
    Yorba Linda, CA
    10 MGM TRD OR 4wd Auto DCSB
    Banks Monster Exhaust, Pop n Lock tailgate lock, Hook-Ups tie down brackets, USA Spec Ipod adaptor, WO seat covers, color matched grill with Grillcraft insert, Tuffy locking bed box
    A co worker is having problems with his 01 Lexus IS300. It is throwing a CEL for code P1129 for the Electronic Throttle Control System. It seems like a general code for the whole system not a part of it. They can't drive the car as is since the throttle does nothing. Anyone experience something like this themselves or have heard of this issue? I know I can join a Lexus forum but I will try that as a last resort. Thanks.
  2. Jun 15, 2011 at 9:56 PM
    2TRunner
    2TRunner Don't give up here just yet
    Around To Many People
    1, 2, 3, 4, 5 Lugs
    Brute Force Bumpers: rear & custom front tube, Saw-A-Way Racerunner 2.5 Coilovers with Total Chaos UCAs. Icon AAL.
    Throttle position sensor bad??
    From what I understand, most E.T. use two readings to..do their thing. One setting is from 0 to 5 volts and increases as the pedal is pushed, the other goes from 5 to 0 volts and decreases as the pedal is pushed.
    The 2 signals have to "agree" with each other before they will act on the throttle. One should increase the voltage a certain amount under acceleration, the other will decrease voltage during acceleration.
    The computer looks to see that the changes in both are equal and then changes throttle positon(s)
  3. Jun 15, 2011 at 9:59 PM
    whippersnapper02
    Christian
    Yorba Linda, CA
    See here is the thing with this car. It still has a throttle cable and it uses a stepping motor for a butterfly valve. It is a hybrid system from what I have been reading. My co worker purchased a whole throttle body with sensors and he is going to try bolting it onto the car. It is nice working next door to LKQ.
  4. Jun 15, 2011 at 10:04 PM
    2TRunner
    1, 2, 3, 4, 5 Lugs
    Hmmm...well that makes it more interesting!
    I'll jot the info down and take a looksee on Alldata, see what kind of testing it may call for.
  5. Jun 19, 2011 at 2:05 PM
    2TRunner
    1, 2, 3, 4, 5 Lugs
    Ahh..back to this.
    Well, I'll start off by saying that I wish I could get one of those IS300s into my shop for the same code. Easy money.
    1129- Throttle opening angle continues to vary greatly from target TOA
    Area: Electronic Throttle Control System, ECM.
    This has to be the greatest test for a code, ever. There is one step.
    -Are any other codes present?
    --Yes: Diagnose/Repair other codes first.
    --No: Replace ECM.
    ---Does DTC occur again?
    ---Replace Throttle Body.
    But why the ECM first???...It's cheaper.
    ECM = 924.49 (0.6 Labor Hrs)
    ETB = 1,0005.77 (1.4 Labor Hrs)
    So, put a new computer in it.
    Comes back again, put a throttle on it.
  6. Jun 19, 2011 at 4:38 PM
    whippersnapper02
    Christian
    Yorba Linda, CA
    Damn. Well I will see what happens Tuesday. He has a mechanic that he takes his vehicles too but so far he is stumped too.
  7. Jun 19, 2011 at 4:51 PM
    2TRunner
    1, 2, 3, 4, 5 Lugs
    Alldata was pretty short and to the point on this one, one of the 2 should fix it. I'll look again, see if there is any specific test for any component to single it out.
    I'd try the TB first myself, at least you don't have to end up taking it to Lexus so they can reprogram it. And you might be able to pick up a TB from like junk yard or something.
  8. Jun 19, 2011 at 4:57 PM
    whippersnapper02
    Christian
    Yorba Linda, CA
    He was able to pick one up from LKQ for $100ish with a money back guarantee.
  9. Jun 19, 2011 at 5:00 PM
    2TRunner
    1, 2, 3, 4, 5 Lugs
    Hell of a lot better than 900+
  10. Jun 19, 2011 at 5:04 PM
    whippersnapper02
    Christian
    Yorba Linda, CA
    Oh hell yeah. He is hoping that he doesn't have to take it into Lexus. Everytime he thinks about buying a Banks power package for his V10 F250, one of the other vehicles needs something.
    Thanks for the help man.
  11. Jun 20, 2011 at 2:07 AM
    2TRunner
    1, 2, 3, 4, 5 Lugs
    Sounds like your buddy needs a 4 banging Taco...V10/250, IS300 w/2JZ...Trade em' both in on a Pre-Runner!
    Gonna suck if he needs a new ECM. Gonna have to go to Lexus to program it.
    Do what I did though. Install new ECM, take old ECM, hook it up and set it somewhere off to the side under the hood and drive that bitch to the dealer.
  12. Jun 21, 2011 at 4:07 PM
    whippersnapper02
    Christian
    Yorba Linda, CA
    So apparently there was two codes. They changed the TPS and one code went away but the 1129 code is still there. He also says that he hears noises from the passenger side kick panel where the ECU is located.
  13. Jun 21, 2011 at 4:52 PM
    2TRunner
    1, 2, 3, 4, 5 Lugs
    Noises? What kind of noises?
  14. Jun 21, 2011 at 4:53 PM
    whippersnapper02
    Christian
    Yorba Linda, CA
    He said it sounds like a desktop computer thinking. I said there is no hard drive in vehicle ECUs.
  15. Jun 21, 2011 at 5:12 PM
    2TRunner
    1, 2, 3, 4, 5 Lugs
    Well thats no good.
  16. Jun 21, 2011 at 5:23 PM
    whippersnapper02
    Christian
    Yorba Linda, CA
    It should sound like popcorn not a hard drive huh?:D
  17. Jun 22, 2011 at 1:51 AM
    2TRunner
    1, 2, 3, 4, 5 Lugs
    Just wait until it starts smelling like burning/melting plastic, then that noise will probably go away.
    Got a buddy at work who could probably fry that ECM like an egg for ya.
    He sure managed to fuck up a Sequoia. Did a water pump, it ran for a minute then he shut it down and it never started again. They sent it to Toyota thinking it was a security thing...naw...the cam sensor wire(s) were caught/pinched between the water pump and block. Me hopes he's on the road to getting fired, no one likes him.
  18. Jun 22, 2011 at 6:33 PM
    whippersnapper02
    Christian
    Yorba Linda, CA
    So Quake, does Alldata show the location of the computer? LKQ is telling my co worker that the ECU is behind the driver side headlight. I'm not sure where it is.
  19. Jun 22, 2011 at 10:35 PM
    2TRunner
    1, 2, 3, 4, 5 Lugs
    I'll check it out today.
  20. Jun 22, 2011 at 10:44 PM
    whippersnapper02
    Christian
    Yorba Linda, CA
    I know I can always go look but I had no time today. Thanks man.
