Issue with Rear Glass Installation after Fire Repair - pic on pg. 3
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cryptolime, May 21, 2022.
  1. May 21, 2022 at 11:17 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I thought maybe you parked next to a Chevy Volt, that sucks to see that happened but glad it wasn't worse.
  2. May 21, 2022 at 4:30 PM
    AxisCab
    AxisCab Well-Known Member
    Dave
    Bumville, or some dam place
    2018 2.7L 2WD Auto6, utility Axis Cab
    firewood scratches, Labrador hair/slobber, American flag sticker, Total Chaos bed stiffener, Scepter H20 can, onboard air
    jwctaco likes this.
  3. May 21, 2022 at 4:42 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    What the connection between the ac being on and vehicles catching fire?
  4. May 21, 2022 at 5:38 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    I reckon it makes the engine hotter, or by turning it off gives it a bit of power, ... when it's 110+ and you're straining the engine and using
    every resource available ( full A/C etc ) I suppose it is conducive to making the engine catch. Who knows I don't chance it.
    Per post online:
    The A/C condenser in front of the radiator is a big heat generator and removes heat from your vehicle and deposits the hot air in front of the radiator. The A/C pump also puts an additional load on your engine.
    So the additional heat from the A/C condenser, load form the A/C compressor and the load from going up the hill generates a lot more heat that your cooling system can't get rid of so your car can overheat going up steep hills. Thus the sign warning to turn off A/C. It isn't as much of an issue on modern well maintained vehicles especially if you aren't towing anything.
    Gunshot-6A likes this.
  5. May 21, 2022 at 6:48 PM
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    Talk about totally random guess you never have to worry about this happening again. Glad it turned out ok for you.
  6. May 21, 2022 at 6:56 PM
    Insomnivore
    Insomnivore Member
    New England, USA
    2021 Off Road 4WD
    I hear you. I got a cement taco in case I'm following a cement truck that has some type of failure in the cement delivery system. You gotta think of these possible scenarios and be prepared. Also, I carry a fire extinguisher.
  7. May 21, 2022 at 7:02 PM
    MGMDesertTaco
    Watch out for those oil trucks, you'll never get the stains out...
  8. May 21, 2022 at 7:05 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    That won't cause a fire, it will just cause the engine to overheat and blow a head gasket.
    Mas Olas and Clearwater Bill like this.
  9. May 21, 2022 at 7:57 PM
    2021SR5V64WD
    I'm not mechanically inclined - but there seems to be a correlation between those steep inclines, 110+ degree weather, and cars-a-fire.
    An overheated engine, blowing up, pulled to the side of the road, where dry grasses may make their way onto some super hot parts,
    could start it I guess.
    ToyoTaco25, Gunshot-6A and AxisCab like this.
  10. May 21, 2022 at 8:37 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    I was coming up a long grade one time in a Dodge Nitro and a plastic bag got sucked up into the air intake. Lost about all power but luckily got off to the side of the road. Really strange, never even heard of that happening before or since.
  11. May 21, 2022 at 8:42 PM
    AxisCab
    Dave
    Catalytic converters get hot and catch dry grass on fire.
    Gunshot-6A, Clearwater Bill and Chew like this.
  12. May 21, 2022 at 8:50 PM
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    Reminds me of the one time in my younger days driving a cab over Isuzu box truck for work. Was headed back to the shop on a Sunday afternoon after doing a pick-up, and noticed the needle on the fuel gauge dropping at an alarming rate.
    Alarming in that I could literally watch it move, went from a 1/2 tank to a 1/4 in about 3 miles, at which point thankfully there was a rest stop and I pulled over. The old girl was smoking, I lifted the cab but couldn't see anything obviously wrong. Then I turned it on and diesel was spurting like an artery from the fuel rail all over the hot engine.
    Shut it off and called my boss, that motherfucker had the audacity to ask me to FILL IT UP AND TRY AND MAKE IT BACK. I told him I wasn't driving it another inch, and ended up having my dad come pick us up because that piece of shit boss wouldn't come get us.
    I'm eternally grateful it was diesel, otherwise I'd probably be dead.
  13. May 21, 2022 at 10:06 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Likewise, years ago on the way from Southern California to Las Vegas a similar sign said the same thing. Just past said sign there was a burned out Volkswagen Bug carcass. It was an old Bug with no possibility of air conditioning. There was just something wrong with the vehicle and the hill and the heat of the day took its toll. Gas leaking in the engine compartment...?
  14. May 22, 2022 at 4:08 AM
    Travelinman301
    Travelinman301 4 x 4 Fanatic
    Florida
    2018 Blazing Blue Pearl Tacoma TRD Sport 4 x 4 DCSB
    KDMAX-PRO-10.0 Diode Dynamics Sport Fog Lights Morimoto Clear Tail Lights TRD Skid Plate
    If people would be more considerate and not trash our highways with plastic shopping bags (a major culprit of these types of fires), we wouldn't have to deal with this. These bags get blown around and hung up on catalytic converters, exhaust pipes and mufflers etc.. They lead to very expensive fixes or total loss sometimes.
  15. May 22, 2022 at 4:14 AM
    #35
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    Hopefully you don’t work for that asshole anymore.
    HisDad likes this.
  16. May 22, 2022 at 4:34 AM
    #36
    COMMANDO740
    COMMANDO740 Well-Known Member
    Southernahia
    2022 TRD OFFROAD MAGNETIC GRAY
    I’ve seen those get tangled up in the serpentine belts.
  17. May 22, 2022 at 4:37 AM
    #37
    COMMANDO740
    Southernahia
    :rofl::rofl::rofl:
  18. May 22, 2022 at 7:49 AM
    #38
    shakerhood
    Southern Ohio
    There was a plastic fuel filter sitting right above the distributor on old VW Bugs, fires could happen so it was always best to move that filter down below.
    Toycoma2021[QUOTED] likes this.
  19. May 25, 2022 at 8:05 AM
    #39
    cryptolime
    cryptolime [OP] Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    so looks like the bed is fine and didn't melt. they have to replace the rear trim panel on the backside of the cab as some of the insulation has melted. new rear glass. buff/polish next to the third brake light, and some clear coat restoration and other minor things. also one of the pressure vents needs to be replaced as half of it melted.
  20. May 25, 2022 at 8:37 AM
    #40
    SpyGoat
    SpyGoat I miss you Hobbs
    Tom
    Long Island, NY
    2021 TRD Off Road MGM DCSB, 2025 Land Cruiser
    A bunch..and no build thread!
    Glad it turned out ok! I have an extinguisher behind the rear drivers side seat in the little space next to the cubby hole. In NY you have to have one if you have the off road pass and they check from time to time when I'm wheeling.
    I hope to never have to use it!
    tcjacado and cryptolime[OP] like this.
