Issues after battery install
Discussion in 'Technical Chat' started by CoachKTacoma, Jul 15, 2024.
  1. Jul 15, 2024 at 4:44 PM
    CoachKTacoma
    CoachKTacoma [OP] New Member
    2019 Toyota Tacoma
    Finally had to replace factory battery and ever since then I've had several dash warnings.
    1-Check Vehicle Stability System
    2- Lane Departure Alert Malfunction
    3-Pre-Collision System Malfunction
    4- Headlight System Malfunction
    they scroll after starting vehicle, even cruise control stopped working.
    I've tried disconcerting battery for 30 minutes and reconnect.
    Dealer wanted to charge $1,200 to replace steering wheel sensor and they weren't sure that would be the fix, I left there and didn't allow to work on vehicle.
    I hope someone on here can help me.
  2. Jul 15, 2024 at 4:57 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Need to know what code(s) it's setting in what module(s) before we're gona be much help.
    TnShooter likes this.
  3. Jul 15, 2024 at 5:16 PM
    CoachKTacoma
    Zero codes are being thrown, I’ve checked for them and also had a friend check them with his reader as well just in case I was doing it wrong
  4. Jul 15, 2024 at 5:21 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    A generic code reader will only pull codes from the PCM, there may not be any codes in the PCM but there's almost certainly codes in other modules. You need a scan tool that can do all systems to get the codes from modules other than the PCM.
