Issues if 4x4 hasn't been engaged in a long time?
Discussion in '1st Gen. Tacomas (1995-2004)' started by vantaco, Sep 10, 2010.
  1. Sep 10, 2010 at 10:54 AM
    vantaco
    vantaco [OP] Well-Known Member
    02 Taco Xtracab TRD Step Side
    I'm looking at an 04 non TRD v6 4x4 and by the sounds of it the 4x4 hasn't been engaged in quite some time (couple years or more possibly)
    is this an issue? any other thoughts?
    thanks
  2. Sep 10, 2010 at 10:55 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Not an issue. Try it before you buy it though just to make sure everything engages.
  3. Sep 10, 2010 at 11:01 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Regardless of what the possibilities are.... You should always test drive a vehicle and ALWAYS put it into 4WD in both Hi and Lo range to make sure everything works.
    And yes...there are possibilties that the 4WD may not engage because it hasn't been engaged for so long.
    I would not buy the truck if the 4WD doesn't work and the owner isn't willing to fix it for you or drop the price A LOT to accomodate a repair bill.
  4. Sep 10, 2010 at 12:12 PM
    vantaco
    well i asked him, and he claims he engages it once a month to keep it lubricated (which is the reason to)
    it's his 3 tacoma, and he seems to know quite a bit about the truck (listed off a few rear lockers, it's not a trd and i brought those up)
  5. Sep 10, 2010 at 8:06 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    The manual recommends engaging 4Hi at least once a month for the ADD equipped vehicles. If this in fact has been done, it is enough to lubricate the system and count as has having been used.
    I would agree with what others have said. If the system engages without issues it is very likely OK. It is a very well designed system capable of withstanding a lot of abuse, including minimal use.
  6. Sep 11, 2010 at 5:02 AM
    Janster
    Jandy
    Lancaster, PA
    You originally said he didn't engage it in 2 years......
    And now you're saying he engaged it every month? Did he tell you (originally) that it was 2 years? Or is he feeding you a line of BS now?
    I'd definately take it for a test drive and put it in 4hi and 4lo. If it'll engage and you can tell all 4 wheels are being driven, it should be OK - assuming nothing else is wrong.
    Ask him - "When was the last time he changed the oil in the front diff, rear diff, transfer case & the transmission"
    That'll give you a clue whehter or not the guy takes care of his stuff.
