Issue bolting new shocks to lower a-arm
Discussion in 'Suspension' started by Pyetime, Oct 16, 2013.
  1. Oct 16, 2013 at 7:55 AM
    Pyetime
    Pyetime [OP] Active Member
    Colorado
    06 Tacoma 4dr TRD Sport
    Ok, so I got myself in over my head I guess here. Im attempting to put new shocks on my 06 TRD Sport and having a hell of a time getting the bottom bolt started. Everything else is done, I took out the shock and spring as a unit and used a spring compressor to put the new shock in place. Put the unit back in bolted up the 3 bolts on the top of the tower and was able to get the lower shock in the bottom perch but there is no way to get enough tension off of the strut to get the bolt lined up with the hole. I tried to get one compressor on the spring while it was in the tower to take tension off but no luck. Any thoughts? The truck does have a 3" leveling kit that may be some of my issue.
  2. Oct 16, 2013 at 8:17 AM
    JoeTacoma02
    JoeTacoma02 Well-Known Member
    All the times I did mine I had another person help me put force down on the lower control arm to line up the hole. Not sure if it's the right way to do it but works every time.
  3. Oct 16, 2013 at 10:14 AM
    obscurotron
    obscurotron Well-Known Member
    N. Nevada
    '14 DCSB 4x4
    Too many to list, and I've probably forgotten a bunch.
    Get the factory bottle jack out of your truck. Put it in the wheelwell, upside down (base against the inner fender. Extend it (just use your hand to turn the 'loop' on the jack) so the jack makes contact with the UCA. Continue extending until you have clearance to get the strut in place. Slide the bolt in, 'lower' the jack, thread the nut and profit!
    That's how I did the SAW install on my '04 and how I did the SAW install on my '12. You may want a rag between the UCA and the contact point of the jack to keep it from slipping
    Mojave4x likes this.
  4. Oct 16, 2013 at 10:57 AM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    I use a small pry bar that fits underneath the shock eye and wedge it between the shock and LCA. You can use the leverage to gently pursued the LCA down and maneuver the shock into place :D
  5. Oct 16, 2013 at 7:29 PM
    Pyetime
    Colorado
    Got it, thanks guys! Just needed another pair of hands.
  6. Mar 18, 2018 at 2:23 PM
    Mojave4x
    Mojave4x Active Member
    98 SR5 4x4 extended cab 3.4 5speed & 08 limited 4Runner 4x4 4.0
    Detroit TrueTrac both diffs, re-gear 4:30, Wheeler's 8 leaf, OME 881, JBA UCAs, Bilstein 5100 all 4 corners, All new u-joints & ball joints, new LCA bushings
    That method worked great on my 98. Thank you Obscurotron for posting.frontStrut.jpg
    Slashaar likes this.
