ISO a more aggressive tire, with similar ride quality / MPG to stock
Discussion in '3rd Gen. Tacomas (2016+)' started by 18TRD_OR, Apr 14, 2018.
  1. Apr 14, 2018 at 12:22 AM
    18TRD_OR
    18TRD_OR [OP] Active Member
    Dennis
    [Current] 2018 Silver TRD OR DCSB 4X4 [Traded] 2017 Black SR5 DCSB 4X2
    [Current] Black-Out Emblems, WeatherTech, removed pin stripe, MORE TO COME. [Old] 265/75/16 BFG K02, Predator rails, 2" RC Level, TRD Pro Grill, Painted rear bumpers black (replaced chrome), tonneau cover, WeatherTech mats, air dam removal, full stereo upgrade (minus HU), Black out emblems, removed pin stripe. Traded for 4X4.
    On my 17 SR5 I switched to a 265/75 (or 70)/16 BFG K02 E load range. The ride was miserable, noise was fine, MPG also dropped to around 17 average for winter.
    I just upgraded to an 18 TRD OR with the wrangler goodyears, and the ride is way better, and I'm not sure how much the suspension has to do with this. But I'm also averaging around 21-22 MPG again, but I want a better looking, more aggressive tire. I really want to keep the ride quality if possible, keep my MPG, but have a slightly more aggressive and capable tire. It doesn't need to be on the same level as the K02's.
    I saw someone recommend the duratrac in a C load, but I couldn't find any clarification on ride quality and MPG.
    Opinions please!
  2. Apr 14, 2018 at 3:21 AM
    TheyCallMeBruce84
    TheyCallMeBruce84 Well-Known Member
    NC
    2017 Silver DCLB TRD Sport 4X2
    I'm sure others will chime in but I've done a bit of tire research lately.
    Regarding your BFG K02s, the difference between C load rated (6-ply and 32lb weight) vs. E load (10-ply at 50lbs each) that difference in rotating weight, no doubt, contributed to your 17mpg on the SR5.
    A "better looking/more aggressive" tire is out there, I'm sure, but you'll no doubt pay for it at the pump...the gift that keeps on giving. It all boils down to your truck usage/application and budget.
    Since I'm driving a TRD Sport any specific brands/models that i'm looking at wouldn't be ideal for your TRD OR, so I'll run silent and let the 4x4 crowd take it from here.
    crashnburn80 and hiPSI like this.
  3. Apr 14, 2018 at 3:55 AM
    NOLAMedic
    NOLAMedic Well-Known Member
    2018 Quicksand DCLB TRD Off Road
    Vanity > comfort
  4. Apr 14, 2018 at 5:18 AM
    Comb
    Comb Well-Known Member
    2017 TRD Sport 4x4 DCSB 6MT BBP ABCDEFG
    OVTune Verified Purchase
    Falken Wildpeak A/T3W in SL load. Size will have a huge impact on fuel economy, so stick with the stock size if that's a concern.
    bsp_taco, Robb_D, shakerhood and 3 others like this.
  5. Apr 14, 2018 at 5:37 AM
    iPaint
    iPaint Well-Known Member
    Nebraska
    2017 TRD OR DC 4x4 AT
    Check out Hankook Dynapro ATM. I have had P265/70R17’s for 16k miles and they have treated me well so far.
    MY50cal and Robb_D like this.
  6. Apr 14, 2018 at 5:48 AM
    BillsSR5
    BillsSR5 Well-Known Member
    bill
    2014 SR5
    MICHELIN DEFENDER or AT2 , the search is over
  7. Apr 14, 2018 at 6:25 AM
    hiPSI
    hiPSI Laminar Flow
    Appalachians
    2017 4WD DCSB Gray
    Exactly right.
    I got Cooper AT3.
    Truth: If you want to keep the mpg, you cannot go even mildly aggressive tread like Duratrac. You can't go much wider or bigger or heavier either. Also needs to be a P or SL rated. Or you can lose efficiency and get what makes you feel good.
    If you read where someone went bigger and heavier and more aggressive and kept the same mpg, that person does not know how to calculate mpg.
  8. Apr 14, 2018 at 6:40 AM
    trdt44
    trdt44 Well-Known Member
    Utah
    2017 Tacoma TRD OR
    I have the Duratracs in 265/75/16 (C load rating) on my 17 offroad. I have not noticed much difference in ride quality over the stock goodyears. I have adjusted the air pressure to maximize tread life and ride quality. My mileage has dropped about 2 mpg. I can still get 22mpg if I keep it below 70mph. I commute about 60 miles a day.
