Issue with my GB HID's
Discussion in 'Lighting' started by nolanspawn, Oct 24, 2009.
  1. Oct 24, 2009 at 7:01 PM
    nolanspawn
    nolanspawn [OP] Work In Progress
    Layton, Utah
    2011 Tundra Crewmax
    Corsa Exhuast, AFE Intake
    These HID's were bought a month ago on slimcubby's GB.
    Tonight I went to turn on my headlights and when I did only my passenger side turned on. I noticed a loud ticking sound only when I turned on the lights. To make sure it wasn't the bulb I swapped the bulbs and the drivers side one works fine on the passenger side. I checked all connections and everything seems to be fine. That loud ticking is definitely coming from the drivers side portion of the HID setup. Is it likely one of the capacitors or solenoids that's gone bad? I shot slimcubby an PM with a link to this thread hoping he has some insight.
    Whats really crappy is I am leaving at 4am tomorrow flying up north till Thursday then the following day Ill be driving home to Texas so I don't have any options of getting a replacement before I make that drive if that's the issue.
  2. Oct 25, 2009 at 3:35 AM
    nolanspawn
    Layton, Utah
    2011 Tundra Crewmax
    Also, noticed that I can't turn on the high beam. When I try to turn it on nothing happens the low just stays on.
  3. Oct 25, 2009 at 7:40 AM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    Check your fuses on the relay and fuse box.
  4. Oct 25, 2009 at 7:43 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    About the hi-beams-Did you buy the bi-zeon bulbs??
  5. Oct 25, 2009 at 11:17 AM
    nolanspawn
    Layton, Utah
    2011 Tundra Crewmax
    If a fuse was blown wouldn't the passenger side not work either.
    Yes. Prior to this the hi-beams worked awesome.
  6. Oct 25, 2009 at 6:00 PM
    Viet2100
    Viet
    South Florida
    2016 Prius 4T
    Sorry I read your post too fast. When you swapped bulbs, you never stated that you put the passenger bulb in the driver's side...
  7. Oct 25, 2009 at 6:04 PM
    slimsdepot
    slimsdepot slimsdepot.com
    SoCal
    08 PreRunner
    Hey there,
    I am not sure what could be ticking I haven't had this issue yet with anybody. It could possibly be a bad ballast. Does the sound seem to be coming from the ballast? Also, are your grounds good? I always recommend grounding to the battery negative terminal.
    For us to determine if the ballast needs to be replaced please swap the ballasts with one another. (driver to passenger and vise versa). Then turn the lights on and see if the problem stays on the bad side or moves with the ballast. Let me know how that goes and we will go from there.
    I appologize you had to have a problem with your kit but I will take care of you and get it fixed asap. Sorry for the delay reply I had to fly to Arizona on Friday to pick up my grandma and I just got back.
  8. Oct 25, 2009 at 6:06 PM
    jeremiekc
    jeremiekc Well-Known Member
    Jeremie
    Vilseck, Germany
    07 Regular Cab Base Model
    Secondary Air Filter removed, Painted Brake Calipers, AFN Drop in air cleaner, OEM Chrome Bumper, OEM Chrome grilll, OEM Cruise Control, OEM Interval Wipers, Hard Wired Garmin Nuvi 670, X-Runner Rims, Devil Horns, 6000w HID's, Bling Light Fogs with Blue Halo, OEM Bilstein Rear Shocks, 12V Plug in Truck Bed pocket. Debagged, 13" Antennax, Color Matched Satoshi Grill, URD Short Shifter, WeatherTech Floor Mats, PainLess Wiring Switched Fuse Box, Black Sand Pearl X-Runner Badges
    Also make sure that your ground is good and solid.
  9. Oct 25, 2009 at 6:07 PM
    Menametony
    Menametony Well-Known Member
    Tony
    Oahu
    09 Black 4x4 DC Offroad
    Flow Master 40 Series, TRD CAI, Kings 2.5 remote res front and back, All Pro Front bumper, All Pro Skid Plate, PIAA 4" 510 XT SMR, TC UCA's, 265/75/16 WildPeak AT3 on ATX Artillery, LightForce 240 Blitz HID's, WeatherTech Vents and FloorMats, Cobra 19 CB & PA, Maglite mod both driver and passenger, safari snorkel, TRD supercharger, warn 10k winch, PRINSU CabRack, Cali Raised 42" Light Bar, OEM bed mat, softtopper. WeatherTech Mudflaps On order dissent bed rack and retrofits.
    yeah double check everything.. i had somewhat the same problem.. and all i had to do was ground one side to the battery.. and viola
  10. Oct 25, 2009 at 6:51 PM
    nolanspawn
    Layton, Utah
    2011 Tundra Crewmax
    Yah i swapped the passenger ballast to drivers side and drivers side to passenger side. Both ballasts worked on the passenger side but not the drivers side. Whenever I get back home on Friday I'll double check the grounds.
  11. Oct 25, 2009 at 6:52 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Mine did something similar. I will be checking grounds when I get a chance. I am going to ground it at the battery.
  12. Oct 26, 2009 at 6:26 PM
    jeremiekc
    Jeremie
    Vilseck, Germany
    I grounded mine to the grounding points that are just to the side of each one of the lights. I actually ended up taking the battery and the whiper fluid bottle out to mount everything. It definately made it alot easier.
  13. Oct 27, 2009 at 9:19 AM
    slimsdepot
    SoCal
    08 PreRunner
    Ok cool make sure the grounds are good and all the connections are fastened securely. Let me know how it goes and we will go from there. :)
  14. Oct 27, 2009 at 9:26 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    This is what I did, and have not had any issues. Whenever grounding an electrical component, it is imperative to make sure you are grounding to a solid piece of metal that is also grounded and all debris and paint is free from the grounding location.
  15. Oct 27, 2009 at 8:04 PM
    jeremiekc
    Jeremie
    Vilseck, Germany
    Something that you have to also look out for on the positive wire is the size of the solderless connector is real small. I ended up increasing the size of it and then fishing the wire through the relay box and connecting it to the positive terminal in the terminal box. You can run it directly to the battery but I figured that it would be protected better inside of the box.
  16. Oct 28, 2009 at 10:25 AM
    nolanspawn
    Layton, Utah
    2011 Tundra Crewmax
    I grounded directly to the battery and still no luck getting the drivers side to work.
  17. Oct 28, 2009 at 11:29 AM
    jeremiekc
    Jeremie
    Vilseck, Germany
    Then let Slim know and he will get you a replacement.
