Issue with Solo Motorsports Tundra Steering Rack
Discussion in '3rd Gen. Tacomas (2016-2023)' started by finneganlives, Aug 2, 2023.
  1. Sep 27, 2023 at 5:37 PM
    Deeahgee
    Deeahgee Well-Known Member
    3rd gen. I have had great experiences with jd stuff. Probably have gone with the slide rack but didn’t want to move the oil filter/cooler
    Buttskevin21 likes this.
  2. Sep 27, 2023 at 8:01 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    I have a 2nd gen so no issues for me in that regards. Is there a reason you have offset heimed ends? Your double sheer steering tabs are those JDFab's as well?
  3. Sep 27, 2023 at 8:05 PM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    I was cramming the coilover with tie rod with the Tundra rack/stock tie rods, since the rack is set back farther.
    Deeahgee and 01 dhrracer[QUOTED] like this.
  4. Sep 27, 2023 at 10:19 PM
    Deeahgee
    Didn’t want the tie rods hitting the coils at full lock. Double sheer tabs are jd. Refitted to a Camburg lift spindle
  5. Sep 27, 2023 at 11:20 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Interesting stuff. I am about to install the Basiker tundra rack. Already have outer heims but I am unsure if i want to run full solid tie rods and inner heims or leave stock inner and run a war fab sleave or as is.
    Basikbiker likes this.
  6. Oct 7, 2023 at 11:03 AM
    lit_taco4x4
    lit_taco4x4 IG and YT: @2a_crawlcamper
    Louie
    2018 Tacoma TRD Pro
    JD fab LT, Archive and Deavers, King shocks, Dual locked, Dual T case, Tundra steering rack, 39’s
    Had this same issue. Not a fan of the offset heim ends. Got longer rod ends on the shock to clear the heims from rubbing the coils. It gave me a lift so I ended up with 550 lb. coil springs to level out. A bit of a nose dive now. Other than that @Basikbiker tundra rack holds up pretty good.
  7. Oct 12, 2023 at 7:14 PM
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    originally when i first started doing these racks i offered em with new weld in bushings because that was the only feasable way to get it to fit as properly as possible. but many folks out there wanted a bolt in option so the eccentric idea came about. all valid points are mentioned in this thread. some people care some dont. ill still offer the weld in bungs to anyone that wants em. i been dicking around on the computer to design a new crossmember to mount everything perfect, as well as billet diff mounts, but i dont know if the endevor will be worth it? and my truck isnt a good test vehicle for it because i designed a whole LT kit around the rack.
  8. Oct 13, 2023 at 11:16 AM
    aturk
    aturk Well-Known Member
    Tony
    Charlotte, NC
    YES for the crossmember and diff mounts.
  9. Oct 16, 2023 at 10:16 AM
    nudavinci64
    Robert
    Made to fit count me in too!
  10. Apr 7, 2025 at 8:33 AM
    tacoman_13
    tacoman_13 Well-Known Member
    Triston
    San Diego
    2007 TRD Off-Road
    JD Fab LT, Archive Garage Hammer Hangers, soon to be on 35's
    who’s offset heims are those?
  11. Apr 7, 2025 at 8:45 AM
    Deeahgee
    Rusty offroad
  12. Apr 7, 2025 at 8:46 AM
    tacoman_13
    Triston
    San Diego
    2007 TRD Off-Road
    Yup, I bought the same ones then. How have they been holding up? and do you have the offset bushing in the steering rack or did you do cut out and re-weld new barrels?
  13. Apr 7, 2025 at 8:50 AM
    Deeahgee
    They’ve been great so far. The rack came with offset bushings but it wasn’t enough. I ended up making some new barrels and welded them in an inch forward. Probably could have gone another 1/4 forward but it started to get wonky with the power steering lines
  14. Apr 7, 2025 at 8:52 AM
    tacoman_13
    Triston
    San Diego
    2007 TRD Off-Road
    Cool, think i’ll be able to clear with the oem spot, offset bushings, and the same offset heims? i’m running a jd kit as well but just oem lower pivots.
  15. Apr 7, 2025 at 9:15 AM
    #35
    Deeahgee
    my son switched to the kartek tie rods and pick up a little clearance as they are smaller in diameter than the aluminum jd rods. He and I are both one puck forward on the pivot kit which is roughly about 1 1/8 forward on the suspension. He is running the stock rack in the stock location with the nylon bushing from JD.
  16. Apr 7, 2025 at 9:19 AM
    #36
    tacoman_13
    Triston
    San Diego
    2007 TRD Off-Road
    have anymore photos for reference? I want to see how much tie rod clearance i’ll need to be able to clear everything
  17. Apr 7, 2025 at 10:11 AM
    #37
    nudavinci64
    Robert
    I have the Basibiker and JD pivot kit. I had to go back to stock for now as the eccentric bushing was rubbing on the springs, moving the rack about 3/4 inches from its stock location. The offset is an interesting idea. I have see some others get custom solid ones that tapered narrower in the middle and wider on the ends to clear this issue. Forgot where I saw it but possible solution as well.
  18. Apr 10, 2025 at 10:27 AM
    #38
    tacoman_13
    Triston
    San Diego
    2007 TRD Off-Road
    Was your rack one where it was a requirement to cut out the old mounting barrels and re-weld in new ones? I would recommend doing this.
  19. Apr 10, 2025 at 10:31 AM
    #39
    tacoman_13
    Triston
    San Diego
    2007 TRD Off-Road
    And for others with a JD LT kit, I spoke with Jesse as he knows the issue with his kits and clearance with the tie rods and springs. He made a fix for it that he is starting to sell. It's a new coil bucket. You cut out the top portion just above the UCA bolt and re weld in his coil bucket. It moves the mounting point up higher and you no longer utilize a top hat for the coilovers. Paired with it would be a longer rod end, so that there would be more clearance with the tie rods. The tie rods would then be at the height with the rod ends rather than with the springs. Also for 3g tacos your able to bolt an engine cross bar to both of the shock mounts.
    AY_ARONTRD likes this.
  20. Apr 10, 2025 at 10:38 AM
    #40
    AY_ARONTRD
    AY_ARONTRD Well-Known Member
    Aaron
    Murrieta ,CA
    2019 DCLB Cement OR 4x4
    Yeah, I’m currently waiting for a tundra rack, JD’s going to do the install w/ their longer rod ends and top hats. I installed new tie rods and mine were hitting as well. Known issue