    This is my 4th set of Duratracs which have been on multiple vehicles. They are perfect for what I do.
    Eta. This is all hand calculated. It is important to note that a large percentage of my miles are on the freeway.
    GoodOlBoy and 15+1 like this.
  9. Apr 14, 2018 at 6:48 AM
    Crimson Flam3s
    Crimson Flam3s Well-Known Member
  10. Apr 14, 2018 at 6:50 AM
    jsinnard
    jsinnard Crawl Control and longbed? I has it
    Virginia
    04 DCAB 4X4, 16 QS DCLB OR 4X4
    Ive got 30k on my Nitto Terra Grapplers G2s and have been pleased with the tires so far. I average a 40 mile round trip daily commute, size is 265/70/17 C load and I average 20-22 mpgs if I keep it below 70 mph.
    It's not crazy aggressive but good enough for my tastes.
    rmepilot, TBV, Spare Parts and 3 others like this.
  11. Apr 14, 2018 at 6:59 AM
    15+1 Well-Known Member
    Arvada, Co
    2017 AC TRDOR
    Recently replaced the stockers with Duratracs in 265/75 16 "C". So far, I love them. Running them at 40 psi, they ride great and are returning slightly better mileage than the stock wrangler adventures which I ran at 35 psi. Couldn't be happier! My winter mileage in the city is a consistent 19 and 21 highway.
    Robb_D, MandosTaco, TBV and 3 others like this.
  12. Apr 14, 2018 at 8:25 AM
    18TRD_OR
    Dennis
    Lots of great ideas. The looks are good, and some good news about the mpg and ride. But the big thing is capability. Some of the tires look like they have a similar tread pattern / size to the stock. I’ve read and watched videos that these type of tires are the biggest drawback to the stock truck. So the falken at3w, the g2s, and duratrac are catching my eye. Thanks.
  13. Apr 14, 2018 at 8:38 AM
    Matt3400
    Matt3400 Well-Known Member
    2017 Magnetic Gray TRD Off-Road
    STOCK!
    Really can't go wrong with either of those tires. Like others have said stay in SL or C load rating to keep weight down.
  14. Apr 14, 2018 at 9:11 AM
    Mikeybuck
    Mikeybuck Well-Known Member
    SW WA
    2018, 2010, Tacoma
    The stock offroad tires really are not a bad tire.
    I did replace mine with c rated duratracs and no difference in ride quality that I can tell. Only difference was mpg loss.
  15. Apr 14, 2018 at 9:14 AM
    Joe23
    Joe23 Technically, alcohol is a solution
    Joe
    The Great White North
    2017 Off Road DCSB MGM
    Check build thread
    So a unicorn? When you find it let me know.
    I had the duratrac in a c rated 265 70 17 it didn't hurt to much but still lost some mpg. Ride was smooth but a little noisy no louder than a ko2 with some wear on it.
  16. Apr 14, 2018 at 9:16 AM
    Tacothegreat
    Tacothegreat Member
    Camilla Ga
    2018 White Tacoma SR5 XP
    Get some Goodyear Kevlar Mt and never look back. Aggresive, quiet, and light which will keep your mpgs up.
  17. Apr 14, 2018 at 9:20 AM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Pacific Northwest
    2018 OR DCSB 4x4
    I've never had a worse tire than the Duratracs I had on my 2nd gen. I had C rated. They couldn't ever get balanced. Traction started off good but quickly wore off. They looked like they had a ton if tread, but spun easily when wet and winter traction was awful after about 8k miles. The longer they're on the louder they get. Would never get again.
    BillsSR5 likes this.
  18. Apr 14, 2018 at 9:20 AM
    lcarrasco212
    lcarrasco212 Active Member
    Toyo at or nitto terra grappler in same rating as factory is what I want to go with. I feel they are more “all terrain” balanced. Duratracs are an aggressive all terrain. The stock wranglers are a very mild all terrain
  19. Apr 14, 2018 at 9:21 AM
    Syncros
    Syncros Well-Known Member
    Hankook Dynapro ATM, P265/75R16.
  20. Apr 14, 2018 at 9:25 AM
    Madtown
    Madtown Well-Known Member
    Eric
    Madison,WI
    16 Tacoma OR Quicksand
    Ray10's, Fox TRD Pro suspension
    Look at the Yokohama G015 as well.
    Robb_D and Pot_Lickr like this.
