Issue after installing BS 5100 & rear blocks-NEED HELP!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mynameissean123, Mar 20, 2019.
  1. Mar 21, 2019 at 9:22 AM
    #41
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Sierra Denali Ultimate, 6.2
    A few additions to make me feel cool.
    Man you guys are giving this poor guy the run around. OP you should always measure from the center of the hub to the body panel to get your lift measurements. Also this is a very common and known issue. Install this on top of your driver side front strut. That is the only way you will remedy this issue.
    mynameissean123[OP] likes this.
  2. Mar 21, 2019 at 9:27 AM
    #42
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Huh? Yes, pointing someone in a direction to throw money at a problem on a different part of the truck is the right answer.
    We did mention the measurement location and the front strut spacer won't help if your "lean" is only found at the back of the truck where the leaf (nothing to do with the coil) supports the weight of the truck. His issue is with leafs not supporting equal weight.
    lo2hi and AverageGuy like this.
  3. Mar 21, 2019 at 9:30 AM
    #43
    JJ Customs
    Jay
    NV
    As someone who has dealt with this on three Tacoma's the front strut does in fact control this issue though you see it in the rear. I am not going to argue a point that everyone who has dealt with this issue has figured out. Adding the spacer to the front drivers shock tower loads the suspension and takes the load and equals the truck out. It is not throwing money at it, it is in fact spending $10 on the correct solution while you all who do not understand this have the poor man chasing his tail.
  4. Mar 21, 2019 at 9:31 AM
    #44
    zippsub9
    Halfmoon, NY
    14 DCLB
    The supreme leader has spoken, just like a Marine.
    Good luck OP
  5. Mar 21, 2019 at 9:31 AM
    #45
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    What size and tire rating? I run 265/70/17 Toyo open country at2 SL rated. I think the c rated or even e would be a lot worse
  6. Mar 21, 2019 at 9:34 AM
    #46
    JJ Customs
    Jay
    NV
    Just been there before. My military background does not play into this equation but you seem to have a very army point of view. Remember when things get though you boys normally call us so perhaps we should take this one from here.
  7. Mar 21, 2019 at 9:40 AM
    #47
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    JJ Customs[QUOTED] likes this.
  8. Mar 21, 2019 at 9:41 AM
    #48
    JJ Customs
    Jay
    NV
    LOL, you be quiet now. We will let you know when we need a ride. You are supposed to have my back dude, the USMC is a department of the Navy. The men's department! JK...
    lo2hi likes this.
  9. Mar 21, 2019 at 9:45 AM
    #49
    JJ Customs
    Jay
    NV
    Look, I know it sounds crazy that by adding a spacer to the front you will equal out the truck but it works. Toyota actually runs a heaver spring on the drivers front to combat this from the factory to compensate for the battery and fuel tank. When you swap that out with a spring that is the same rate as the passenger side it carries over to the rear. I did the same thing, front was level and I could not wrap my head around adding a spacer to the front where I did not have an issue but I finally listened and added the spacer and it brought the rear up. and somehow the front even remained correct. It has to do with the way it loads the suspension. I am not trying to sound like a dick or be an asshole but that is how you fix this problem.
    Furthermore it does not affect all trucks the same. Some do not need it but others do. My last Tacoma was off by about an inch in the rear when my 07 only needed the OME trim packer on the bottom of the OME spring perch. Each truck seems to be different and that is why so many get the run around on fixing it.
  10. Mar 21, 2019 at 10:10 AM
    #50
    VaToy
    Parts Unknown
    The shop in my area who is very well respected did my lift with 5100s, 1/4 shim an the ECGS clamshell bushing. The did a one inch block and it fixed my taco lean, rides great and no vibrations what so ever. Their words exactly " our trucks don't vibrate". I was happy with their advice and the advice you the OP are receiving here. Good luck!
  11. Mar 21, 2019 at 10:44 AM
    #51
    mynameissean123
    mynameissean123 [OP] Well-Known Member
    Sean
    2019 Tacoma Off Road
    Of course I forgot to measure before hand. That’s what I was thinking as well, maybe they moved? Not sure
  12. Mar 21, 2019 at 10:44 AM
    #52
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Just leave a positive review on uber and I'll try not to hit any other ships. Or continants.
  13. Mar 21, 2019 at 10:45 AM
    #53
    mynameissean123
    Sean
    Tha is for this, I took everything back apart last night to make sure I didn’t do that. But it was there
  14. Mar 21, 2019 at 10:48 AM
    #54
    mynameissean123
    Sean
    I’m reguards to the e-brake? I did. Can’t believe that effects it sometimes
  15. Mar 21, 2019 at 11:50 AM
    #55
    JJ Customs
    Jay
    NV
    LOL!! That was an awesome response.
  16. Mar 21, 2019 at 12:40 PM
    #56
    mynameissean123
    Sean
    Just swapped the front struts hoping that would do something, but still the same. I’m going to order that spacer and hope that solves it
  17. Mar 21, 2019 at 12:41 PM
    #57
    mynameissean123
    Sean
    Ordering it now. Thanks
  18. Mar 21, 2019 at 12:43 PM
    #58
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    1 inch blocks wont cause issues with ride quality
    VaToy likes this.
  19. Mar 21, 2019 at 12:51 PM
    #59
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Did anyone mention that the dust covers on the rear shocks slide around on the shock body by themselves? Don’t compare them for height.
    Maybe Taco Lean was intentional - it’s to counteract the lean from the awesome torque of the engine! :)
  20. Mar 21, 2019 at 12:59 PM
    #60
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Another thing that may effect your suspension height is whether you torque to spec before or after you drop the suspension down on all four wheels.
